I recently (3 months ago) got my beagleboard and after some hardware-
problems (and an RMA replacement) I installed the Angstrom Demo and
played around with the Beagle-Mojo.
I like to use the beagle as Web-/Samba-/ssh-/printer-Server but I get
some serious problems. When I start copying files from an usb-drive
connected to the beagle via usb-ethernet-adapter to a pc the beagle
stops working after some time. Browsing a samba-share or the webserver-
content from a pc speeds up the locking process.
In some cases the beagle doesn't lock up complete and I get the
following messages via rs232:
Clock mmchs_fck didn't enable in 100000 tries
BUG: soft lockup - CPU#0 stuck for 74s! [swapper:0]
hub 2-1:1.0: cannot reset port 3 (err = -110)
BUG: soft lockup - CPU#0 stuck for 108s! [dd:1889]
hub 2-1:1.0: Cannot enable port 3. Maybe the USB cable is bad?
hub 2-1:1.0: cannot disable port 3 (err = -110)
end_request: I/O error, dev sda, sector 159645759
Buffer I/O error on device sda1, logical block 19955712
sd 1:0:0:0: rejecting I/O to offline device
Buffer I/O error on device sda1, logical block 19005442
Buffer I/O error on device sda1, logical block 19016720
Buffer I/O error on device sda1, logical block 19987084
Buffer I/O error on device sda1, logical block 19988109
Buffer I/O error on device sda1, logical block 19988480
Buffer I/O error on device sda1, logical block 19989654
Buffer I/O error on device sda1, logical block 19990679
Buffer I/O error on device sda1, logical block 19991704
Buffer I/O error on device sda1, logical block 19992729
end_request: I/O error, dev sda, sector 103
Aborting journal on device sda1.
hub 2-1:1.0: hub_port_status failed (err = -110)
musb_h_ep0_irq 1091: no URB for end 0
usb 2-1.2: device v13b1 p0018 is not supported
usb 2-1.3: device v058f p6390 is not supported
sd 2:0:0:0: [sdb] Assuming drive cache: write through
But sometimes the beagle crashes completly.
I tried all currently available kernels from the angstrom-demo, tried
several kernels in combination with the mojo-project (from
http://www.rcn-ee.com/deb/kernel/beagle/hasty/) but none of them
worked. Some got me great ehternet speeds others took longer to crash
but all of them did crash.
I also changed nearly all hardware-components: usb-ethernet device
(USB200M Linksys, and another noname-adapter), the "powered" usb hub,
all usb cables but the mini-A-cable.
I only didn't change the sd-card, the beagle-powersupply (which was
bought from digi-key with the beagle), and the mini-A-adapter (nor the
beagle of course).
I tried everything with DVI/rs232 connected and not, but no change.
I would be really glad for every idea because I'm really stuck now.
Should I change the rest of the unchanged components? Is this a
hardware or a software problem?
