Hi.. I'm new here so first of all I wish to say a big "hello" the the
community.
Now .. to the problem..
I recently bought a Beagleboard rev C4 and all seems to works... exept
HDMI (I don't have the adapter to test)
USB host (not the OTG).
I can boot the BB from SD (2Gb kingstone) without problem (I've
installed the Angstrom),
but when i insert a usb periferal i cant see it...
lsusb only show the two linux hub, but no usb pendrive or external
hub... is this an hardware problem or are there
software solutions??
Thanks for the help!
The HOST port is High Speed only. If you want to connect a low or full speed device, like a keyboard or a mouse, you must connect through a USB HUB. On the OTG port, you must ground the ID pin, either by using a 5 pin cable that has the ID pin grounded, or shorting the ID pin by using the shorting pad on the back of the board.
Thanks for the reply ![]()
I tried using external hub with power supply but i can't get the BB to
recognise the external hardware.
BB can't recognise neither the hub...
here is the log of the boot procedure:
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.01-dirty (Feb 19 2009 - 12:23:21)
I2C: ready
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
Using default environment
MUSB: using high speed
In: serial usbtty
Out: serial usbtty
Err: serial usbtty
Board revision Ax/Bx
Serial #7ea4000400000000040373051401500e
reading boot.scr
603 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
reading uImage.bin
2996196 bytes read
***** Kernel: /dev/mmcblk0p1/uImage.bin *****
reading ramdisk.gz
** Unable to read "ramdisk.gz" from mmc 0:1 **
***** RootFS: /dev/mmcblk0p2 *****
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Angstrom/2.6.29/beagleboard
Data Size: 2996132 Bytes = 2.9 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux..........................................................................................................................................................
[ 0.000000] Linux version 2.6.29-omap1 (koen@dominion) (gcc version
4.3.3 (GCC) ) #1 PREEMPT Wed Oct 21 13:11:52 CEST 2009
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES3.1
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size:
0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8
console=tty0 root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 238848KB available (5632K code, 576K data, 204K
init)
[ 0.000000] Calibrating delay loop... 497.82 BogoMIPS (lpj=1941504)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] GPIO-156 autorequested
[ 0.000000] GPIO-159 autorequested
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 22.546813] OMAP DMA hardware revision 4.0
[ 22.592926] bio: create slab <bio-0> at 0
[ 22.652832] OMAP DSS rev 2.0
[ 22.652984] OMAP DISPC rev 3.0
[ 22.653015] OMAP VENC rev 2
[ 22.653198] OMAP DSI rev 1.0
[ 22.668365] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 22.672485] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 22.672546] twl4030: power (irq 373) chaining IRQs 376..383
[ 22.673187] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 22.676483] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 22.677490] regulator: VDAC: 1800 mV normal standby
[ 22.678497] regulator: VUSB1V5: 1500 <--> 0 mV normal standby
[ 22.679443] regulator: VUSB1V8: 1800 <--> 0 mV normal standby
[ 22.680419] regulator: VUSB3V1: 3100 <--> 0 mV normal standby
[ 22.681396] regulator: VPLL2: 1800 mV normal standby
[ 22.682403] regulator: VMMC2: 2800 <--> 3150 mV normal standby
[ 22.683380] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 22.683624] i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz
[ 22.699462] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 22.701660] SCSI subsystem initialized
[ 22.707763] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 22.709411] usbcore: registered new interface driver usbfs
[ 22.710083] usbcore: registered new interface driver hub
[ 22.710571] usbcore: registered new device driver usb
[ 22.713897] Bluetooth: Core ver 2.14
[ 22.714508] NET: Registered protocol family 31
[ 22.714538] Bluetooth: HCI device and connection manager
initialized
[ 22.714599] Bluetooth: HCI socket layer initialized
[ 22.715484] cfg80211: Using static regulatory domain info
[ 22.715515] cfg80211: Regulatory domain: US
[ 22.715576] (start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp)
[ 22.715637] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi,
2700 mBm)
[ 22.715667] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 22.715728] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 22.715789] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 22.715820] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 22.715881] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi,
3000 mBm)
[ 22.715942] cfg80211: Calling CRDA for country: US
[ 22.719726] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 22.720520] musb_hdrc: USB OTG mode controller at d80ab000 using
DMA, IRQ 92
[ 22.721832] NET: Registered protocol family 2
[ 22.722167] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 22.723297] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 22.723602] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 22.723754] TCP: Hash tables configured (established 8192 bind
8192)
[ 22.723815] TCP reno registered
[ 22.724121] NET: Registered protocol family 1
[ 22.728546] VFS: Disk quotas dquot_6.5.2
[ 22.728698] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 22.729370] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 22.730224] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red
Hat, Inc.
[ 22.731384] msgmni has been set to 466
[ 22.736328] alg: No test for stdrng (krng)
[ 22.736480] io scheduler noop registered
[ 22.736511] io scheduler anticipatory registered
[ 22.736572] io scheduler deadline registered
[ 22.736816] io scheduler cfq registered (default)
[ 22.763031] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 22.785919] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 22.807830] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 22.828857] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 22.828948] console [ttyS2] enabled
[ 23.347564] musb_hdrc: peripheral reset irq lost!
[ 23.364929] brd: module loaded
[ 23.374664] loop: module loaded
[ 23.378601] enc28j60 spi4.0: enc28j60 Ethernet driver 1.01 loaded
[ 23.387908] enc28j60 spi4.0: enc28j60 chip not found
[ 23.392974] enc28j60: probe of spi4.0 failed with error -5
[ 23.399261] usbcore: registered new interface driver catc
[ 23.404846] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 23.411163] usbcore: registered new interface driver kaweth
[ 23.416839] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 23.424743] usbcore: registered new interface driver pegasus
[ 23.430541] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 23.437805] usbcore: registered new interface driver rtl8150
[ 23.443878] usbcore: registered new interface driver asix
[ 23.449707] usbcore: registered new interface driver cdc_ether
[ 23.455932] usbcore: registered new interface driver dm9601
[ 23.461914] usbcore: registered new interface driver smsc95xx
[ 23.468109] usbcore: registered new interface driver gl620a
[ 23.474090] usbcore: registered new interface driver net1080
[ 23.480133] usbcore: registered new interface driver plusb
[ 23.486053] usbcore: registered new interface driver rndis_host
[ 23.492401] usbcore: registered new interface driver cdc_subset
[ 23.498748] usbcore: registered new interface driver zaurus
[ 23.504730] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 23.512634] Broadcom 43xx driver loaded [ Features: L, Firmware-ID:
FW13 ]
[ 23.520080] usbcore: registered new interface driver zd1211rw
[ 23.526214] usbcore: registered new interface driver rtl8187
[ 23.532409] usbcore: registered new interface driver rndis_wlan
[ 23.538818] usbcore: registered new interface driver zd1201
[ 23.544891] usbcore: registered new interface driver usb8xxx
[ 23.550994] usbcore: registered new interface driver rt2500usb
[ 23.557250] usbcore: registered new interface driver rt73usb
[ 23.563385] usbcore: registered new interface driver p54usb
[ 23.569061] i2c /dev entries driver
[ 23.574737] Driver 'sd' needs updating - please use bus_type
methods
[ 23.581451] Driver 'sr' needs updating - please use bus_type
methods
[ 23.589080] omap2-nand driver initializing
[ 23.593627] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 23.602752] cmdlinepart partition parsing not available
[ 23.608093] Creating 5 MTD partitions on "omap2-nand":
[ 23.613311] 0x000000000000-0x000000080000 : "X-Loader"
[ 23.620819] 0x000000080000-0x000000260000 : "U-Boot"
[ 23.628112] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 23.635040] 0x000000280000-0x000000680000 : "Kernel"
[ 23.643188] 0x000000680000-0x000010000000 : "File System"
[ 23.758483] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 23.765502] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 23.772338] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 23.780242] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 23.800994] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 23.807647] usb usb1: configuration #1 chosen from 1 choice
[ 23.813842] hub 1-0:1.0: USB hub found
[ 23.817779] hub 1-0:1.0: 3 ports detected
[ 23.824157] Initializing USB Mass Storage driver...
[ 23.829620] usbcore: registered new interface driver usb-storage
[ 23.835784] USB Mass Storage support registered.
[ 23.841278] mice: PS/2 mouse device common for all mice
[ 23.847259] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 23.856994] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-adapter/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 24.863555] i2c_omap i2c_omap.2: controller timed out
[ 24.868713] rtc-ds1307: probe of 2-0068 failed with error -5
[ 24.876495] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 24.882965] Bluetooth: HCI UART driver ver 2.2
[ 24.887512] Bluetooth: HCI H4 protocol initialized
[ 24.892364] Bluetooth: HCI BCSP protocol initialized
[ 24.897460] Bluetooth: HCILL protocol initialized
[ 24.902221] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 24.908782] usbcore: registered new interface driver bcm203x
[ 24.914581] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 24.920928] usbcore: registered new interface driver bpa10x
[ 24.926635] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 24.931976] usbcore: registered new interface driver bfusb
[ 24.937591] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 24.943603] usbcore: registered new interface driver btusb
[ 24.949188] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 24.956176] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce
clock
[ 25.066741] mmci-omap-hs mmci-omap-hs.1: Failed to get debounce
clock
[ 25.073394] regulator: Unable to get requested regulator: vmmc_aux
[ 25.082641] Registered led device: beagleboard::usr0
[ 25.088012] Registered led device: beagleboard::usr1
[ 25.100555] usbcore: registered new interface driver usbhid
[ 25.106292] usbhid: v2.6:USB HID core driver
[ 25.111907] Advanced Linux Sound Architecture Driver Version
1.0.18a.
[ 25.119476] usbcore: registered new interface driver snd-usb-audio
[ 25.126190] No device for DAI twl4030
[ 25.130096] No device for DAI omap-mcbsp-dai-0
[ 25.134613] No device for DAI omap-mcbsp-dai-1
[ 25.139251] No device for DAI omap-mcbsp-dai-2
[ 25.143768] No device for DAI omap-mcbsp-dai-3
[ 25.148284] No device for DAI omap-mcbsp-dai-4
[ 25.152832] OMAP3 Beagle SoC init
[ 25.156677] TWL4030 Audio Codec init
[ 25.162017] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 25.178253] ALSA device list:
[ 25.181274] #0: omap3beagle (twl4030)
[ 25.193634] oprofile: using arm/armv7
[ 25.197631] TCP cubic registered
[ 25.201049] NET: Registered protocol family 17
[ 25.205596] NET: Registered protocol family 15
[ 25.210266] Bluetooth: L2CAP ver 2.11
[ 25.213958] Bluetooth: L2CAP socket layer initialized
[ 25.219146] Bluetooth: SCO (Voice Link) ver 0.6
[ 25.223754] Bluetooth: SCO socket layer initialized
[ 25.228881] Bluetooth: RFCOMM socket layer initialized
[ 25.234191] Bluetooth: RFCOMM TTY layer initialized
[ 25.239227] Bluetooth: RFCOMM ver 1.10
[ 25.243041] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.248443] Bluetooth: BNEP filters: protocol multicast
[ 25.253753] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 25.262359] RPC: Registered udp transport module.
[ 25.267150] RPC: Registered tcp transport module.
[ 25.272064] lib80211: common routines for IEEE802.11 drivers
[ 25.277893] ThumbEE CPU extension supported.
[ 25.282226] Power Management for TI OMAP3.
[ 25.295501] Disabling unused clock "sr2_fck"
[ 25.299865] Disabling unused clock "sr1_fck"
[ 25.304260] Disabling unused clock "mcbsp_fck"
[ 25.308776] Disabling unused clock "mcbsp_fck"
[ 25.313293] Disabling unused clock "mcbsp_fck"
[ 25.317840] Disabling unused clock "mcbsp_ick"
[ 25.322326] Disabling unused clock "mcbsp_ick"
[ 25.326873] Disabling unused clock "mcbsp_ick"
[ 25.331359] Disabling unused clock "gpt2_ick"
[ 25.335815] Disabling unused clock "gpt3_ick"
[ 25.340270] Disabling unused clock "gpt4_ick"
[ 25.344665] Disabling unused clock "gpt5_ick"
[ 25.349121] Disabling unused clock "gpt6_ick"
[ 25.353515] Disabling unused clock "gpt7_ick"
[ 25.357971] Disabling unused clock "gpt8_ick"
[ 25.362365] Disabling unused clock "gpt9_ick"
[ 25.366821] Disabling unused clock "wdt3_ick"
[ 25.371246] Disabling unused clock "wdt3_fck"
[ 25.375701] Disabling unused clock "gpio2_dbck"
[ 25.380310] Disabling unused clock "gpio3_dbck"
[ 25.384887] Disabling unused clock "gpio4_dbck"
[ 25.389526] Disabling unused clock "gpio5_dbck"
[ 25.394104] Disabling unused clock "gpio6_dbck"
[ 25.398712] Disabling unused clock "gpt9_fck"
[ 25.403167] Disabling unused clock "gpt8_fck"
[ 25.407592] Disabling unused clock "gpt7_fck"
[ 25.412048] Disabling unused clock "gpt6_fck"
[ 25.416442] Disabling unused clock "gpt5_fck"
[ 25.420898] Disabling unused clock "gpt4_fck"
[ 25.425292] Disabling unused clock "gpt3_fck"
[ 25.429748] Disabling unused clock "gpt2_fck"
[ 25.434173] Disabling unused clock "gpt1_ick"
[ 25.438598] Disabling unused clock "wdt1_ick"
[ 25.443054] Disabling unused clock "wdt2_ick"
[ 25.447448] Disabling unused clock "wdt2_fck"
[ 25.451904] Disabling unused clock "gpio1_dbck"
[ 25.456481] Disabling unused clock "gpt1_fck"
[ 25.460937] Disabling unused clock "cam_ick"
[ 25.465332] Disabling unused clock "cam_mclk"
[ 25.469757] Disabling unused clock "des1_ick"
[ 25.474212] Disabling unused clock "sha11_ick"
[ 25.478698] Disabling unused clock "rng_ick"
[ 25.483062] Disabling unused clock "aes1_ick"
[ 25.487457] Disabling unused clock "ssi_ick"
[ 25.491821] Disabling unused clock "mailboxes_ick"
[ 25.496704] Disabling unused clock "mcbsp_ick"
[ 25.501220] Disabling unused clock "mcbsp_ick"
[ 25.505737] Disabling unused clock "gpt10_ick"
[ 25.510253] Disabling unused clock "gpt11_ick"
[ 25.514770] Disabling unused clock "hdq_ick"
[ 25.519104] Disabling unused clock "mspro_ick"
[ 25.523620] Disabling unused clock "des2_ick"
[ 25.528076] Disabling unused clock "sha12_ick"
[ 25.532562] Disabling unused clock "aes2_ick"
[ 25.537017] Disabling unused clock "icr_ick"
[ 25.541351] Disabling unused clock "pka_ick"
[ 25.545684] Disabling unused clock "ssi_ssr_fck"
[ 25.550384] Disabling unused clock "hdq_fck"
[ 25.554748] Disabling unused clock "mcbsp_fck"
[ 25.559265] Disabling unused clock "mcbsp_fck"
[ 25.563781] Disabling unused clock "mspro_fck"
[ 25.568298] Disabling unused clock "gpt11_fck"
[ 25.572814] Disabling unused clock "gpt10_fck"
[ 25.577331] Disabling unused clock "dpll4_m6x2_ck"
[ 25.582214] Disabling unused clock "dpll3_m3x2_ck"
[ 25.587097] Disabling unused clock "sys_clkout1"
[ 25.591827] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 25.604125] registered taskstats version 1
[ 25.628204] Console: switching to colour frame buffer device 80x30
[ 25.648010] clock: clksel_round_rate_div: dpll4_m4_ck target_rate
48000000
[ 25.657653] clock: new_div = 9, new_rate = 48000000
[ 25.672241] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 25.682037] Waiting for root device /dev/mmcblk0p2...
[ 26.019866] mmc0: new high speed SD card at address 1234
[ 26.029418] mmcblk0: mmc0:1234 SA02G 1.83 GiB
[ 26.037719] mmcblk0: p1 p2
[ 32.018280] kjournald starting. Commit interval 5 seconds
[ 32.237518] EXT3 FS on mmcblk0p2, internal journal
[ 32.246185] EXT3-fs: recovery complete.
[ 32.258575] EXT3-fs: mounted filesystem with ordered data mode.
[ 32.268646] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 32.279113] Freeing init memory: 204K
[ 33.329406] udevd version 124 started
[ 39.486877] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 0
[ 39.494842] Buffer I/O error on device mtdblock0, logical block 0
[ 39.501251] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 8
[ 39.509094] Buffer I/O error on device mtdblock0, logical block 1
[ 39.518005] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 16
[ 39.782318] Buffer I/O error on device mtdblock0, logical block 2
[ 39.915710] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 24
[ 39.923736] Buffer I/O error on device mtdblock0, logical block 3
[ 39.980957] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 0
[ 39.988800] Buffer I/O error on device mtdblock0, logical block 0
[ 42.731689] ipv6: disagrees about version of symbol struct_module
[ 42.795684] irda: disagrees about version of symbol struct_module
[ 42.808441] ircomm: disagrees about version of symbol struct_module
[ 42.822540] ircomm_tty: disagrees about version of symbol
struct_module
[ 43.830139] FAT: IO charset iso8859-1 not found
[ 46.811920] ipv6: disagrees about version of symbol struct_module
[ 46.929016] ipv6: disagrees about version of symbol struct_module
[ 49.148437] ipv6: disagrees about version of symbol struct_module
[ 49.600036] ipv6: disagrees about version of symbol struct_module
[ 49.775695] ipv6: disagrees about version of symbol struct_module
[ 49.890625] ipv6: disagrees about version of symbol struct_module
[ 50.066101] ipv6: disagrees about version of symbol struct_module
> > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2009.X-stable beagleboard ttyS2
beagleboard login: root
root@beagleboard:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
root@beagleboard:~# cat /proc/bus/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 3
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 2.06
S: Manufacturer=Linux 2.6.29-omap1 ehci_hcd
S: Product=OMAP-EHCI Host Controller
S: SerialNumber=ehci-omap.0
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
root@beagleboard:~#
In this thest a USB hub was connected before BB was powered on.
I tried also the newest kernel e rootfs from Angstrom (2010) but get
the same results...
Is there a validation test only for the USB host port?
Thanks for the support!
Sorry for the double post but I've news.
I've updated the version of the Angtrom distro to the latest
version...
First: the u-boot.bin (2010 version) don't works: it hangs during boot
at I2C: ready message.
Second: if I boot up using a normal usb cable to power the BB I get
kernel panic.
Third: if I boot using an external power source, i can reach the
login promp... I can login normally but lsusb show 2 hubs (equals VID
& PID) but I can't any external USB device attached (???)
This behaviors are equals on 2 Beagleboards rev C4… so now… does
anyone use this version (rev 4C) and has the USB function properly???
If yes… how to set up angstrom or any other distro?
Your MLO is too old, use the 1.4.4 one.
regards,
Koen
Yes.. I know, double post isn't a good thing ad triple-post is worst
but i solved.
The problem was the u-boot.bin.
The ones taken from the guide at http://code.google.com/p/beagleboard/wiki/BeagleboardRevC3Validation
is the only that enabled the usb.
Now... with that all the usb works;)
The main problem is that the u-boot.bin at the Angstrom website can't
boot... but at least.. now... I know it!
Jeff,
u-boot works fine. You just need to hold the USER button during the boot
2010/7/6 Jeff Malcom <cyberswordman@gmail.com>
Thanks for the suggestion.
But I've tried and it doesn't work...
As far as I know, the USER button on startup tell the BB to start with
the file USER.SCR ,but I don't have such file in the mmc.
Is it mandatory?
Well, on the Rev C4 board it forces a boot from the SD card instead of the NAND and has nothing to do with the user.scr functiuon unless you push the button AFTER the boot process has startted. I am not sure that the user button option to force a boot script switch works on Rev C4. I have seen some people having issues with that feature.
Now that you make me think about it.. you're right about the USER
button.
But now I can't see why I need to push the USER button to make the
latest u-boot to boot correctly (thinks that don't happen even with
the USER button pressed during and after the boot).
Perhaps I miss the correct timing?
(O.T. to the moderators: since the USB question is closed.. is it
better to continue this discussion bout u-boot in another thread?)
You only need to push the user button to force a boot from the SD card. If you have flashed a newer version of the UBoot into NAND, then it will boot from the NAND. It all depends on where the UBoot version that you wish to use is located.
If you like, it would make sense to start a second discussion on this issue so the title is more appropriate.
