I have a PoocketBeagle with the latest image (bone-debian-9.2-iot-armhf-2017-10-10-4gb) connected to a Debian Sid machine.
Used to be when I plugged the board in, I would see a storage device, and an Ethernet adapter (eth1, IIRC). The Ethernet adapter would automatically get in IP address, and everything would work as advertised.
I recently had a power outage, and things don’t work so well anymore: I now see two Ethernet adapters, and neither one gets an IP address.
The /var/log/messages on the PC contains the following right after I plug the PocketBeagle in:
Nov 15 23:58:46 skaia kernel: [823653.997487] usb 5-4: new high-speed USB device number 7 using ehci-pci
Nov 15 23:58:46 skaia kernel: [823654.150574] usb 5-4: New USB device found, idVendor=1d6b, idProduct=0104
Nov 15 23:58:46 skaia kernel: [823654.150593] usb 5-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 15 23:58:46 skaia kernel: [823654.150594] usb 5-4: Product: BeagleBone
Nov 15 23:58:46 skaia kernel: [823654.150596] usb 5-4: Manufacturer: BeagleBoard.org
Nov 15 23:58:46 skaia kernel: [823654.150597] usb 5-4: SerialNumber: 1741GPB4
Nov 15 23:58:46 skaia kernel: [823654.152778] rndis_host 5-4:1.0 eth1: register ‘rndis_host’ at usb-0000:00:16.2-4, RNDIS device, 60:64:05:e0:d9:ce
Nov 15 23:58:46 skaia kernel: [823654.153625] cdc_ether 5-4:1.2 eth2: register ‘cdc_ether’ at usb-0000:00:16.2-4, CDC Ethernet Device, 60:64:05:e0:d9:d1
Nov 15 23:58:46 skaia kernel: [823654.154411] cdc_acm 5-4:1.4: ttyACM0: USB ACM device
Nov 15 23:58:46 skaia kernel: [823654.155107] usb-storage 5-4:1.6: USB Mass Storage device detected
Nov 15 23:58:46 skaia kernel: [823654.156185] scsi host6: usb-storage 5-4:1.6
Nov 15 23:58:46 skaia mtp-probe: checking bus 5, device 7: “/sys/devices/pci0000:00/0000:00:16.2/usb5/5-4”
Nov 15 23:58:46 skaia mtp-probe: bus: 5, device: 7 was not an MTP device
Nov 15 23:58:46 skaia kernel: [823654.885248] rndis_host 5-4:1.0 enx606405e0d9ce: renamed from eth1
Nov 15 23:58:46 skaia kernel: [823654.897678] cdc_ether 5-4:1.2 enx606405e0d9d1: renamed from eth2
Nov 15 23:58:47 skaia kernel: [823655.166381] scsi 6:0:0:0: Direct-Access Linux File-Stor Gadget 0404 PQ: 0 ANSI: 2
Nov 15 23:58:47 skaia kernel: [823655.166870] sd 6:0:0:0: Attached scsi generic sg3 type 0
Nov 15 23:58:47 skaia kernel: [823655.171354] sd 6:0:0:0: [sdc] 36864 512-byte logical blocks: (18.9 MB/18.0 MiB)
Nov 15 23:58:47 skaia kernel: [823655.171995] sd 6:0:0:0: [sdc] Write Protect is on
Nov 15 23:58:47 skaia kernel: [823655.172609] sd 6:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
Nov 15 23:58:47 skaia kernel: [823655.184365] sdc: sdc1
Nov 15 23:58:47 skaia kernel: [823655.187738] sd 6:0:0:0: [sdc] Attached SCSI removable disk
Nov 15 23:58:53 skaia kernel: [823661.155219] TCP: request_sock_TCP: Possible SYN flooding on port 46319. Sending cookies. Check SNMP counters
The serial device (ttyACM0) and the mass storage device (sdc) work as expected.
I realize this is probably not much, but can anybody help me out here?
–Juergen
