USB 3.0 to Gigabit
I am facing an issue to access usb from Debian linux platform.
The exact error is:
Failed to attach the USB device TP-LINK USB 10/100/10000 LAN [3000] to the virtual machine
Actually has plug and play installation support for Windows and Linux OS. But still i can’t access it. Do I need to install supporting drivers in linux os?
If yes, I have received a driver CD along with the pack while purchasing. Where can I find these supporting drivers?
If you know how to solve this issue, please let me know.
Thanks in advance.
regards,
Jay
The exact error is:
*Failed to attach the USB device TP-LINK USB 10/100/10000 LAN [3000] to the
virtual machine*
  "virtual machine"? This has nothing to do with a Beagle board itself,
does it?
  What virtual machine controller are you using? Oracle VirtualBox, M$
Hyper-V?
But still i can't access it. Do I need to install supporting drivers in
linux os?
  Oracle VirtualBox, "Settings" for the virtual machine has a "Network"
page with four network tabs. Normally the first tab is already configured
with the host network hardware. I suspect (IF you are using VBox) that you
will need to make changes to, say, Network 2 -- setting what type of
connection you have (obtain the documentation for VBox and study it), and
under "Advanced" select the USB NIC.
  This will, I believe, create a second "virtual" network connection
inside the virtual machine -- the host OS is the one that actually talks to
the USB NIC, so (assumption here) that would be Windows. VBox (running on
Windows) translates the virtual machine requests into Windows operations.
Hello
Issue solved.
Thanks for the support
regards,
Jay
