I am working on BB for the past couple of days. I am trying to boot
the BB with Angstrom 2009.X-stable version from the link
http://www.angstrom-distribution.org/demo/beagleboard/.
The boot screen comes up perfectly with the Angstrom logo and screen
for entering username and password in DVI monitor. I have connected a
USB HS compliant hub (http://www.rosewill.com/products/s_1289/
productDetail.htm) that is self powered to the C4 Rev of BB's USB Host
connector P7. But for some reason the USB hub and hence the keyboard
and mouse connected to the hub do not get enumerated.
I am attaching the log file in the serial session during booting for
your reference. I have been working on this particular issue for the
past 36 hours with no success. Please help me resolve this.
U-Boot 2009.11-rc1 (Jan 08 2010 - 21:19:52)
OMAP3530-GP ES3.1, CPU-OPP2 L3-165MHz
I2C: ready
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision C4
Die ID #64e8000400000000040365fa17019008
Hit any key to stop autoboot: 10 9 8 7 6 5 4 3 2 1 0
mmc1 is available
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage
2996196 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Angstrom/2.6.29/beagleboard
Data Size: 2996132 Bytes = 2.9 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux..................................................................................................................................................................................................
done, booting the kernel.
[ 0.000000] Linux version 2.6.29-omap1 (koen@dominion) (gcc version
4.3.3 (GCC) ) #1 PREEMPT Wed Oct 21 13:11:52 CEST 2009
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES3.1
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 vram=12M
omapfb.mode=dvi:1024x768MR-16@60 omapfb.debug=y omapdss.def_disp=dvi
root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/720 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 240896KB available (5632K code, 576K data, 204K
init)
[ 0.000000] Calibrating delay loop... 734.17 BogoMIPS (lpj=2867200)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] GPIO-156 autorequested
[ 0.000000] GPIO-159 autorequested
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 17.953918] OMAP DMA hardware revision 4.0
[ 17.987213] bio: create slab <bio-0> at 0
[ 18.046752] OMAP DSS rev 2.0
[ 18.046844] OMAP DISPC rev 3.0
[ 18.046875] OMAP VENC rev 2
[ 18.046997] OMAP DSI rev 1.0
[ 18.049316] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 18.052581] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 18.052612] twl4030: power (irq 373) chaining IRQs 376..383
[ 18.053070] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 18.055480] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 18.056213] regulator: VDAC: 1800 mV normal standby
[ 18.056915] regulator: VUSB1V5: 1500 <--> 0 mV normal standby
[ 18.057617] regulator: VUSB1V8: 1800 <--> 0 mV normal standby
[ 18.058319] regulator: VUSB3V1: 3100 <--> 0 mV normal standby
[ 18.059020] regulator: VPLL2: 1800 mV normal standby
[ 18.059722] regulator: VMMC2: 2800 <--> 3150 mV normal standby
[ 18.060485] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 18.060638] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 18.070739] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 18.072570] SCSI subsystem initialized
[ 18.075469] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 18.076751] usbcore: registered new interface driver usbfs
[ 18.077209] usbcore: registered new interface driver hub
[ 18.077545] usbcore: registered new device driver usb
[ 18.080047] Bluetooth: Core ver 2.14
[ 18.080474] NET: Registered protocol family 31
[ 18.080474] Bluetooth: HCI device and connection manager
initialized
[ 18.080505] Bluetooth: HCI socket layer initialized
[ 18.081054] cfg80211: Using static regulatory domain info
[ 18.081085] cfg80211: Regulatory domain: US
[ 18.081085] (start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp)
[ 18.081115] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi,
2700 mBm)
[ 18.081115] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 18.081146] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 18.081146] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 18.081176] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 18.081176] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi,
3000 mBm)
[ 18.081207] cfg80211: Calling CRDA for country: US
[ 18.083953] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 18.086151] musb_hdrc: USB OTG mode controller at d80ab000 using
DMA, IRQ 92
[ 18.087341] NET: Registered protocol family 2
[ 18.087524] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 18.088043] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 18.088226] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 18.088317] TCP: Hash tables configured (established 8192 bind
8192)
[ 18.088348] TCP reno registered
[ 18.088531] NET: Registered protocol family 1
[ 18.091796] VFS: Disk quotas dquot_6.5.2
[ 18.091888] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 18.092346] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 18.092895] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 18.093627] msgmni has been set to 470
[ 18.097412] alg: No test for stdrng (krng)
[ 18.097473] io scheduler noop registered
[ 18.097503] io scheduler anticipatory registered
[ 18.097503] io scheduler deadline registered
[ 18.097686] io scheduler cfq registered (default)
[ 18.117279] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 18.139892] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 18.161071] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 18.182342] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 18.182373] console [ttyS2] enabled
[ 18.710662] brd: module loaded
[ 18.718597] loop: module loaded
[ 18.722381] enc28j60 spi4.0: enc28j60 Ethernet driver 1.01 loaded
[ 18.731018] enc28j60 spi4.0: enc28j60 chip not found
[ 18.736175] enc28j60: probe of spi4.0 failed with error -5
[ 18.742614] usbcore: registered new interface driver catc
[ 18.748077] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 18.754302] usbcore: registered new interface driver kaweth
[ 18.759979] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 18.767761] usbcore: registered new interface driver pegasus
[ 18.773468] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 18.780609] usbcore: registered new interface driver rtl8150
[ 18.786560] usbcore: registered new interface driver asix
[ 18.792205] usbcore: registered new interface driver cdc_ether
[ 18.798339] usbcore: registered new interface driver dm9601
[ 18.804168] usbcore: registered new interface driver smsc95xx
[ 18.810211] usbcore: registered new interface driver gl620a
[ 18.816070] usbcore: registered new interface driver net1080
[ 18.822021] usbcore: registered new interface driver plusb
[ 18.827758] usbcore: registered new interface driver rndis_host
[ 18.833984] usbcore: registered new interface driver cdc_subset
[ 18.840179] usbcore: registered new interface driver zaurus
[ 18.846038] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 18.853759] Broadcom 43xx driver loaded [ Features: L, Firmware-ID:
FW13 ]
[ 18.861083] usbcore: registered new interface driver zd1211rw
[ 18.867065] usbcore: registered new interface driver rtl8187
[ 18.873046] usbcore: registered new interface driver rndis_wlan
[ 18.879272] usbcore: registered new interface driver zd1201
[ 18.885162] usbcore: registered new interface driver usb8xxx
[ 18.891082] usbcore: registered new interface driver rt2500usb
[ 18.897277] usbcore: registered new interface driver rt73usb
[ 18.903228] usbcore: registered new interface driver p54usb
[ 18.908874] i2c /dev entries driver
[ 18.913879] Driver 'sd' needs updating - please use bus_type
methods
[ 18.920532] Driver 'sr' needs updating - please use bus_type
methods
[ 18.927856] omap2-nand driver initializing
[ 18.932281] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 18.941314] cmdlinepart partition parsing not available
[ 18.946624] Creating 5 MTD partitions on "omap2-nand":
[ 18.951782] 0x000000000000-0x000000080000 : "X-Loader"
[ 18.958679] 0x000000080000-0x000000260000 : "U-Boot"
[ 18.965545] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 18.972045] 0x000000280000-0x000000680000 : "Kernel"
[ 18.979736] 0x000000680000-0x000010000000 : "File System"
[ 19.094665] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 19.101531] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 19.108062] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 19.115844] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 19.133666] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 19.140075] usb usb1: configuration #1 chosen from 1 choice
[ 19.146057] hub 1-0:1.0: USB hub found
[ 19.149932] hub 1-0:1.0: 3 ports detected
[ 19.155670] Initializing USB Mass Storage driver...
[ 19.160980] usbcore: registered new interface driver usb-storage
[ 19.167083] USB Mass Storage support registered.
[ 19.172271] mice: PS/2 mouse device common for all mice
[ 19.178070] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 19.186981] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-adapter/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 19.478271] hub 1-0:1.0: unable to enumerate USB device on port 2
[ 20.202423] i2c_omap i2c_omap.2: controller timed out
[ 20.207550] rtc-ds1307: probe of 2-0068 failed with error -5
[ 20.214843] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 20.221191] Bluetooth: HCI UART driver ver 2.2
[ 20.225646] Bluetooth: HCI H4 protocol initialized
[ 20.230499] Bluetooth: HCI BCSP protocol initialized
[ 20.235565] Bluetooth: HCILL protocol initialized
[ 20.240295] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 20.246704] usbcore: registered new interface driver bcm203x
[ 20.252471] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 20.258697] usbcore: registered new interface driver bpa10x
[ 20.264312] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 20.269561] usbcore: registered new interface driver bfusb
[ 20.275115] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 20.280975] usbcore: registered new interface driver btusb
[ 20.286529] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 20.293151] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce
clock
[ 20.407196] mmci-omap-hs mmci-omap-hs.1: Failed to get debounce
clock
[ 20.413726] regulator: Unable to get requested regulator: vmmc_aux
[ 20.422302] Registered led device: beagleboard::usr0
[ 20.427612] Registered led device: beagleboard::usr1
[ 20.438049] usbcore: registered new interface driver usbhid
[ 20.443786] usbhid: v2.6:USB HID core driver
[ 20.449096] Advanced Linux Sound Architecture Driver Version
1.0.18a.
[ 20.456329] usbcore: registered new interface driver snd-usb-audio
[ 20.462921] No device for DAI twl4030
[ 20.466583] No device for DAI omap-mcbsp-dai-0
[ 20.471099] No device for DAI omap-mcbsp-dai-1
[ 20.475585] No device for DAI omap-mcbsp-dai-2
[ 20.480194] No device for DAI omap-mcbsp-dai-3
[ 20.484649] No device for DAI omap-mcbsp-dai-4
[ 20.489227] OMAP3 Beagle SoC init
[ 20.493041] TWL4030 Audio Codec init
[ 20.497802] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 20.511962] ALSA device list:
[ 20.514953] #0: omap3beagle (twl4030)
[ 20.519287] oprofile: using arm/armv7
[ 20.523162] TCP cubic registered
[ 20.526489] NET: Registered protocol family 17
[ 20.531005] NET: Registered protocol family 15
[ 20.535552] Bluetooth: L2CAP ver 2.11
[ 20.539245] Bluetooth: L2CAP socket layer initialized
[ 20.544372] Bluetooth: SCO (Voice Link) ver 0.6
[ 20.548950] Bluetooth: SCO socket layer initialized
[ 20.559570] Bluetooth: RFCOMM socket layer initialized
[ 20.564880] Bluetooth: RFCOMM TTY layer initialized
[ 20.569793] Bluetooth: RFCOMM ver 1.10
[ 20.573577] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.578948] Bluetooth: BNEP filters: protocol multicast
[ 20.584197] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 20.593261] RPC: Registered udp transport module.
[ 20.598052] RPC: Registered tcp transport module.
[ 20.602905] lib80211: common routines for IEEE802.11 drivers
[ 20.608673] ThumbEE CPU extension supported.
[ 20.613006] Power Management for TI OMAP3.
[ 20.623748] Disabling unused clock "sr2_fck"
[ 20.628143] Disabling unused clock "sr1_fck"
[ 20.632446] Disabling unused clock "mcbsp_fck"
[ 20.636932] Disabling unused clock "mcbsp_fck"
[ 20.641448] Disabling unused clock "mcbsp_fck"
[ 20.645904] Disabling unused clock "mcbsp_ick"
[ 20.650390] Disabling unused clock "mcbsp_ick"
[ 20.654876] Disabling unused clock "mcbsp_ick"
[ 20.659362] Disabling unused clock "gpt2_ick"
[ 20.663757] Disabling unused clock "gpt3_ick"
[ 20.668151] Disabling unused clock "gpt4_ick"
[ 20.672546] Disabling unused clock "gpt5_ick"
[ 20.676940] Disabling unused clock "gpt6_ick"
[ 20.681335] Disabling unused clock "gpt7_ick"
[ 20.685729] Disabling unused clock "gpt8_ick"
[ 20.690124] Disabling unused clock "gpt9_ick"
[ 20.694519] Disabling unused clock "wdt3_ick"
[ 20.698913] Disabling unused clock "wdt3_fck"
[ 20.703308] Disabling unused clock "gpio2_dbck"
[ 20.707885] Disabling unused clock "gpio3_dbck"
[ 20.712463] Disabling unused clock "gpio4_dbck"
[ 20.717010] Disabling unused clock "gpio5_dbck"
[ 20.721588] Disabling unused clock "gpio6_dbck"
[ 20.726165] Disabling unused clock "gpt9_fck"
[ 20.730560] Disabling unused clock "gpt8_fck"
[ 20.734924] Disabling unused clock "gpt7_fck"
[ 20.739349] Disabling unused clock "gpt6_fck"
[ 20.743743] Disabling unused clock "gpt5_fck"
[ 20.748138] Disabling unused clock "gpt4_fck"
[ 20.752532] Disabling unused clock "gpt3_fck"
[ 20.756927] Disabling unused clock "gpt2_fck"
[ 20.761322] Disabling unused clock "gpt1_ick"
[ 20.765716] Disabling unused clock "wdt1_ick"
[ 20.770111] Disabling unused clock "wdt2_ick"
[ 20.774505] Disabling unused clock "wdt2_fck"
[ 20.778900] Disabling unused clock "gpio1_dbck"
[ 20.783477] Disabling unused clock "gpt1_fck"
[ 20.787872] Disabling unused clock "cam_ick"
[ 20.792205] Disabling unused clock "cam_mclk"
[ 20.796600] Disabling unused clock "des1_ick"
[ 20.801025] Disabling unused clock "sha11_ick"
[ 20.805511] Disabling unused clock "rng_ick"
[ 20.809783] Disabling unused clock "aes1_ick"
[ 20.814208] Disabling unused clock "ssi_ick"
[ 20.818511] Disabling unused clock "mailboxes_ick"
[ 20.823333] Disabling unused clock "mcbsp_ick"
[ 20.827819] Disabling unused clock "mcbsp_ick"
[ 20.832305] Disabling unused clock "gpt10_ick"
[ 20.836791] Disabling unused clock "gpt11_ick"
[ 20.841278] Disabling unused clock "hdq_ick"
[ 20.845581] Disabling unused clock "mspro_ick"
[ 20.850067] Disabling unused clock "des2_ick"
[ 20.854461] Disabling unused clock "sha12_ick"
[ 20.858917] Disabling unused clock "aes2_ick"
[ 20.863342] Disabling unused clock "icr_ick"
[ 20.867614] Disabling unused clock "pka_ick"
[ 20.871948] Disabling unused clock "ssi_ssr_fck"
[ 20.876617] Disabling unused clock "hdq_fck"
[ 20.880920] Disabling unused clock "mcbsp_fck"
[ 20.885406] Disabling unused clock "mcbsp_fck"
[ 20.889862] Disabling unused clock "mspro_fck"
[ 20.894378] Disabling unused clock "gpt11_fck"
[ 20.898834] Disabling unused clock "gpt10_fck"
[ 20.903320] Disabling unused clock "dpll4_m6x2_ck"
[ 20.908172] Disabling unused clock "dpll3_m3x2_ck"
[ 20.912994] Disabling unused clock "sys_clkout1"
[ 20.917694] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 20.931030] registered taskstats version 1
[ 20.936309] fbcvt: 1024x768@60: CVT Name - .786M3-R
[ 20.962768] Console: switching to colour frame buffer device 128x48
[ 20.979461] clock: clksel_round_rate_div: dpll4_m4_ck target_rate
48000000
[ 20.986358] clock: new_div = 9, new_rate = 48000000
[ 20.993927] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 21.000579] Waiting for root device /dev/mmcblk0p2...
[ 21.024444] mmc0: new high speed SDHC card at address 0001
[ 21.030548] mmcblk0: mmc0:0001 00000 7.60 GiB
[ 21.035339] mmcblk0: p1 p2
[ 25.849914] kjournald starting. Commit interval 5 seconds
[ 26.065948] EXT3 FS on mmcblk0p2, internal journal
[ 26.070770] EXT3-fs: recovery complete.
[ 26.076873] EXT3-fs: mounted filesystem with ordered data mode.
[ 26.082916] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 26.089111] Freeing init memory: 204K
INIT: version 2.86 bootingStarting udev[ 32.186798] uncorrectable
error : <3>end_request: I/O error, dev mtdblock0, sector 0
[ 32.194732] Buffer I/O error on device mtdblock0, logical block 0
[ 32.427612] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 8
[ 32.435516] Buffer I/O error on device mtdblock0, logical block 1
[ 32.548431] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 16
[ 32.556365] Buffer I/O error on device mtdblock0, logical block 2
[ 32.668792] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 24
[ 32.676696] Buffer I/O error on device mtdblock0, logical block 3
[ 32.748016] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 0
[ 32.755950] Buffer I/O error on device mtdblock0, logical block 0
[ 34.155792] FAT: IO charset iso8859-1 not found
and populating dev cache
Remounting root file system...
[ 38.077453] ipv6: disagrees about version of symbol struct_module
[ 38.110900] irda: disagrees about version of symbol struct_module
[ 38.121246] ircomm: disagrees about version of symbol struct_module
[ 38.132873] ircomm_tty: disagrees about version of symbol
struct_module
Unknown HZ value! (54) Assume 100.
ALSA: Restoring mixer settings...
Configuring network interfaces... eth0: unknown interface: No such
device
eth0: unknown interface: No such device
eth0 No such device
done.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
hwclock: can't open '/dev/misc/rtc': No such file or directory
Fri Jun 12 13:04:00 BST 2009
INIT: Entering runlevel: 5Configuring leds:
beagleboard::usr0: heartbeat
beagleboard::usr1: mmc0
Starting Dropbear SSH server: [ 40.569519] ipv6: disagrees about
modprobe: FATAL: Error inserting ipv6 (/lib/modules/2.6.29-omap1/
kernel/net/ipv6/ipv6.ko): Invalid module format
[ 40.653564] ipv6: disagrees about version of symbol struct_module
dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Connection Manager
Running ntpdate to synchronize clock[ 42.217193] ipv6: disagrees
Error : Temporary failure in name resolution
Starting GPE display manager: gpe-dm
[ 42.543762] ipv6: disagrees about version of symbol struct_module
[ 42.667572] ipv6: disagrees about version of symbol struct_module
[ 42.765686] ipv6: disagrees about version of symbol struct_module
[ 42.855804] ipv6: disagrees about version of symbol struct_module
> > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2009.X-stable beagleboard ttyS2
beagleboard login:
Ramasamy Gopalan
