I’m a beginner at Linux and just had a question about using a WiFi USB dongle with the BeagleBoard Black. I want to be able to add a wireless USB stick to the BBB with the out-of-the-box Angstrom loaded on the board. Does anyone know a supported USB device that will work with what I want? If so, how exactly would I get it to work with the stock Angstrom on the BBB?
Thanks!
Tommy
I'm a beginner at Linux and just had a question about using a WiFi USB
BBB?
With the exception you should use the default IP connection at 192.168.7.2
over USB or find the IP address some other way than using the serial port
(unless you have a cable), the instructions and USB dongle at
WiFi | BeagleBone | Adafruit Learning System should work.
