I have my beagle board running the 2.6.22 kernel from
http://code.google.com/p/beagleboard/wiki/BeagleSourceCode . I added a
USB ethernet dongle ($6 at Frys and it works. However, I keep
getting the USB port "turned off", as seen in console messages below:
# <3>hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
<6>usb 1-1: USB disconnect, address 2
<6>usb 1-1.4: USB disconnect, address 3
<6>usb 1-1.4.1: USB disconnect, address 4
<6>eth0: unregister 'asix' usb-ehci-omap.0-1.4.1, ASIX AX88772 USB 2.0
Ethernet
Ethernet
ping: sendto: Network is unreachable
As you can see, I am using a (powered) hub. I get the same results w/o
the hub. At first I thought is was due to inactivity, but I had a ping
running in the background and it still disconnected.
Any ideas?
Mark
