I am performing some source code tasks and I wanted to be able to track things via USB Camera.
What is holding me back?
Maestro hardware serial interface established.
[ WARN:0@1.304] global cap_gstreamer.cpp:1777 open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
Configuring hardware profiles...
Computer Vision Targeting Loop Active. Press 'q' in video frame to exit.
Client is not authorized to connect to Server
qt.qpa.xcb: could not connect to display :1
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized.
Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen,
vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Aborted
It seems I cannot initialize a QT plugin for whatever reason. Also, it seems client cannot connect to server. I am not sure why exactly this is the case so far.
