I build my own images and kernel because I am doing kernel driver work on the Fire. I encountered an error using top of tree. I apologize that I have not had time to delve into the root cause, but I am enveloped by my own debug currently.
commit a2bbfafeda15453cfc1b93973defa528446a357b (HEAD → main, origin/main, origin/HEAD)
Merge: 265db70 95f4401
Author: Robert Nelson robertcnelson@beagleboard.org
Date: Fri Jun 13 12:09:43 2025 -0400
./01_git_sync.sh
./02_build_hss.sh
./03_build_u-boot.sh
./04_build_linux.sh
./05_generate_payload.bin.sh
sudo ./06_generate_ubuntu_console_root.sh
sudo ./07_create_sdcard_img.sh
sudo bmaptool copy --bmap ~/beaglev/deploy/images/sdcard.bmap ~/beaglev/deploy/images/sdcard.img /dev/sda && sudo sync
Rebooting after the flash produces this error:
[FAILED] Failed to start bb-usb-gadgets.service - BeagleBoard.org USB gadgets.
See ‘systemctl status bb-usb-gadgets.service’ for details.
systemctl status bb-usb-gadgets.service >gadget.txt
beagle@BeagleV:~$ cat gadget.txt
× bb-usb-gadgets.service - BeagleBoard.org USB gadgets
Loaded: loaded (/usr/lib/systemd/system/bb-usb-gadgets.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sat 2025-06-14 06:39:50 UTC; 1min 21s ago
CPU: 364ms
Jun 14 06:39:49 BeagleV systemd[1]: Starting bb-usb-gadgets.service - BeagleBoard.org USB gadgets…
Jun 14 06:39:50 BeagleV bb-start-usb-gadgets[354]: bb-usb-gadgets: bb-start-acm-ncm-rndis-old-gadget
Jun 14 06:39:50 BeagleV bb-start-usb-gadgets[365]: usb_gadget: Looking for libcomposite
Jun 14 06:39:50 BeagleV bb-start-usb-gadgets[365]: usb_gadget: Creating g_multi
Jun 14 06:39:50 BeagleV bb-start-usb-gadgets[365]: /usr/bin/bb-start-acm-ncm-rndis-old-gadget: 128: echo: echo: I/O error
Jun 14 06:39:50 BeagleV systemd[1]: bb-usb-gadgets.service: Control process exited, code=exited, status=1/FAILURE
Jun 14 06:39:50 BeagleV systemd[1]: bb-usb-gadgets.service: Failed with result ‘exit-code’.
Jun 14 06:39:50 BeagleV systemd[1]: Failed to start bb-usb-gadgets.service - BeagleBoard.org USB gadgets.
I can confirm that this commit is working fine:
commit efff7c9f57fdd63f8cd21f9500141427a9b0af3a (HEAD → corei2c)
Author: Robert Nelson robertcnelson@gmail.com
Date: Fri May 30 08:39:00 2025 -0500
Thank you,
Justin
