i have usb-otg slot on my development board with omap3530;;
i used that slot to connect it to a usb mass storage..
i get some info like this while booting
usb 2-1: new full speed USB device using musb_hdrc and address 3
but i cannot see it in media. nor can i mount it anywhere..
what could be the problem..
please help me out.. someone..
Check whether the device is listed in /dev/sd where x may be a or b.
most propably the first disk will be detected as /dev/sda.
If so listed then mount it using the following commands
mkdir mnt
mount -t vfat /dev/sda mnt/
- If the file system is fat32
cd mnt/
ls
The contents of the mass storage device will be listed.
yeah, i know the following procedure..
But, the main problem is there is no device as sd<a/b> in /dev/
What could have gone wrong??
drivers ?
Thank You..
