I bought a miniature WiFi (802.11b/g/n) module a while ago, and cannot make it works with my BeagleBone.
I tried to troubleshoot the problem with Adafruit guys, but it looks like the problem would be linked to the USB dongle of the BeagleBone.
Here is the log:
root@beaglebone:~# dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13 (koen@rrMBP) (gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Tue Jun 18 02:11:09 EDT 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 65280
[ 0.000000] free_area_init_node: node 0, pgdat c0688d80, node_mem_map c06e4000
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 64768 pages, LIFO batch:15
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c08f2000 s9408 r8192 d15168 u32768
[ 0.000000] pcpu-alloc: s9408 r8192 d15168 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64768
[ 0.000000] Kernel command line: console=ttyO0,115200n8 run_hardware_tests quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 524288 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 255MB = 255MB total
[ 0.000000] Memory: 251176k/251176k available, 10968k reserved, 0K highmem
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
.text : 0xc0008000 - 0xc05d5914 (5943 kB)
.init : 0xc05d6000 - 0xc06174c0 ( 262 kB)
.data : 0xc0618000 - 0xc0689ca0 ( 456 kB)
.bss : 0xc0689ca0 - 0xc06e36bc ( 359 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000364] Calibrating delay loop… 545.07 BogoMIPS (lpj=531968)
[ 0.015419] pid_max: default: 32768 minimum: 301
[ 0.015650] Security Framework initialized
[ 0.015750] Mount-cache hash table entries: 512
[ 0.025792] Initializing cgroup subsys cpuacct
[ 0.025829] Initializing cgroup subsys memory
[ 0.025893] Initializing cgroup subsys blkio
[ 0.026035] CPU: Testing write buffer coherency: ok
[ 0.026599] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.026681] Setting up static identity map for 0x80370ee0 - 0x80370f2c
[ 0.028115] Brought up 1 CPUs
[ 0.028141] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029478] devtmpfs: initialized
[ 0.094467] pinctrl core: initialized pinctrl subsystem
[ 0.094689] rstctl core: initialized rstctl subsystem
[ 0.095189] regulator-dummy: no parameters
[ 0.095781] NET: Registered protocol family 16
[ 0.096693] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106659] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107497] platform 49000000.edma: alias fck already exists
[ 0.107531] platform 49000000.edma: alias fck already exists
[ 0.107558] platform 49000000.edma: alias fck already exists
[ 0.108725] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.108910] OMAP GPIO hardware version 0.1
[ 0.110341] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.111669] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.112974] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.118693] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.120929] cpsw.0: No hwaddr in dt. Using 50:56:63:c9:d0:01 from efuse
[ 0.120975] cpsw.1: No hwaddr in dt. Using 50:56:63:c9:d0:02 from efuse
[ 0.135515] bio: create slab at 0
[ 0.147581] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.147814] of_get_named_gpio_flags: can’t parse gpios property
[ 0.148069] vmmcsd_fixed: 3300 mV
[ 0.150974] SCSI subsystem initialized
[ 0.151385] usbcore: registered new interface driver usbfs
[ 0.151509] usbcore: registered new interface driver hub
[ 0.151805] usbcore: registered new device driver usb
[ 0.153901] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.155443] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.157224] DCDC1: at 1800 mV
[ 0.158382] vdd_mpu: 925 <–> 1325 mV at 1275 mV
[ 0.159502] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.160687] LDO1: at 1800 mV
[ 0.161767] LDO2: at 3300 mV
[ 0.162942] LDO3: 1800 <–> 3300 mV at 3300 mV
[ 0.164099] LDO4: at 3300 mV
[ 0.165117] tps65217 0-0024: TPS65217 ID 0xf version 1.1
[ 0.165905] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.166638] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.169049] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.169278] media: Linux media interface: v0.10
[ 0.169383] Linux video capture interface: v2.00
[ 0.170179] Advanced Linux Sound Architecture Driver Initialized.
[ 0.171544] Switching to clocksource gp_timer
[ 0.189828] NET: Registered protocol family 2
[ 0.190859] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.190948] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[ 0.191039] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.191130] TCP: reno registered
[ 0.191231] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191282] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191718] NET: Registered protocol family 1
[ 0.192303] RPC: Registered named UNIX socket transport module.
[ 0.192323] RPC: Registered udp transport module.
[ 0.192337] RPC: Registered tcp transport module.
[ 0.192350] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.193596] CPU PMU: probing PMU on CPU 0
[ 0.193627] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.194090] omap2_mbox_probe: platform not supported
[ 0.198075] VFS: Disk quotas dquot_6.5.2
[ 0.198313] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.199628] NFS: Registering the id_resolver key type
[ 0.199736] Key type id_resolver registered
[ 0.199754] Key type id_legacy registered
[ 0.199827] jffs2: version 2.2. (NAND) (SUMMARY) \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc.
[ 0.200267] msgmni has been set to 490
[ 0.203252] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.203279] io scheduler noop registered
[ 0.203295] io scheduler deadline registered
[ 0.203336] io scheduler cfq registered (default)
[ 0.205057] tps65217-bl tps65217-bl: no platform data provided
[ 0.205102] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.205993] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.208625] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.209022] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 0.221261] console [ttyO0] enabled
[ 0.222288] [drm] Initialized drm 1.1.0 20060810
[ 0.236221] brd: module loaded
[ 0.243280] loop: module loaded
[ 0.243409] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.243487] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.243558] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.243627] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.243696] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.250909] bone-capemgr bone_capemgr.7: Baseboard: ‘A335BONE,00A6,3712BB000826’
[ 0.250948] bone-capemgr bone_capemgr.7: compatible-baseboard=ti,beaglebone
[ 0.281054] bone-capemgr bone_capemgr.7: slot #0: No cape found
[ 0.318160] bone-capemgr bone_capemgr.7: slot #1: No cape found
[ 0.355269] bone-capemgr bone_capemgr.7: slot #2: No cape found
[ 0.392377] bone-capemgr bone_capemgr.7: slot #3: No cape found
[ 0.398777] bone-capemgr bone_capemgr.7: initialized OK.
[ 0.400774] OneNAND driver initializing
[ 0.402318] usbcore: registered new interface driver asix
[ 0.402444] usbcore: registered new interface driver cdc_ether
[ 0.402564] usbcore: registered new interface driver smsc95xx
[ 0.402666] usbcore: registered new interface driver net1080
[ 0.402756] usbcore: registered new interface driver cdc_subset
[ 0.402843] usbcore: registered new interface driver zaurus
[ 0.403008] usbcore: registered new interface driver cdc_ncm
[ 0.403813] usbcore: registered new interface driver cdc_acm
[ 0.403832] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.403846] Initializing USB Mass Storage driver…
[ 0.403979] usbcore: registered new interface driver usb-storage
[ 0.403994] USB Mass Storage support registered.
[ 0.404229] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.404623] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 0.404651] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 0.404689] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.404710] musb-hdrc: MHDRC RTL version 2.0
[ 0.404725] musb-hdrc: setup fifo_mode 4
[ 0.404753] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.404900] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 0.404922] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 0.405650] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 0.405678] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 0.405714] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.405733] musb-hdrc: MHDRC RTL version 2.0
[ 0.405747] musb-hdrc: setup fifo_mode 4
[ 0.405769] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.405896] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 0.405918] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 0.405939] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.406382] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.406423] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 0.406539] usb usb1: default language 0x0409
[ 0.406598] usb usb1: udev 1, busnum 1, minor = 0
[ 0.406622] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.406644] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.406665] usb usb1: Product: MUSB HDRC host driver
[ 0.406685] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 0.406704] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 0.407486] usb usb1: usb_probe_device
[ 0.407515] usb usb1: configuration #1 chosen from 1 choice
[ 0.407585] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 0.407792] hub 1-0:1.0: usb_probe_interface
[ 0.407815] hub 1-0:1.0: usb_probe_interface - got id
[ 0.407844] hub 1-0:1.0: USB hub found
[ 0.407885] hub 1-0:1.0: 1 port detected
[ 0.407904] hub 1-0:1.0: standalone hub
[ 0.407921] hub 1-0:1.0: individual port power switching
[ 0.407939] hub 1-0:1.0: no over-current protection
[ 0.408051] hub 1-0:1.0: Single TT
[ 0.408075] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 0.408095] hub 1-0:1.0: power on to power good time: 10ms
[ 0.408180] hub 1-0:1.0: local power source is good
[ 0.408295] hub 1-0:1.0: enabling power on all ports
[ 0.409416] mousedev: PS/2 mouse device common for all mice
[ 0.412032] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 0.412095] 44e3e000.rtc: already running
[ 0.412369] i2c /dev entries driver
[ 0.414129] Driver for 1-wire Dallas network protocol.
[ 0.415564] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.415966] cpuidle: using governor ladder
[ 0.415985] cpuidle: using governor menu
[ 0.416394] of_get_named_gpio_flags: can’t parse gpios property
[ 0.416413] of_get_named_gpio_flags: can’t parse gpios property
[ 0.416429] of_get_named_gpio_flags: can’t parse gpios property
[ 0.416465] omap_hsmmc mmc.3: of_parse_phandle_with_args of ‘reset’ failed
[ 0.423708] omap_hsmmc mmc.3: Failed to get rstctl; not using any
[ 0.423761] omap_hsmmc mmc.3: unable to select pin group
[ 0.424045] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 0.424122] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 0.424654] mmc.3 supply vmmc_aux not found, using dummy regulator
[ 0.426177] omap_hsmmc mmc.3: pins are not configured from the driver
[ 0.455445] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.6
[ 0.467204] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.6) status -22
[ 0.474518] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 0.483511] leds-gpio gpio-leds.6: pins are not configured from the driver
[ 0.483550] of_get_named_gpio_flags exited with status 53
[ 0.483573] of_get_named_gpio_flags exited with status 54
[ 0.483595] of_get_named_gpio_flags exited with status 55
[ 0.483617] of_get_named_gpio_flags exited with status 56
[ 0.483642] of_get_named_gpio_flags exited with status 53
[ 0.483934] of_get_named_gpio_flags exited with status 54
[ 0.484195] of_get_named_gpio_flags exited with status 55
[ 0.484398] of_get_named_gpio_flags exited with status 56
[ 0.484765] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.485200] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 0.485280] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 0.487560] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 0.487689] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 0.487763] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 0.488954] usbcore: registered new interface driver usbhid
[ 0.488973] usbhid: USB HID core driver
[ 0.491747] TCP: cubic registered
[ 0.491769] Initializing XFRM netlink socket
[ 0.491815] NET: Registered protocol family 17
[ 0.491895] NET: Registered protocol family 15
[ 0.492357] Key type dns_resolver registered
[ 0.492694] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.492734] ThumbEE CPU extension supported.
[ 0.492778] Registering SWP/SWPB emulation handler
[ 0.493752] registered taskstats version 1
[ 0.511431] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 0.511630] hub 1-0:1.0: hub_suspend
[ 0.511676] usb usb1: bus auto-suspend, wakeup 1
[ 0.544708] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 0.546694] mmc0: new high speed SDHC card at address 1234
[ 0.547458] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 0.547483] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 0.547961] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 0.549727] libphy: 4a101000.mdio: probed
[ 0.549760] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.549988] Detected MACID = 50:56:63:c9:d0:01
[ 0.550118] cpsw 4a100000.ethernet: NAPI disabled
[ 0.550827] mmcblk0: p1 p2
[ 0.553362] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:19:09 UTC (946685949)
[ 0.562203] ALSA device list:
[ 0.562230] No soundcards found.
[ 0.593840] usb usb1: usb wakeup-resume
[ 0.593894] usb usb1: usb auto-resume
[ 0.593959] hub 1-0:1.0: hub_resume
[ 0.594010] hub 1-0:1.0: port 1: status 0101 change 0001
[ 0.597037] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 0.597118] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 0.624488] devtmpfs: mounted
[ 0.624917] Freeing init memory: 260K
[ 0.697145] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[ 0.697241] hub 1-0:1.0: port 1, status 0101, change 0000, 12 Mb/s
[ 0.802697] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 0.922507] usb 1-1: default language 0x0409
[ 0.923116] usb 1-1: udev 2, busnum 1, minor = 1
[ 0.923138] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
[ 0.923156] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 0.923172] usb 1-1: Product: 802.11n WLAN Adapter
[ 0.923187] usb 1-1: Manufacturer: Realtek
[ 0.923201] usb 1-1: SerialNumber: 00e04c000001
[ 0.923837] usb 1-1: usb_probe_device
[ 0.923863] usb 1-1: configuration #1 chosen from 1 choice
[ 0.924020] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 0.924926] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[ 0.924968] hub 1-0:1.0: port 1 enable change, status 00000503
[ 1.498593] systemd[1]: systemd 196 running in system mode. (+PAM -LIBWRAP -AUDIT -SELINUX +IMA +SYSVINIT -LIBCRYPTSETUP +GCRYPT +ACL +XZ; angstrom)
[ 1.592272] systemd[1]: Inserted module ‘autofs4’
[ 1.594666] systemd[1]: Set hostname to .
[ 1.624448] systemd[1]: Initializing machine ID from random generator.
[ 1.624958] systemd[1]: Installed transient /etc/machine-id file.
[ 1.970771] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 1.971379] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.971520] systemd[1]: Expecting device dev-ttyGS0.device…
[ 1.971634] systemd[1]: Expecting device dev-ttyO0.device…
[ 1.971736] systemd[1]: Starting Remote File Systems.
[ 1.971828] systemd[1]: Reached target Remote File Systems.
[ 1.971931] systemd[1]: Starting Delayed Shutdown Socket.
[ 1.972202] systemd[1]: Listening on Delayed Shutdown Socket.
[ 1.972292] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 1.972657] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 1.972796] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 1.973138] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.973466] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 1.974350] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.975203] systemd[1]: Starting udev Kernel Socket.
[ 1.975488] systemd[1]: Listening on udev Kernel Socket.
[ 1.975965] systemd[1]: Starting udev Control Socket.
[ 1.976289] systemd[1]: Listening on udev Control Socket.
[ 1.976553] systemd[1]: Starting Swap.
[ 1.976658] systemd[1]: Reached target Swap.
[ 1.976779] systemd[1]: Starting Journal Socket.
[ 1.977232] systemd[1]: Listening on Journal Socket.
[ 1.977437] systemd[1]: Starting File System Check on Root Device…
[ 1.985745] systemd[1]: Starting udev Coldplug all Devices…
[ 1.995960] systemd[1]: Mounting Debug File System…
[ 2.036200] systemd[1]: Started Set Up Additional Binary Formats.
[ 2.104008] systemd[1]: Starting Apply Kernel Variables…
[ 2.125245] systemd[1]: Starting Load Kernel Modules…
[ 2.131466] systemd[1]: Mounted Huge Pages File System.
[ 2.131640] systemd[1]: Started Machine ID first boot configure.
[ 2.131811] systemd[1]: Mounting POSIX Message Queue File System…
[ 2.140121] systemd[1]: Starting udev Kernel Device Manager…
[ 2.152771] systemd[1]: Starting Journal Service…
[ 2.159125] systemd[1]: Started Journal Service.
[ 2.342974] systemd-udevd[85]: starting version 196
[ 2.538228] bluetooth: disagrees about version of symbol skb_free_datagram
[ 2.538263] bluetooth: Unknown symbol skb_free_datagram (err -22)
[ 2.538311] bluetooth: disagrees about version of symbol simple_attr_write
[ 2.538324] bluetooth: Unknown symbol simple_attr_write (err -22)
[ 2.538359] bluetooth: disagrees about version of symbol sock_i_uid
[ 2.538372] bluetooth: Unknown symbol sock_i_uid (err -22)
[ 2.538414] bluetooth: disagrees about version of symbol simple_attr_open
[ 2.538428] bluetooth: Unknown symbol simple_attr_open (err -22)
[ 2.539131] bluetooth: disagrees about version of symbol skb_put
[ 2.539154] bluetooth: Unknown symbol skb_put (err -22)
[ 2.539198] bluetooth: disagrees about version of symbol dev_set_name
[ 2.539211] bluetooth: Unknown symbol dev_set_name (err -22)
[ 2.539282] bluetooth: disagrees about version of symbol skb_dequeue
[ 2.539295] bluetooth: Unknown symbol skb_dequeue (err -22)
[ 2.539374] bluetooth: disagrees about version of symbol device_initialize
[ 2.539387] bluetooth: Unknown symbol device_initialize (err -22)
[ 2.539524] bluetooth: disagrees about version of symbol sock_no_connect
[ 2.539538] bluetooth: Unknown symbol sock_no_connect (err -22)
[ 2.539589] bluetooth: disagrees about version of symbol get_device
[ 2.539602] bluetooth: Unknown symbol get_device (err -22)
[ 2.539635] bluetooth: disagrees about version of symbol skb_copy_datagram_iovec
[ 2.539648] bluetooth: Unknown symbol skb_copy_datagram_iovec (err -22)
[ 2.539683] bluetooth: disagrees about version of symbol sock_alloc_send_skb
[ 2.539696] bluetooth: Unknown symbol sock_alloc_send_skb (err -22)
[ 2.539752] bluetooth: disagrees about version of symbol proto_unregister
[ 2.539765] bluetooth: Unknown symbol proto_unregister (err -22)
[ 2.539783] bluetooth: disagrees about version of symbol kfree_skb
[ 2.539795] bluetooth: Unknown symbol kfree_skb (err -22)
[ 2.539827] bluetooth: disagrees about version of symbol sock_register
[ 2.539841] bluetooth: Unknown symbol sock_register (err -22)
[ 2.539879] bluetooth: disagrees about version of symbol datagram_poll
[ 2.539892] bluetooth: Unknown symbol datagram_poll (err -22)
[ 2.539911] bluetooth: disagrees about version of symbol sock_get_timestampns
[ 2.539924] bluetooth: Unknown symbol sock_get_timestampns (err -22)
[ 2.539945] bluetooth: disagrees about version of symbol put_device
[ 2.539958] bluetooth: Unknown symbol put_device (err -22)
[ 2.539989] bluetooth: disagrees about version of symbol __alloc_skb
[ 2.540002] bluetooth: Unknown symbol __alloc_skb (err -22)
[ 2.540033] bluetooth: disagrees about version of symbol sk_reset_timer
[ 2.540046] bluetooth: Unknown symbol sk_reset_timer (err -22)
[ 2.540073] bluetooth: disagrees about version of symbol proto_register
[ 2.540086] bluetooth: Unknown symbol proto_register (err -22)
[ 2.540116] bluetooth: disagrees about version of symbol skb_queue_tail
[ 2.540129] bluetooth: Unknown symbol skb_queue_tail (err -22)
[ 2.540163] bluetooth: disagrees about version of symbol __sock_recv_ts_and_drops
[ 2.540176] bluetooth: Unknown symbol __sock_recv_ts_and_drops (err -22)
[ 2.540212] bluetooth: disagrees about version of symbol __sock_recv_timestamp
[ 2.540225] bluetooth: Unknown symbol __sock_recv_timestamp (err -22)
[ 2.540244] bluetooth: disagrees about version of symbol sock_no_shutdown
[ 2.540257] bluetooth: Unknown symbol sock_no_shutdown (err -22)
[ 2.540288] bluetooth: disagrees about version of symbol init_net
[ 2.540301] bluetooth: Unknown symbol init_net (err -22)
[ 2.540333] bluetooth: disagrees about version of symbol skb_pull
[ 2.540346] bluetooth: Unknown symbol skb_pull (err -22)
[ 2.540365] bluetooth: disagrees about version of symbol device_add
[ 2.540378] bluetooth: Unknown symbol device_add (err -22)
[ 2.540399] bluetooth: disagrees about version of symbol simple_attr_release
[ 2.540412] bluetooth: Unknown symbol simple_attr_release (err -22)
[ 2.540452] bluetooth: disagrees about version of symbol sk_free
[ 2.540465] bluetooth: Unknown symbol sk_free (err -22)
[ 2.540484] bluetooth: disagrees about version of symbol device_move
[ 2.540497] bluetooth: Unknown symbol device_move (err -22)
[ 2.540515] bluetooth: disagrees about version of symbol sock_no_accept
[ 2.540528] bluetooth: Unknown symbol sock_no_accept (err -22)
[ 2.540579] bluetooth: disagrees about version of symbol skb_push
[ 2.540592] bluetooth: Unknown symbol skb_push (err -22)
[ 2.540625] bluetooth: disagrees about version of symbol sock_no_listen
[ 2.540638] bluetooth: Unknown symbol sock_no_listen (err -22)
[ 2.540749] bluetooth: disagrees about version of symbol proc_net_remove
[ 2.540849] bluetooth: Unknown symbol proc_net_remove (err -22)
[ 2.548776] bluetooth: disagrees about version of symbol lock_sock_nested
[ 2.548808] bluetooth: Unknown symbol lock_sock_nested (err -22)
[ 2.548849] bluetooth: disagrees about version of symbol device_find_child
[ 2.548862] bluetooth: Unknown symbol device_find_child (err -22)
[ 2.548919] bluetooth: disagrees about version of symbol __pskb_copy
[ 2.548932] bluetooth: Unknown symbol __pskb_copy (err -22)
[ 2.548952] bluetooth: disagrees about version of symbol sk_alloc
[ 2.548965] bluetooth: Unknown symbol sk_alloc (err -22)
[ 2.548983] bluetooth: disagrees about version of symbol device_del
[ 2.548996] bluetooth: Unknown symbol device_del (err -22)
[ 2.549020] bluetooth: disagrees about version of symbol __sock_recv_wifi_status
[ 2.549033] bluetooth: Unknown symbol __sock_recv_wifi_status (err -22)
[ 2.549064] bluetooth: disagrees about version of symbol sock_no_socketpair
[ 2.549077] bluetooth: Unknown symbol sock_no_socketpair (err -22)
[ 2.549103] bluetooth: disagrees about version of symbol skb_queue_purge
[ 2.549116] bluetooth: Unknown symbol skb_queue_purge (err -22)
[ 2.549164] bluetooth: disagrees about version of symbol sock_no_mmap
[ 2.549178] bluetooth: Unknown symbol sock_no_mmap (err -22)
[ 2.549205] bluetooth: disagrees about version of symbol sock_get_timestamp
[ 2.549218] bluetooth: Unknown symbol sock_get_timestamp (err -22)
[ 2.549241] bluetooth: disagrees about version of symbol simple_attr_read
[ 2.549253] bluetooth: Unknown symbol simple_attr_read (err -22)
[ 2.549280] bluetooth: disagrees about version of symbol skb_trim
[ 2.549292] bluetooth: Unknown symbol skb_trim (err -22)
[ 2.549308] bluetooth: disagrees about version of symbol skb_unlink
[ 2.549321] bluetooth: Unknown symbol skb_unlink (err -22)
[ 2.549350] bluetooth: disagrees about version of symbol proc_net_fops_create
[ 2.549363] bluetooth: Unknown symbol proc_net_fops_create (err -22)
[ 2.549407] bluetooth: disagrees about version of symbol sock_i_ino
[ 2.549420] bluetooth: Unknown symbol sock_i_ino (err -22)
[ 2.549507] bluetooth: disagrees about version of symbol skb_recv_datagram
[ 2.549520] bluetooth: Unknown symbol skb_recv_datagram (err -22)
[ 2.549553] bluetooth: disagrees about version of symbol sock_queue_rcv_skb
[ 2.549566] bluetooth: Unknown symbol sock_queue_rcv_skb (err -22)
[ 2.549616] bluetooth: disagrees about version of symbol skb_copy
[ 2.549629] bluetooth: Unknown symbol skb_copy (err -22)
[ 2.549650] bluetooth: disagrees about version of symbol skb_clone
[ 2.549663] bluetooth: Unknown symbol skb_clone (err -22)
[ 2.549714] bluetooth: disagrees about version of symbol sk_stop_timer
[ 2.549728] bluetooth: Unknown symbol sk_stop_timer (err -22)
[ 2.549822] bluetooth: disagrees about version of symbol sock_init_data
[ 2.549835] bluetooth: Unknown symbol sock_init_data (err -22)
[ 2.549859] bluetooth: disagrees about version of symbol release_sock
[ 2.549872] bluetooth: Unknown symbol release_sock (err -22)
[ 2.549885] bluetooth: disagrees about version of symbol skb_queue_head
[ 2.549898] bluetooth: Unknown symbol skb_queue_head (err -22)
[ 2.692652] NET: Registered protocol family 10
[ 2.752642] NET: Registered protocol family 23
[ 2.765894] IrCOMM protocol (Dag Brattli)
[ 2.841826] bluetooth: disagrees about version of symbol skb_free_datagram
[ 2.841858] bluetooth: Unknown symbol skb_free_datagram (err -22)
[ 2.841904] bluetooth: disagrees about version of symbol simple_attr_write
[ 2.841918] bluetooth: Unknown symbol simple_attr_write (err -22)
[ 2.841953] bluetooth: disagrees about version of symbol sock_i_uid
[ 2.841966] bluetooth: Unknown symbol sock_i_uid (err -22)
[ 2.842007] bluetooth: disagrees about version of symbol simple_attr_open
[ 2.842020] bluetooth: Unknown symbol simple_attr_open (err -22)
[ 2.842118] bluetooth: disagrees about version of symbol skb_put
[ 2.842131] bluetooth: Unknown symbol skb_put (err -22)
[ 2.842171] bluetooth: disagrees about version of symbol dev_set_name
[ 2.842184] bluetooth: Unknown symbol dev_set_name (err -22)
[ 2.842252] bluetooth: disagrees about version of symbol skb_dequeue
[ 2.842266] bluetooth: Unknown symbol skb_dequeue (err -22)
[ 2.842343] bluetooth: disagrees about version of symbol device_initialize
[ 2.842356] bluetooth: Unknown symbol device_initialize (err -22)
[ 2.842494] bluetooth: disagrees about version of symbol sock_no_connect
[ 2.842507] bluetooth: Unknown symbol sock_no_connect (err -22)
[ 2.842559] bluetooth: disagrees about version of symbol get_device
[ 2.842572] bluetooth: Unknown symbol get_device (err -22)
[ 2.842605] bluetooth: disagrees about version of symbol skb_copy_datagram_iovec
[ 2.842618] bluetooth: Unknown symbol skb_copy_datagram_iovec (err -22)
[ 2.842651] bluetooth: disagrees about version of symbol sock_alloc_send_skb
[ 2.842664] bluetooth: Unknown symbol sock_alloc_send_skb (err -22)
[ 2.842719] bluetooth: disagrees about version of symbol proto_unregister
[ 2.842732] bluetooth: Unknown symbol proto_unregister (err -22)
[ 2.842750] bluetooth: disagrees about version of symbol kfree_skb
[ 2.842763] bluetooth: Unknown symbol kfree_skb (err -22)
[ 2.842793] bluetooth: disagrees about version of symbol sock_register
[ 2.842806] bluetooth: Unknown symbol sock_register (err -22)
[ 2.842844] bluetooth: disagrees about version of symbol datagram_poll
[ 2.842856] bluetooth: Unknown symbol datagram_poll (err -22)
[ 2.842875] bluetooth: disagrees about version of symbol sock_get_timestampns
[ 2.842888] bluetooth: Unknown symbol sock_get_timestampns (err -22)
[ 2.842909] bluetooth: disagrees about version of symbol put_device
[ 2.842922] bluetooth: Unknown symbol put_device (err -22)
[ 2.842952] bluetooth: disagrees about version of symbol __alloc_skb
[ 2.842965] bluetooth: Unknown symbol __alloc_skb (err -22)
[ 2.842995] bluetooth: disagrees about version of symbol sk_reset_timer
[ 2.843008] bluetooth: Unknown symbol sk_reset_timer (err -22)
[ 2.843035] bluetooth: disagrees about version of symbol proto_register
[ 2.843048] bluetooth: Unknown symbol proto_register (err -22)
[ 2.843079] bluetooth: disagrees about version of symbol skb_queue_tail
[ 2.843092] bluetooth: Unknown symbol skb_queue_tail (err -22)
[ 2.843126] bluetooth: disagrees about version of symbol __sock_recv_ts_and_drops
[ 2.843139] bluetooth: Unknown symbol __sock_recv_ts_and_drops (err -22)
[ 2.843175] bluetooth: disagrees about version of symbol __sock_recv_timestamp
[ 2.843188] bluetooth: Unknown symbol __sock_recv_timestamp (err -22)
[ 2.843207] bluetooth: disagrees about version of symbol sock_no_shutdown
[ 2.843220] bluetooth: Unknown symbol sock_no_shutdown (err -22)
[ 2.843250] bluetooth: disagrees about version of symbol init_net
[ 2.843263] bluetooth: Unknown symbol init_net (err -22)
[ 2.843294] bluetooth: disagrees about version of symbol skb_pull
[ 2.843307] bluetooth: Unknown symbol skb_pull (err -22)
[ 2.843327] bluetooth: disagrees about version of symbol device_add
[ 2.843340] bluetooth: Unknown symbol device_add (err -22)
[ 2.843360] bluetooth: disagrees about version of symbol simple_attr_release
[ 2.843373] bluetooth: Unknown symbol simple_attr_release (err -22)
[ 2.843412] bluetooth: disagrees about version of symbol sk_free
[ 2.843425] bluetooth: Unknown symbol sk_free (err -22)
[ 2.843445] bluetooth: disagrees about version of symbol device_move
[ 2.843457] bluetooth: Unknown symbol device_move (err -22)
[ 2.843476] bluetooth: disagrees about version of symbol sock_no_accept
[ 2.843489] bluetooth: Unknown symbol sock_no_accept (err -22)
[ 2.851525] bluetooth: disagrees about version of symbol skb_push
[ 2.851554] bluetooth: Unknown symbol skb_push (err -22)
[ 2.851599] bluetooth: disagrees about version of symbol sock_no_listen
[ 2.851613] bluetooth: Unknown symbol sock_no_listen (err -22)
[ 2.851741] bluetooth: disagrees about version of symbol proc_net_remove
[ 2.851756] bluetooth: Unknown symbol proc_net_remove (err -22)
[ 2.851785] bluetooth: disagrees about version of symbol lock_sock_nested
[ 2.851797] bluetooth: Unknown symbol lock_sock_nested (err -22)
[ 2.851827] bluetooth: disagrees about version of symbol device_find_child
[ 2.851840] bluetooth: Unknown symbol device_find_child (err -22)
[ 2.851905] bluetooth: disagrees about version of symbol __pskb_copy
[ 2.851919] bluetooth: Unknown symbol __pskb_copy (err -22)
[ 2.854889] bluetooth: disagrees about version of symbol sk_alloc
[ 2.854922] bluetooth: Unknown symbol sk_alloc (err -22)
[ 2.854950] bluetooth: disagrees about version of symbol device_del
[ 2.854963] bluetooth: Unknown symbol device_del (err -22)
[ 2.854989] bluetooth: disagrees about version of symbol __sock_recv_wifi_status
[ 2.855003] bluetooth: Unknown symbol __sock_recv_wifi_status (err -22)
[ 2.855034] bluetooth: disagrees about version of symbol sock_no_socketpair
[ 2.855047] bluetooth: Unknown symbol sock_no_socketpair (err -22)
[ 2.855076] bluetooth: disagrees about version of symbol skb_queue_purge
[ 2.855089] bluetooth: Unknown symbol skb_queue_purge (err -22)
[ 2.855139] bluetooth: disagrees about version of symbol sock_no_mmap
[ 2.855152] bluetooth: Unknown symbol sock_no_mmap (err -22)
[ 2.855180] bluetooth: disagrees about version of symbol sock_get_timestamp
[ 2.855193] bluetooth: Unknown symbol sock_get_timestamp (err -22)
[ 2.855388] bluetooth: disagrees about version of symbol simple_attr_read
[ 2.855407] bluetooth: Unknown symbol simple_attr_read (err -22)
[ 2.856296] bluetooth: disagrees about version of symbol skb_trim
[ 2.856321] bluetooth: Unknown symbol skb_trim (err -22)
[ 2.856338] bluetooth: disagrees about version of symbol skb_unlink
[ 2.856351] bluetooth: Unknown symbol skb_unlink (err -22)
[ 2.856387] bluetooth: disagrees about version of symbol proc_net_fops_create
[ 2.856400] bluetooth: Unknown symbol proc_net_fops_create (err -22)
[ 2.856448] bluetooth: disagrees about version of symbol sock_i_ino
[ 2.856461] bluetooth: Unknown symbol sock_i_ino (err -22)
[ 2.856572] bluetooth: disagrees about version of symbol skb_recv_datagram
[ 2.856586] bluetooth: Unknown symbol skb_recv_datagram (err -22)
[ 2.856620] bluetooth: disagrees about version of symbol sock_queue_rcv_skb
[ 2.856633] bluetooth: Unknown symbol sock_queue_rcv_skb (err -22)
[ 2.856686] bluetooth: disagrees about version of symbol skb_copy
[ 2.856699] bluetooth: Unknown symbol skb_copy (err -22)
[ 2.856720] bluetooth: disagrees about version of symbol skb_clone
[ 2.856733] bluetooth: Unknown symbol skb_clone (err -22)
[ 2.856787] bluetooth: disagrees about version of symbol sk_stop_timer
[ 2.856800] bluetooth: Unknown symbol sk_stop_timer (err -22)
[ 2.856897] bluetooth: disagrees about version of symbol sock_init_data
[ 2.856911] bluetooth: Unknown symbol sock_init_data (err -22)
[ 2.856936] bluetooth: disagrees about version of symbol release_sock
[ 2.856949] bluetooth: Unknown symbol release_sock (err -22)
[ 2.856962] bluetooth: disagrees about version of symbol skb_queue_head
[ 2.856975] bluetooth: Unknown symbol skb_queue_head (err -22)
[ 3.121084] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.865424] systemd-journald[86]: Received SIGUSR1
[ 9.328217] cfg80211: Calling CRDA to update world regulatory domain
[ 9.328359] cfg80211: World regulatory domain updated:
[ 9.328372] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.328388] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.328402] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.328416] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 9.328429] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.328443] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.618412] rtlwifi: disagrees about version of symbol skb_put
[ 10.618447] rtlwifi: Unknown symbol skb_put (err -22)
[ 10.618498] rtlwifi: disagrees about version of symbol skb_dequeue
[ 10.618513] rtlwifi: Unknown symbol skb_dequeue (err -22)
[ 10.618537] rtlwifi: disagrees about version of symbol ieee80211_free_hw
[ 10.618551] rtlwifi: Unknown symbol ieee80211_free_hw (err -22)
[ 10.618573] rtlwifi: disagrees about version of symbol ieee80211_alloc_hw
[ 10.618587] rtlwifi: Unknown symbol ieee80211_alloc_hw (err -22)
[ 10.618636] rtlwifi: disagrees about version of symbol regulatory_hint
[ 10.618649] rtlwifi: Unknown symbol regulatory_hint (err -22)
[ 10.618682] rtlwifi: disagrees about version of symbol ieee80211_register_hw
[ 10.618696] rtlwifi: Unknown symbol ieee80211_register_hw (err -22)
[ 10.618798] rtlwifi: disagrees about version of symbol ieee80211_rate_control_unregister
[ 10.618816] rtlwifi: Unknown symbol ieee80211_rate_control_unregister (err -22)
[ 10.619322] rtlwifi: disagrees about version of symbol ieee80211_get_hdrlen_from_skb
[ 10.619346] rtlwifi: Unknown symbol ieee80211_get_hdrlen_from_skb (err -22)
[ 10.619401] rtlwifi: disagrees about version of symbol kfree_skb
[ 10.619415] rtlwifi: Unknown symbol kfree_skb (err -22)
[ 10.619435] rtlwifi: disagrees about version of symbol ieee80211_tx_status_irqsafe
[ 10.619449] rtlwifi: Unknown symbol ieee80211_tx_status_irqsafe (err -22)
[ 10.619496] rtlwifi: disagrees about version of symbol wiphy_rfkill_set_hw_state
[ 10.619510] rtlwifi: Unknown symbol wiphy_rfkill_set_hw_state (err -22)
[ 10.619579] rtlwifi: disagrees about version of symbol dev_kfree_skb_irq
[ 10.619593] rtlwifi: Unknown symbol dev_kfree_skb_irq (err -22)
[ 10.619620] rtlwifi: disagrees about version of symbol wiphy_to_ieee80211_hw
[ 10.619634] rtlwifi: Unknown symbol wiphy_to_ieee80211_hw (err -22)
[ 10.619650] rtlwifi: disagrees about version of symbol dev_kfree_skb_any
[ 10.619664] rtlwifi: Unknown symbol dev_kfree_skb_any (err -22)
[ 10.619690] rtlwifi: disagrees about version of symbol wiphy_rfkill_stop_polling
[ 10.619704] rtlwifi: Unknown symbol wiphy_rfkill_stop_polling (err -22)
[ 10.619721] rtlwifi: disagrees about version of symbol skb_pull
[ 10.619735] rtlwifi: Unknown symbol skb_pull (err -22)
[ 10.619768] rtlwifi: disagrees about version of symbol wiphy_apply_custom_regulatory
[ 10.619782] rtlwifi: Unknown symbol wiphy_apply_custom_regulatory (err -22)
[ 10.619823] rtlwifi: disagrees about version of symbol ieee80211_rate_control_register
[ 10.619837] rtlwifi: Unknown symbol ieee80211_rate_control_register (err -22)
[ 10.619932] rtlwifi: disagrees about version of symbol __netdev_alloc_skb
[ 10.619947] rtlwifi: Unknown symbol __netdev_alloc_skb (err -22)
[ 10.619968] rtlwifi: disagrees about version of symbol skb_trim
[ 10.619982] rtlwifi: Unknown symbol skb_trim (err -22)
[ 10.620011] rtlwifi: disagrees about version of symbol wiphy_rfkill_start_polling
[ 10.620025] rtlwifi: Unknown symbol wiphy_rfkill_start_polling (err -22)
[ 10.620051] rtlwifi: disagrees about version of symbol freq_reg_info
[ 10.620065] rtlwifi: Unknown symbol freq_reg_info (err -22)
[ 10.620097] rtlwifi: disagrees about version of symbol rate_control_send_low
[ 10.620111] rtlwifi: Unknown symbol rate_control_send_low (err -22)
[ 10.620129] rtlwifi: disagrees about version of symbol ieee80211_unregister_hw
[ 10.620143] rtlwifi: Unknown symbol ieee80211_unregister_hw (err -22)
[ 10.620218] rtlwifi: disagrees about version of symbol ieee80211_rx_irqsafe
[ 10.620232] rtlwifi: Unknown symbol ieee80211_rx_irqsafe (err -22)
[ 10.633725] rtlwifi: disagrees about version of symbol skb_put
[ 10.633760] rtlwifi: Unknown symbol skb_put (err -22)
[ 10.633811] rtlwifi: disagrees about version of symbol skb_dequeue
[ 10.633825] rtlwifi: Unknown symbol skb_dequeue (err -22)
[ 10.633848] rtlwifi: disagrees about version of symbol ieee80211_free_hw
[ 10.633861] rtlwifi: Unknown symbol ieee80211_free_hw (err -22)
[ 10.633883] rtlwifi: disagrees about version of symbol ieee80211_alloc_hw
[ 10.633895] rtlwifi: Unknown symbol ieee80211_alloc_hw (err -22)
[ 10.633943] rtlwifi: disagrees about version of symbol regulatory_hint
[ 10.633957] rtlwifi: Unknown symbol regulatory_hint (err -22)
[ 10.633988] rtlwifi: disagrees about version of symbol ieee80211_register_hw
[ 10.634001] rtlwifi: Unknown symbol ieee80211_register_hw (err -22)
[ 10.634020] rtlwifi: disagrees about version of symbol ieee80211_rate_control_unregister
[ 10.634034] rtlwifi: Unknown symbol ieee80211_rate_control_unregister (err -22)
[ 10.634056] rtlwifi: disagrees about version of symbol ieee80211_get_hdrlen_from_skb
[ 10.634069] rtlwifi: Unknown symbol ieee80211_get_hdrlen_from_skb (err -22)
[ 10.634118] rtlwifi: disagrees about version of symbol kfree_skb
[ 10.634131] rtlwifi: Unknown symbol kfree_skb (err -22)
[ 10.634150] rtlwifi: disagrees about version of symbol ieee80211_tx_status_irqsafe
[ 10.634162] rtlwifi: Unknown symbol ieee80211_tx_status_irqsafe (err -22)
[ 10.634208] rtlwifi: disagrees about version of symbol wiphy_rfkill_set_hw_state
[ 10.634222] rtlwifi: Unknown symbol wiphy_rfkill_set_hw_state (err -22)
[ 10.634287] rtlwifi: disagrees about version of symbol dev_kfree_skb_irq
[ 10.634300] rtlwifi: Unknown symbol dev_kfree_skb_irq (err -22)
[ 10.634326] rtlwifi: disagrees about version of symbol wiphy_to_ieee80211_hw
[ 10.634339] rtlwifi: Unknown symbol wiphy_to_ieee80211_hw (err -22)
[ 10.634355] rtlwifi: disagrees about version of symbol dev_kfree_skb_any
[ 10.634367] rtlwifi: Unknown symbol dev_kfree_skb_any (err -22)
[ 10.634393] rtlwifi: disagrees about version of symbol wiphy_rfkill_stop_polling
[ 10.634406] rtlwifi: Unknown symbol wiphy_rfkill_stop_polling (err -22)
[ 10.634421] rtlwifi: disagrees about version of symbol skb_pull
[ 10.634434] rtlwifi: Unknown symbol skb_pull (err -22)
[ 10.634466] rtlwifi: disagrees about version of symbol wiphy_apply_custom_regulatory
[ 10.634479] rtlwifi: Unknown symbol wiphy_apply_custom_regulatory (err -22)
[ 10.634685] rtlwifi: disagrees about version of symbol ieee80211_rate_control_register
[ 10.634704] rtlwifi: Unknown symbol ieee80211_rate_control_register (err -22)
[ 10.634802] rtlwifi: disagrees about version of symbol __netdev_alloc_skb
[ 10.634816] rtlwifi: Unknown symbol __netdev_alloc_skb (err -22)
[ 10.634839] rtlwifi: disagrees about version of symbol skb_trim
[ 10.634851] rtlwifi: Unknown symbol skb_trim (err -22)
[ 10.634883] rtlwifi: disagrees about version of symbol wiphy_rfkill_start_polling
[ 10.634896] rtlwifi: Unknown symbol wiphy_rfkill_start_polling (err -22)
[ 10.634922] rtlwifi: disagrees about version of symbol freq_reg_info
[ 10.634935] rtlwifi: Unknown symbol freq_reg_info (err -22)
[ 10.634967] rtlwifi: disagrees about version of symbol rate_control_send_low
[ 10.634980] rtlwifi: Unknown symbol rate_control_send_low (err -22)
[ 10.634998] rtlwifi: disagrees about version of symbol ieee80211_unregister_hw
[ 10.635011] rtlwifi: Unknown symbol ieee80211_unregister_hw (err -22)
[ 10.635086] rtlwifi: disagrees about version of symbol ieee80211_rx_irqsafe
[ 10.635099] rtlwifi: Unknown symbol ieee80211_rx_irqsafe (err -22)
[ 20.613467] ip_tables: © 2000-2006 Netfilter Core Team
[ 24.816143] net eth0: initializing cpsw version 1.12 (0)
[ 24.818518] net eth0: phy found : id is : 0x7c0f1
[ 24.818545] libphy: PHY 4a101000.mdio:01 not found
[ 24.823608] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 24.932474] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.896877] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[ 27.896955] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Does it look like a hardware malfunction of my BeagleBone ?
