USB and ethernet interfaces are not visible to me.
Hi All,
I recently build mainline linux kernel (6.6.0-rc3). You cna checklog for more information.
I didn’t get usb and ethernet interface when i run ifconfig command.
Can someone pointout the issue ?
U-Boot SPL 2023.04 (Oct 04 2023 - 16:14:54 +0530)
Trying to boot from MMC1
U-Boot 2023.04 (Oct 04 2023 - 16:14:54 +0530)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
Core:  160 devices, 18 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing every 1000ms (60s timeout)
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
<ethaddr> not set. Validating first E-fuse MAC
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1:      beaglebone-buildroot
Retrieving file: /zImage
append: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Retrieving file: /am335x-boneblack-wireless.dtb
Kernel image @ 0x82000000 [ 0x000000 - 0x4ee988 ]
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
   Loading Device Tree to 8ffeb000, end 8ffff0ab ... OK
Working FDT set to 8ffeb000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.6.0-rc3 (root@riscv-demo) (arm-linux-gnueabihf-gc        c (GCC) 14.0.0 20230605 (experimental) [master revision c7fe7ad612bb6aac1d078d21        5d5700ec4ef70e3c], GNU ld (Linaro_Binutils-2023.06) 2.40.50.20230605) #1 SMP Fri        Oct  6 09:19:37 IST 2023
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio        n cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black Wireless
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9e800000 on node -1
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 16 pages/cpu s36052 r8192 d21292 u65536
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 r        w rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, l        inear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, li        near)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 484736K/522240K available (10240K kernel code, 1108K rwda        ta, 2532K rodata, 1024K init, 283K bss, 21120K reserved, 16384K cma-reserved, 0K        highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif        fies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrup        ts
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segm        ent@200000/target-module@31000
[    0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478        484971ns
[    0.000027] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 79635851949 ns
[    0.000491] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/        segment@0/target-module@40000
[    0.001959] Console: colour dummy device 80x30
[    0.002035] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.090538] CPU: Testing write buffer coherency: ok
[    0.090640] CPU0: Spectre v2: using BPIALL workaround
[    0.090651] pid_max: default: 32768 minimum: 301
[    0.090779] LSM: initializing lsm=capability,integrity
[    0.090950] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linea        r)
[    0.090971] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes,        linear)
[    0.092438] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.094002] Setting up static identity map for 0x80100000 - 0x80100078
[    0.094282] rcu: Hierarchical SRCU implementation.
[    0.094293] rcu:     Max phase no-delay instances is 1000.
[    0.094986] smp: Bringing up secondary CPUs ...
[    0.095031] smp: Brought up 1 node, 1 CPU
[    0.095043] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[    0.095054] CPU: All CPU(s) started in SVC mode.
[    0.095885] devtmpfs: initialized
[    0.111535] VFP support v0.3: implementor 41 architecture 3 part 30 variant c        rev 3
[    0.111876] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
[    0.111909] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.113184] pinctrl core: initialized pinctrl subsystem
[    0.115517] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.118012] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.118607] audit: initializing netlink subsys (disabled)
[    0.119841] thermal_sys: Registered thermal governor 'fair_share'
[    0.119860] thermal_sys: Registered thermal governor 'step_wise'
[    0.119866] thermal_sys: Registered thermal governor 'user_space'
[    0.119969] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=        0 res=1
[    0.120045] cpuidle: using governor menu
[    0.136089] No ATAGs?
[    0.136114] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.139011] kprobes: kprobe jump-optimization is enabled. All kprobes are opt        imized if possible.
[    0.795811] iommu: Default domain type: Translated
[    0.795832] iommu: DMA domain TLB invalidation policy: strict mode
[    0.797235] SCSI subsystem initialized
[    0.799005] pps_core: LinuxPPS API ver. 1 registered
[    0.799017] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome        tti <giometti@linux.it>
[    0.799040] PTP clock support registered
[    0.800953] vgaarb: loaded
[    0.801263] clocksource: Switched to clocksource dmtimer
[    0.801844] VFS: Disk quotas dquot_6.6.0
[    0.801908] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.823589] NET: Registered PF_INET protocol family
[    0.823927] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear        )
[    0.825269] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096        bytes, linear)
[    0.825304] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes,        linear)
[    0.825320] TCP established hash table entries: 4096 (order: 2, 16384 bytes,        linear)
[    0.825362] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.825460] TCP: Hash tables configured (established 4096 bind 4096)
[    0.825592] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.825620] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.825796] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.826942] RPC: Registered named UNIX socket transport module.
[    0.826964] RPC: Registered udp transport module.
[    0.826969] RPC: Registered tcp transport module.
[    0.826975] RPC: Registered tcp-with-tls transport module.
[    0.826980] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.827004] PCI: CLS 0 bytes, default 64
[    0.828528] Initialise system trusted keyrings
[    0.829352] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.830552] NFS: Registering the id_resolver key type
[    0.830625] Key type id_resolver registered
[    0.830633] Key type id_legacy registered
[    0.830685] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.831136] Key type asymmetric registered
[    0.831151] Asymmetric key parser 'x509' registered
[    0.831220] io scheduler mq-deadline registered
[    0.831387] io scheduler kyber registered
[    0.831477] io scheduler bfq registered
[    0.835406] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[    0.853741] brd: module loaded
[    0.861587] loop: module loaded
[    0.862494] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.865173] i2c_dev: i2c /dev entries driver
[    0.866015] cpuidle: enable-method property 'ti,am3352' found operations
[    0.866465] sdhci: Secure Digital Host Controller Interface driver
[    0.866475] sdhci: Copyright(c) Pierre Ossman
[    0.866650] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.866907] ledtrig-cpu: registered to indicate activity on CPUs
[    0.867659] Initializing XFRM netlink socket
[    0.867783] NET: Registered PF_INET6 protocol family
[    0.869494] Segment Routing with IPv6
[    0.869568] In-situ OAM (IOAM) with IPv6
[    0.869678] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.870571] NET: Registered PF_PACKET protocol family
[    0.870601] NET: Registered PF_KEY protocol family
[    0.870763] Key type dns_resolver registered
[    0.870964] ThumbEE CPU extension supported.
[    0.870986] Registering SWP/SWPB emulation handler
[    0.871569] omap_voltage_late_init: Voltage driver support not added
[    0.871919] SmartReflex Class3 initialized
[    0.879229] Loading compiled-in X.509 certificates
[    0.920705] platform 44e10800.pinmux: Fixed dependency cycle(s) with /ocp/int        erconnect@44c00000/segment@200000/target-module@10000/scm@0/pinmux@800/clkout2-p        ins
[    0.921416] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.926015] ti-sysc: probe of 44e31000.target-module failed with error -16
[    0.940476] ti-sysc: probe of 48040000.target-module failed with error -16
[    0.952833] OMAP GPIO hardware version 0.1
[    0.965554] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    0.970502] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 25, base_baud =        3000000) is a 8250
[    0.970832] serial serial0: tty port ttyS3 registered
[    1.001749] debugfs: Directory '49000000.dma' with parent 'dmaengine' already        present!
[    1.001802] edma 49000000.dma: TI EDMA DMA engine driver
[    1.013078] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regu        lator
[    1.013547] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regu        lator
[    1.028485] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counter        s available
[    1.035896] l3-aon-clkctrl:0000:0: failed to disable
[    1.038958] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 32, base_baud =        3000000) is a 8250
[    1.039036] printk: console [ttyS0] enabled
[    1.913117] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using Exter        nal DMA
[    1.952141] tps65217-pmic: Failed to locate of_node [id: -1]
[    1.958208] tps65217-bl: Failed to locate of_node [id: -1]
[    1.969216] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.975431] i2c 0-0070: Fixed dependency cycle(s) with /ocp/interconnect@4800        0000/segment@300000/target-module@e000/lcdc@0/port/endpoint@0
[    1.988200] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.997772] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000        microseconds (-22)
[    2.006683] sdhci-omap 48060000.mmc: Got CD GPIO
[    2.011687] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regu        lator
[    2.023010] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regu        lator
[    2.031776] sdhci-omap 47810000.mmc: supply pbias not found, using dummy regu        lator
[    2.040500] sdhci-omap 47810000.mmc: supply vqmmc not found, using dummy regu        lator
[    2.060227] mmc1: new high speed MMC card at address 0001
[    2.067216] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    2.074275]  mmcblk1: p1 p2
[    2.078438] mmcblk1boot0: mmc1:0001 MMC04G 2.00 MiB
[    2.084777] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using Exter        nal DMA
[    2.094706] mmcblk1boot1: mmc1:0001 MMC04G 2.00 MiB
[    2.101864] mmcblk1rpmb: mmc1:0001 MMC04G 128 KiB, chardev (250:0)
[    2.166619] mmc2: SDHCI controller on 47810000.mmc [47810000.mmc] using Exter        nal DMA
[    2.177654] clk: Disabling unused clocks
[    2.182598] mmc0: new high speed SDHC card at address e624
[    2.189528] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[    2.201188]  mmcblk0: p1 p2
[    2.252249] EXT4-fs (mmcblk0p2): recovery complete
[    2.261169] EXT4-fs (mmcblk0p2): mounted filesystem 1a64b592-aa5f-414f-9644-5        e7e70d5bbe7 r/w with ordered data mode. Quota mode: none.
[    2.273525] VFS: Mounted root (ext4 filesystem) on device 179:26.
[    2.285974] devtmpfs: mounted
[    2.290420] Freeing unused kernel image (initmem) memory: 1024K
[    2.297055] Run /sbin/init as init process
[    2.456676] EXT4-fs (mmcblk0p2): re-mounted 1a64b592-aa5f-414f-9644-5e7e70d5b        be7 r/w. Quota mode: none.
[    2.603398] random: crng init done
Seeding 256 bits and crediting
Saving 256 bits of creditable seed for next boot
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Starting mdev... OK
[    2.623385] mmc2: Failed to initialize a non-removable card
[    4.223319] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    4.235306] omap-aes 53500000.aes: will run requests pump with realtime priority
[    4.262444] at24 2-0054: supply vcc not found, using dummy regulator
[    4.296028] at24 2-0055: supply vcc not found, using dummy regulator
[    4.334880] at24 2-0056: supply vcc not found, using dummy regulator
[    4.374832] at24 2-0057: supply vcc not found, using dummy regulator
[    4.417601] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    4.584634] Bluetooth: Core ver 2.22
[    4.588504] NET: Registered PF_BLUETOOTH protocol family
[    4.593959] Bluetooth: HCI device and connection manager initialized
[    4.600371] Bluetooth: HCI socket layer initialized
[    4.605310] Bluetooth: L2CAP socket layer initialized
[    4.610419] Bluetooth: SCO socket layer initialized
[    4.657684] Bluetooth: HCI UART driver ver 2.3
[    4.662347] Bluetooth: HCI UART protocol H4 registered
[    4.667516] Bluetooth: HCI UART protocol BCSP registered
[    4.673159] Bluetooth: HCI UART protocol LL registered
[    4.678391] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.685172] Bluetooth: HCI UART protocol Broadcom registered
[    4.695362] Bluetooth: hci0: Frame reassembly failed (-84)
[    4.830358] remoteproc remoteproc0: wkup_m3 is available
[    5.035155] Bluetooth: hci0: Failed to get CTS
[    5.184908] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    5.443102] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    5.458106] input: tps65217_pwrbutton as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    5.541623] omap_rng 48310000.rng: Random Number Generator ver. 20
[    5.572988] omap_rtc 44e3e000.rtc: already running
[    5.604215] omap_rtc 44e3e000.rtc: registered as rtc0
[    5.609384] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:20:05 UTC (946686005)
[    5.652202] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    5.671859] omap-sham 53100000.sham: will run requests pump with realtime priority
[    5.894035] tda998x 0-0070: found TDA19988
[    5.913340] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops [tda998x])
[    5.933538] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    5.942071] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[    5.950656] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[    6.010191] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[    6.057644] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[    6.163671] usbcore: registered new interface driver usbfs
[    6.169294] usbcore: registered new interface driver hub
[    6.174848] usbcore: registered new device driver usb
[    6.295438] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    6.300849] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    6.325406] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    6.333864] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.341129] usb usb1: Product: MUSB HDRC host driver
[    6.346171] usb usb1: Manufacturer: Linux 6.6.0-rc3 musb-hcd
[    6.351881] usb usb1: SerialNumber: musb-hdrc.1
[    6.392291] hub 1-0:1.0: USB hub found
[    6.396193] hub 1-0:1.0: 1 port detected
[    6.433532] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    6.483234] remoteproc remoteproc0: powering up wkup_m3
[    6.488657] remoteproc remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2
[    6.498388] remoteproc remoteproc0: request_firmware failed: -2
[    6.504410] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed
[    6.553596] PM: Cannot get wkup_m3_ipc handle
Starting network: ip: SIOCGIFFLAGS: No such device
FAIL
Welcome to Buildroot
buildroot login: root
# [   17.122149] PM: Cannot get wkup_m3_ipc handle
[   17.126828] platform pm33xx: deferred probe pending
# ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
# lsmod
Module                  Size  Used by    Not tainted
pm33xx                 12288  0
cpufreq_dt             12288  0
wkup_m3_ipc            12288  1 pm33xx
omap_wdt               12288  0
watchdog               24576  1 omap_wdt
musb_dsps              16384  0
musb_hdrc             126976  1 musb_dsps
udc_core               45056  1 musb_hdrc
usbcore               204800  1 musb_hdrc
snd_soc_hdmi_codec     16384  1
phy_am335x             12288  2
phy_generic            12288  1 phy_am335x
usb_common             12288  5 musb_dsps,musb_hdrc,udc_core,usbcore,phy_am335x
tda998x                20480  0
snd_soc_simple_card    16384  0
snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
omap_sham              28672  0
evdev                  20480  0
rtc_omap               16384  2 pm33xx
omap_rng               12288  0
rng_core               16384  1 omap_rng
tps65218_pwrbutton     12288  0
snd_soc_davinci_mcasp    24576  2
snd_soc_ti_udma        12288  1 snd_soc_davinci_mcasp
snd_soc_ti_edma        12288  1 snd_soc_davinci_mcasp
snd_soc_ti_sdma        12288  1 snd_soc_davinci_mcasp
snd_soc_core          180224  7 snd_soc_hdmi_codec,snd_soc_simple_card,snd_soc_simple_card_utils,snd_soc_davinci_mcasp,snd_soc_ti_udma,snd_soc_ti_edma,snd_soc_ti_sdma
snd_pcm_dmaengine      12288  1 snd_soc_core
snd_pcm               110592  5 snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_davinci_mcasp,snd_soc_core,snd_pcm_dmaengine
snd_timer              32768  1 snd_pcm
snd                    69632  4 snd_soc_hdmi_codec,snd_soc_core,snd_pcm,snd_timer
soundcore              12288  1 snd
omap_mailbox           16384  1
leds_gpio              12288  0
led_class              12288  1 leds_gpio
tilcdc                 32768  0
drm_dma_helper         16384  2 tilcdc
drm_kms_helper        122880  3 tda998x,tilcdc,drm_dma_helper
drm                   425984  5 tda998x,tilcdc,drm_dma_helper,drm_kms_helper
drm_panel_orientation_quirks    12288  1 drm
ti_emif_sram           12288  1 pm33xx
cppi41                 16384 60
wkup_m3_rproc          12288  1
phy_am335x_control     12288  1 phy_am335x
hci_uart               53248  0
btbcm                  16384  1 hci_uart
bluetooth             520192  3 hci_uart,btbcm
ecdh_generic           12288  1 bluetooth
ecc                    32768  1 ecdh_generic
at24                   16384  0
omap_aes_driver        24576  0
omap_crypto            12288  1 omap_aes_driver
crypto_engine          12288  2 omap_sham,omap_aes_driver
libaes                 12288  2 bluetooth,omap_aes_driver
see the same thing, try “ifconfig eth0 up”
my guess is that there is a package missing in the build that makes this a startup at boot time.
How to compile missing pakage ? Any pointer ???
# ifconfig
# ifconfig eth0 up
ifconfig: SIOCGIFFLAGS: No such device
Is your board a BeagleBone Black or BeagleBone Black Wireless…
As your booting as a BeagleBone Black Wireless
@RobertCNelson,
My board is beaglebone black. :melting_face:
But I checked with both dtb am335x-boneblack.dtb and am335x-boneblack-wireless.dtb.
But Issue is same.
add:
fdt /am335x-boneblack.dtb
to extlinux.conf…
the following is with the default build from the Buildroot image that you referenced above.
it should work out of the box, i’m testing on BBB non-wireless version
# ifconfig
# ifconfig eth0 192.168.3.86 up
[   21.270521] cpsw 4a100000.ethernet: initializing cpsw version 1.12 (0)
[   21.367270] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC)
# [   24.566250] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow f
[   24.574368] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
ifconfig
eth0      Link encap:Ethernet  HWaddr B0:D5:CC:CD:8A:B7
          inet addr:192.168.3.86  Bcast:192.168.3.255  Mask:255.255.255.0
          inet6 addr: fe80::b2d5:ccff:fecd:8ab7/64 Scope:Link
          inet6 addr: 2603:8081:1500:111a:b2d5:ccff:fecd:8ab7/64 Scope:Global
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:728 (728.0 B)  TX bytes:602 (602.0 B)
# ping 192.168.3.1
PING 192.168.3.1 (192.168.3.1): 56 data bytes
64 bytes from 192.168.3.1: seq=0 ttl=64 time=1.160 ms
64 bytes from 192.168.3.1: seq=1 ttl=64 time=0.749 ms
^C
--- 192.168.3.1 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.749/0.954/1.160 ms
Hi @RobertCNelson
etxlinux/etxlinux.conf
label beaglebone-buildroot
  kernel /zImage
  append console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
vi /etc/network/interfaces
# interface file auto-generated by buildroot
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 192.168.10.1
netmask 255.255.255.0
gateway 192.168.10.1
ifconfig
# ifconfig
eth0      Link encap:Ethernet  HWaddr 6C:EC:EB:A5:A0:34
          inet addr:192.168.10.1  Bcast:0.0.0.0  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
I think ethernet is set up but how can we set up usb interface also.
Thanks & Regards
Vivek Yadav
Create systemd service file:
bb-usb-gadgets.service
[Unit]
Description=BeagleBoard.org USB gadgets
After=usb-gadget.target
ConditionFileIsExecutable=/usr/bin/bb-start-acm-ncm-rndis-old-gadget
[Service]
Type=forking
ExecStartPre=/sbin/modprobe libcomposite
ExecStart=/usr/bin/bb-start-acm-ncm-rndis-old-gadget
[Install]
WantedBy=multi-user.target
Copy this file as:
/usr/bin/bb-start-acm-ncm-rndis-old-gadget : https://github.com/rcn-ee/repos/blob/master/bb-usb-gadgets/suite/bookworm/debian/bb-start-acm-ncm-rndis-old-gadget
Then copy this file as:
/usr/bin/bb-setup-mac-address : https://github.com/rcn-ee/repos/blob/master/generic-sys-mods/suite/bookworm/debian/bb-setup-mac-address
Hi @RobertCNelson,
vi /etc/systemd/system/bb-usb-gadgets.service
[Unit]
[Service]
Type=forking
[Install]
And otherfiles content copied as specified location.
Still not getting usb interface
# reboot
# Stopping network: OK
Stopping mdev... stopped process in pidfile '/var/run/mdev.pid' (pid 100)
OK
Stopping klogd: OK
Stopping syslogd: OK
umount: devtmpfs busy - remounted read-only
[  271.081396] EXT4-fs (mmcblk0p2): re-mounted 1a64b592-aa5f-414f-9644-5e7e70d5bbe7 ro. Quota mode: none.
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
[  273.204492] reboot: Restarting system
DRAM:  512 MiB
NAND:  0 MiB
Scanning mmc 0:1...
Retrieving file: /am335x-boneblack.dtb
   Loading Device Tree to 8ffeb000, end 8ffff1be ... OK
Starting kernel ...
[    0.000000] Linux version 6.6.0-rc3 (root@riscv-demo) (arm-linux-gnueabihf-gcc (GCC) 14.0.0 20230605 (experimental) [master revision c7fe7ad612bb6aac1d078d215d5700ec4ef70e3c], GNU ld (Linaro_Binutils-2023.06) 2.40.50.20230605) #1 SMP Fri Oct  6 09:19:37 IST 2023
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Memory: 484740K/522240K available (10240K kernel code, 1108K rwdata, 2532K rodata, 1024K init, 283K bss, 21116K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000026] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000486] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.001934] Console: colour dummy device 80x30
[    0.002010] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.090533] CPU: Testing write buffer coherency: ok
[    0.090637] CPU0: Spectre v2: using BPIALL workaround
[    0.090649] pid_max: default: 32768 minimum: 301
[    0.090774] LSM: initializing lsm=capability,integrity
[    0.090944] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.090964] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.092440] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.094011] Setting up static identity map for 0x80100000 - 0x80100078
[    0.094288] rcu: Hierarchical SRCU implementation.
[    0.094299] rcu:     Max phase no-delay instances is 1000.
[    0.095007] smp: Bringing up secondary CPUs ...
[    0.095053] smp: Brought up 1 node, 1 CPU
[    0.095064] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[    0.095075] CPU: All CPU(s) started in SVC mode.
[    0.095917] devtmpfs: initialized
[    0.111327] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.111674] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.111709] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.113083] pinctrl core: initialized pinctrl subsystem
[    0.115439] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.117931] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.118524] audit: initializing netlink subsys (disabled)
[    0.119760] thermal_sys: Registered thermal governor 'fair_share'
[    0.119781] thermal_sys: Registered thermal governor 'step_wise'
[    0.119787] thermal_sys: Registered thermal governor 'user_space'
[    0.119900] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=0 res=1
[    0.119977] cpuidle: using governor menu
[    0.135725] No ATAGs?
[    0.135750] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.138589] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.795389] iommu: Default domain type: Translated
[    0.795409] iommu: DMA domain TLB invalidation policy: strict mode
[    0.796803] SCSI subsystem initialized
[    0.798541] pps_core: LinuxPPS API ver. 1 registered
[    0.798553] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.798575] PTP clock support registered
[    0.800370] vgaarb: loaded
[    0.800769] clocksource: Switched to clocksource dmtimer
[    0.801369] VFS: Disk quotas dquot_6.6.0
[    0.801431] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.823090] NET: Registered PF_INET protocol family
[    0.823424] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.824762] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.824794] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.824811] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.824853] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.824952] TCP: Hash tables configured (established 4096 bind 4096)
[    0.825081] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.825111] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.825288] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.826447] RPC: Registered named UNIX socket transport module.
[    0.826467] RPC: Registered udp transport module.
[    0.826473] RPC: Registered tcp transport module.
[    0.826478] RPC: Registered tcp-with-tls transport module.
[    0.826483] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.826509] PCI: CLS 0 bytes, default 64
[    0.828024] Initialise system trusted keyrings
[    0.828865] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.830061] NFS: Registering the id_resolver key type
[    0.830137] Key type id_resolver registered
[    0.830145] Key type id_legacy registered
[    0.830195] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.830643] Key type asymmetric registered
[    0.830659] Asymmetric key parser 'x509' registered
[    0.830723] io scheduler mq-deadline registered
[    0.830890] io scheduler kyber registered
[    0.830980] io scheduler bfq registered
[    0.834888] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[    0.853438] brd: module loaded
[    0.861338] loop: module loaded
[    0.862240] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.864889] i2c_dev: i2c /dev entries driver
[    0.865718] cpuidle: enable-method property 'ti,am3352' found operations
[    0.866160] sdhci: Secure Digital Host Controller Interface driver
[    0.866170] sdhci: Copyright(c) Pierre Ossman
[    0.866343] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.866604] ledtrig-cpu: registered to indicate activity on CPUs
[    0.867350] Initializing XFRM netlink socket
[    0.867502] NET: Registered PF_INET6 protocol family
[    0.869216] Segment Routing with IPv6
[    0.869293] In-situ OAM (IOAM) with IPv6
[    0.869404] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.870324] NET: Registered PF_PACKET protocol family
[    0.870352] NET: Registered PF_KEY protocol family
[    0.870477] Key type dns_resolver registered
[    0.870681] ThumbEE CPU extension supported.
[    0.870701] Registering SWP/SWPB emulation handler
[    0.871275] omap_voltage_late_init: Voltage driver support not added
[    0.871613] SmartReflex Class3 initialized
[    0.878946] Loading compiled-in X.509 certificates
[    0.920017] platform 44e10800.pinmux: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@10000/scm@0/pinmux@800/clkout2-pins
[    0.920549] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.925256] ti-sysc: probe of 44e31000.target-module failed with error -16
[    0.939630] ti-sysc: probe of 48040000.target-module failed with error -16
[    0.952114] OMAP GPIO hardware version 0.1
[    0.964793] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    0.994490] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    0.994980] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    1.050782] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.072614] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    1.073064] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[    1.073082] cpsw-switch 4a100000.switch: ALE Table size 1024
[    1.073208] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[    1.073224] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[    1.073311] cpsw-switch 4a100000.switch: Detected MACID = 6c:ec:eb:a5:a0:34
[    1.075047] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[    1.085485] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    1.085526] edma 49000000.dma: TI EDMA DMA engine driver
[    1.105622] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.112973] l3-aon-clkctrl:0000:0: failed to disable
[    1.115263] printk: console [ttyS0] disabled
[    1.116049] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 34, base_baud = 3000000) is a 8250
[    1.116127] printk: console [ttyS0] enabled
[    2.071695] tps65217-pmic: Failed to locate of_node [id: -1]
[    2.077729] tps65217-bl: Failed to locate of_node [id: -1]
[    2.088536] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    2.094735] i2c 0-0070: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0/port/endpoint@0
[    2.107499] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    2.116973] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    2.125886] sdhci-omap 48060000.mmc: Got CD GPIO
[    2.130909] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[    2.141589] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[    2.151324] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    2.159748] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    2.175642] clk: Disabling unused clocks
[    2.196931] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[    2.205167] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[    2.213947] Waiting for root device /dev/mmcblk0p2...
[    2.280939] mmc0: new high speed SDHC card at address e624
[    2.286982] mmc1: new high speed MMC card at address 0001
[    2.293690] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    2.299413] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[    2.307272]  mmcblk1: p1 p2
[    2.311515] mmcblk1boot0: mmc1:0001 MMC04G 2.00 MiB
[    2.317456]  mmcblk0: p1 p2
[    2.321881] mmcblk1boot1: mmc1:0001 MMC04G 2.00 MiB
[    2.329335] mmcblk1rpmb: mmc1:0001 MMC04G 128 KiB, chardev (250:0)
[    2.353979] EXT4-fs (mmcblk0p2): mounted filesystem 1a64b592-aa5f-414f-9644-5e7e70d5bbe7 r/w with ordered data mode. Quota mode: none.
[    2.366404] VFS: Mounted root (ext4 filesystem) on device 179:10.
[    2.383764] devtmpfs: mounted
[    2.388114] Freeing unused kernel image (initmem) memory: 1024K
[    2.394779] Run /sbin/init as init process
[    2.560620] EXT4-fs (mmcblk0p2): re-mounted 1a64b592-aa5f-414f-9644-5e7e70d5bbe7 r/w. Quota mode: none.
[    2.704721] random: crng init done
Starting klogd: OK
Running sysctl: OK
Starting mdev... OK
[    4.331087] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    4.337318] omap-aes 53500000.aes: will run requests pump with realtime priority
[    4.367283] at24 2-0054: supply vcc not found, using dummy regulator
[    4.405606] at24 2-0055: supply vcc not found, using dummy regulator
[    4.444427] at24 2-0056: supply vcc not found, using dummy regulator
[    4.487674] at24 2-0057: supply vcc not found, using dummy regulator
[    4.527859] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    4.562697] remoteproc remoteproc0: wkup_m3 is available
[    4.904243] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    5.192062] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    5.199667] input: tps65217_pwrbutton as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    5.269387] omap_rng 48310000.rng: Random Number Generator ver. 20
[    5.302779] omap_rtc 44e3e000.rtc: already running
[    5.327846] omap_rtc 44e3e000.rtc: registered as rtc0
[    5.333153] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:04:40 UTC (946685080)
[    5.374837] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    5.401288] omap-sham 53100000.sham: will run requests pump with realtime priority
[    5.613439] tda998x 0-0070: found TDA19988
[    5.633141] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops [tda998x])
[    5.652539] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    5.661581] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[    5.670180] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[    5.729627] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[    5.762550] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[    5.879718] usbcore: registered new interface driver usbfs
[    5.885489] usbcore: registered new interface driver hub
[    5.891006] usbcore: registered new device driver usb
[    6.005825] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    6.011435] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    6.051502] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    6.059889] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.067250] usb usb1: Product: MUSB HDRC host driver
[    6.072268] usb usb1: Manufacturer: Linux 6.6.0-rc3 musb-hcd
[    6.077956] usb usb1: SerialNumber: musb-hdrc.1
[    6.097031] hub 1-0:1.0: USB hub found
[    6.111121] hub 1-0:1.0: 1 port detected
[    6.170361] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    6.213994] remoteproc remoteproc0: powering up wkup_m3
[    6.219455] remoteproc remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2
[    6.229196] remoteproc remoteproc0: request_firmware failed: -2
[    6.235205] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed
[    6.264467] PM: Cannot get wkup_m3_ipc handle
Starting network: [    6.470997] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac
[    6.572275] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
OK
# ifconfig
Thanks & Regards
Vivek Yadav
systemctl status bb-usb-gadgets.service
-sh: systemctl: not found
Regards
So without systemd, and thus without After=usb-gadget.target you get to deal with race conditions on startup…
so just run:
after startup…
