I have just setup my beagleboard according to this step by step man
http://elinux.org/BeagleBoardUbuntu
Everything went well except that my keyboard and mouse are not
responding at all
Texas Instruments X-Loader 1.4.4ss (Mar 26 2010 - 09:02:52)
Beagle Rev Ax/Bx
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.11-rc1 (Mar 02 2010 - 03:30:51)
OMAP3530-GP ES3.0, CP
U-OPP2 L3-165MHz
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #1cd200030000000004013f790302100c
Hit any key to stop autoboot: 10
\0x08\0x08\0x08 9
\0x08\0x08\0x08 8
\0x08\0x08\0x08 7
\0x08\0x08\0x08 6
\0x08\0x08\0x08 5
\0x08\0x08\0x08 4
\0x08\0x08\0x08 3
\0x08\0x08\0x08 2
\0x08\0x08\0x08 1
\0x08\0x08\0x08 0
mmc1 is available
reading boot.scr
301 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
mmc1 is available
reading uImage
3284184 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Lin
ux
Data Size: 3284120 Bytes = 3.1 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ...
OK
Loading Kernel Image ...
OK
OK
Starting kernel ...
Uncompressing Linux.........
.................... done, booting the kernel.
[ 0.000000] Linux version 2.6.31.6-x6.0 (root@beagle-128mb-0)
(gcc version 4.4.1 (Ubuntu 4.4.1-4ubuntu8) ) #1 PREEMPT Fri Nov 13
17:02:45 UTC 2009
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES3.0
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xe3000000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200n8
console=tty0 root=/dev/mmcblk0p2 rootwait rootfstype=ext2 ro vram=12M
omapfb.mode=dvi:1280x720MR-16@60
[ 0.000000] PID hash table entries: 512 (order: 9, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768
bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 110548KB available (5940K code, 669K data, 188K
init, 0K highmem)
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.000000] Calibrating delay loop... 503.12 BogoMIPS (lpj=1966080)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] OMAP DMA hardware revision 4.0
[ 0.000000] bio: create slab <bio-0> at 0
[ 0.000000] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 0.000000] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.000000] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.000000] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.000000] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 0.000000] regulator: VDAC: 1800 mV normal standby
[ 0.000000] regulator: VUSB1V5: 1500 mV normal standby
[ 0.000000] regulator: VUSB1V8: 1800 mV normal standby
[ 0.000000] regulator: VUSB3V1: 3100 mV normal standby
[ 0.000000] regulator: VPLL2: 1800 mV normal standby
[ 0.000000] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 0.000000] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 0.000000] SCSI subsystem initialized
[ 0.000000] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.000000] usbcore: registered new interface driver usbfs
[ 0.000000] usbcore: registered new interface driver hub
[ 0.000000] usbcore: registered new device driver usb
[ 0.000000] Bluetooth: Core ver 2.15
[ 0.000000] NET: Registered protocol family 31
[ 0.000000] Bluetooth: HCI device and connection manager
initialized
[ 0.000000] Bluetooth: HCI socket layer initialized
[ 0.000000] cfg80211: Using static regulatory domain info
[ 0.000000] cfg80211: Regulatory domain: US
[ 0.000000] \0x09(start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp)
[ 0.000000] \0x09(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi,
2700 mBm)
[ 0.000000] \0x09(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 0.000000] \0x09(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 0.000000] \0x09(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 0.000000] \0x09(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 0.000000] \0x09(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi,
3000 mBm)
[ 0.000000] cfg80211: Calling CRDA for country: US
[ 66.182373] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 66.183135] musb_hdrc: USB OTG mode controller at d80ab000 using
DMA, IRQ 92
[ 66.184478] NET: Registered protocol family 2
[ 66.184783] IP route cache hash table entries: 1024 (order: 0, 4096
bytes)
[ 66.185455] TCP established hash table entries: 4096 (order: 3,
32768 bytes)
[ 66.185607] TCP bind hash table entries: 4096 (order: 2, 16384
bytes)
[ 66.185729] TCP: Hash tables configured (established 4096 bind
4096)
[ 66.185760] TCP reno registered
[ 66.186096] NET: Registered protocol family 1
[ 6
6.190673] VFS: Disk quotas dquot_6.5.2
[ 66.190856] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 66.191497] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 66.192352] JFFS2 version 2.2. (NAND) (SUMMARY) \0xc2\0xa9
2001-2006 Red Hat, Inc.
[ 66.193359] msgmni has been set to 216
[ 66.198577] alg: No test for stdrng (krng)
[ 66.198730] io scheduler noop registered
[ 66.198791] io scheduler anticipatory registered
[ 66.198822] io scheduler deadline registered
[ 66.199066] io scheduler cfq registered (default)
[ 66.259307] OMAP DSS rev 2.0
[ 66.259429] OMAP DISPC rev 3.0
[ 66.259521] OMAP VENC rev 2
[ 66.260101] OMAP DSI rev 1.0
[ 66.615447] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 66.638488] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 66.659851] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 66.681121] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 66.681213] console [ttyS2] enabled
[ 67.205047] brd: module loaded
[ 67.216033] loop: module loaded
[ 67.219604] i2c /dev entries driver
[ 67.227844] usbcore: registered new interface driver catc
[ 67.233398] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 67.239776] usbcore: registered new interface driver kaweth
[ 67.245483] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 67.253509] usbcore: registered new interface driver pegasus
[ 67.259277] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 67.266571] usbcore: registered new interface driver rtl8150
[ 67.272644] usbcore: registered new interface driver asix
[ 67.278442] usbcore: registered new interface driver cdc_ether
[ 67.284698] usbcore: registered new interface driver dm9601
[ 67.290710] usbcore: registered new interface driver smsc95xx
[ 67.296813] usbcore: registered new interface driver gl620a
[ 67.302825] usbcore: registered new interface driver net1080
[ 67.308898] usbcore: registered new interface driver plusb
[ 67.314788] usbcore: registered new interface driver rndis_host
[ 67.321075] usbcore: registered new interface driver cdc_subset
[ 67.327392] usbcore: registered new interface driver zaurus
[ 67.333435] usbcore: registered new interface driver MOSCHIP usb-
ethernet driver
[ 67.341308] Broadcom 43xx driver loaded [ Features: L, Firmware-ID:
FW13 ]
[ 67.348785] usbcore: registered new interface driver zd1211rw
[ 67.354980] usbcore: registered new interface driver rtl8187
[ 67.361083] usbcore: registered new interface driver rndis_wlan
[ 67.367401] usbcore: registered new interface driver zd1201
[ 67.373443] usbcore: registered new interface driver usb8xxx
[ 67.379577] usbcore: registered new interface driver rt2500usb
[ 67.385833] usbcore: registered new interface driver rt73usb
[ 67.391906] usbcore: registered new interface driver rt2800usb
[ 67.398193] usbcore: registered new interface driver p54usb
[ 67.404205] usbcore: registered new interface driver ar9170usb
[ 67.410736] omap2-nand driver initializing
[ 67.415191] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 67.424377] cmdlinepart partition parsing not available
[ 67.429687] Creating 5 MTD partitions on "omap2-nand":
[ 67.434967] 0x000000000000-0x000000080000 : "X-Loader"
[ 67.442382] 0x000000080000-0x000000260000 : "U-Boot"
[ 67.449737] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 67.456695] 0x000000280000-0x000000680000 : "Kernel"
[ 67.464935] 0x000000680000-0x000010000000 : "File System"
[ 67.580841] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHC
I) Driver
[ 67.587982] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 67.594360] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 67.602294] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 67.618652] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 67.625335] usb usb1: configuration #1 chosen from 1 choice
[ 67.631591] hub 1-0:1.0: USB hub found
[ 67.635528] hub 1-0:1.0: 3 ports detected
[ 67.640930] Initializing USB Mass Storage driver...
[ 67.646392] usbcore: registered new interface driver usb-storage
[ 67.652526] USB Mass Storage support registered.
[ 67.657287] g_ether gadget: using random self ethernet address
[ 67.663269] g_ether gadget: using random host ethernet address
[ 67.670074] usb0: MAC c6:55:9f:19:9d:bf
[ 67.674011] usb0: HOST MAC 1e:0d:2f:6f:01:c8
[ 67.678405] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 67.685180] g_ether gadget: g_ether ready
[ 67.689270] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 67.695129] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number 2
[ 67.703308] usb usb2: configuration #1 chosen from 1 choice
[ 67.709564] hub 2-0:1.0: USB hub found
[ 67.713500] hub 2-0:1.0: 1 port detected
[ 67.718963] mice: PS/2 mouse device common for all mice
[ 67.725097] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 67.735565] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 67.742187] Bluetooth: HCI UART driver ver 2.2
[ 67.746765] Bluetooth: HCI H4 protocol initialized
[ 67.751678] Bluetooth: HCI BCSP protocol initialized
[ 67.756713] Bluetooth: HCILL protocol initialized
[ 67.761505] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 67.768096] usbcore: registered new interface driver bcm203x
[ 67.773834] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 67.780181] usbcore: registered new interface driver bpa10x
[ 67.785980] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 67.791351] usbcore: registered new interface driver bfusb
[ 67.796936] Bluetooth: Generic Bluetooth USB driver ver 0.5
[ 67.802947] usbcore: registered new interface driver btusb
[ 67.808593] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 67.815795] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce
clock
[ 67.932891] Registered led device: beagleboard::usr0
[ 67.938293] Registered led device: beagleboar
d::usr1
[ 67.944122] Registered led device: beagleboard::pmu_stat
[ 67.956329] usbcore: registered new interface driver usbhid
[ 67.961975] usbhid: v2.6:USB HID core driver
[ 67.967987] Advanced Linux Sound Architecture Driver Version
1.0.20.
[ 67.975494] usbcore: registered new interface driver snd-usb-audio
[ 67.982269] No device for DAI twl4030
[ 67.986175] No device for DAI twl4030 Voice
[ 67.990417] No device for DAI omap-mcbsp-dai-0
[ 67.995056] No device for DAI omap-mcbsp-dai-1
[ 67.999542] No device for DAI omap-mcbsp-dai-2
[ 68.004089] No device for DAI omap-mcbsp-dai-3
[ 68.008575] No device for DAI omap-mcbsp-dai-4
[ 68.013122] Not OMAP3 EVM!
[ 68.015869] OMAP3 Beagle SoC init
[ 68.019744] TWL4030 Audio Codec init
[ 68.025085] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 68.109710] ALSA device list:
[ 68.112792] #0: omap3beagle (twl4030)
[ 68.117218] oprofile: using arm/armv7
[ 68.121276] TCP cubic registered
[ 68.124542] NET: Registered protocol family 17
[ 68.129180] NET: Registered protocol family 15
[ 68.133728] Bluetooth: L2CAP ver 2.13
[ 68.137481] Bluetooth: L2CAP socket layer initialized
[ 68.142639] Bluetooth: SCO (Voice Link) ver 0.6
[ 68.147247] Bluetooth: SCO socket layer initialized
[ 68.152435] Bluetooth: RFCOMM TTY layer initialized
[ 68.157409] Bluetooth: RFCOMM socket layer initialized
[ 68.162658] Bluetooth: RFCOMM ver 1.11
[ 68.166534] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 68.171905] Bluetooth: BNEP filters: protocol multicast
[ 68.177246] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 68.184356] RPC: Registered udp transport module.
[ 68.189178] RPC: Registered tcp transport module.
[ 68.194030] lib80211: common routines for IEEE802.11 drivers
[ 68.199859] ThumbEE CPU extension supported.
[ 68.204193] Power Management for TI OMAP3.
[ 68.219055] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 68.229278] registered taskstats version 1
[ 68.234954] fbcvt: 1280x720@60: CVT Name - .921M9-R
[ 68.269226] Console: switching to colour frame buffer device 160x45
[ 68.294281] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 68.302154] Waiting for root device /dev/mmcblk0p2...
[ 68.376586] mmc0: new
SD card at address aaaa
[ 68.381958] mmcblk0: mmc0:aaaa SD02G 1.84 GiB
[ 68.386962] mmcblk0: p1 p2
[ 68.423797] EXT2-fs warning (device mmcblk0p2): ext2_fill_super:
mounting ext3 filesystem as ext2
[ 68.433197] VFS: Mounted root (ext2 filesystem) readonly on device
179:2.
[ 68.440490] Freeing init memory: 188K
Ubuntu 9.10 beagleboard ttyS2
beagleboard login:
I think i missed something when i copied the files....
Where should i start search the problem?
