usb webcam can not open with this simple code
import cv2
# Open the webcam
cap = cv2.VideoCapture(0)
# Check if the webcam is successfully opened
if not cap.isOpened():
    print("Failed to open webcam.")
    exit(1)
# Capture a frame from the webcam
ret, frame = cap.read()
# Check if the frame is captured successfully
if not ret:
    print("Failed to capture frame.")
    exit(1)
# Display the captured frame
cv2.imshow("Webcam", frame)
cv2.waitKey(0)
# Release the webcam
cap.release()
cv2.destroyAllWindows()
Does the video device exist ?
If so, what is the user/group of the device.
If you are not running as root are you a member of the above group
sudo su
as root
and
I test this usermod as debian
ls /dev/video0 exist
and I try chmod +x file.py
and i also try the xrendr
export DISPLAY=:0.0
xrandr --output HDMI1
sudo apt-get install python3-opencv libopencv-videoio-dev libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
I also test this code
import cv2
Open the video capture device using V4L2
video_capture = cv2.VideoCapture(‘/dev/video0’, cv2.CAP_V4L2)
Check if the video capture device was successfully opened
if not video_capture.isOpened():
print(“Unable to open video capture device”)
exit()
while True:
# Read a frame from the video capture
ret, frame = video_capture.read()
# Check if the frame was successfully read
if not ret:
    print("Error reading frame from video capture")
    break
# Display the frame on the screen
cv2.imshow('Webcam', frame)
# Exit the loop if 'q' key is pressed
if cv2.waitKey(1) & 0xFF == ord('q'):
    break
Release the video capture and close the window
video_capture.release()
[ WARN:0] global …/modules/videoio/src/cap_v4l.cpp (1004) tryIoctl VIDEOIO(V4L2:/dev/video0): select() timeout.
and also
import cv2
GStreamer pipeline
pipeline = “v4l2src device=/dev/video0 ! videoconvert ! video/x-raw,format=BGR ! appsink”
Create a VideoCapture object using the GStreamer pipeline
cap = cv2.VideoCapture(pipeline, cv2.CAP_GSTREAMER)
Check if the VideoCapture object was successfully initialized
print(“Failed to open camera.”)
exit(1)
Read and display frames from the camera
while True:
if not ret:
    break
# Display the frame using imshow
# Check for the 'q' key to exit
    break
Release the VideoCapture object and close any open windows
cap.release()
all of that work on ubuntu but not work on debian 9.9 beagle bone black
Ok just had a quick play.
This is using a newer OS version than you, clean install, just downloaded.
BeagleBoard.org Debian Bullseye Xfce Image 2023-05-18
I installed python3-opencv which pulled in the dependencies.
This is what I am running (see below). I have no display so can’t be sure what it is capturing, but I get no errors.
I had to add the cap.set() calls though to make it work. Just cv2.VideoCapture() on its own does not work.
#!/usr/bin/python3
import cv2
cap = cv2.VideoCapture("/dev/video0", cv2.CAP_V4L2)
cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter_fourcc('M', 'J', 'P', 'G'))
width = 320
height = 240
cap.set(cv2.CAP_PROP_FRAME_WIDTH, width)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, height)
        print('Unable to open video capture device')
        exit()
while(True):
        ret,frame = cap.read()
        if not ret:
                print('Error reading frame from video capture')
                break
        else:
                print('Got frame')
        if cv2.waitKey(1)&0xff == ord('q'):
                break
cap.release()
I suggest firstly you try setting the mode, and resolution as I have done. It that still fails I would suggest updating your OS.
Bullseye XFCE (with graphical desktop) for BeagleBone AI-64 via microSD card
it doesn’t work for beagle bone black
That’s totally expected, the BeagleBone Black and BeagleBone AI-64 use a different processor…
Grab an image from here, for your BeagleBone Black (am335x): Debian 11.x (Bullseye) - Monthly Snapshot - 2023-07-01
after that install we have to build opencv with cmake through cross compile
