USB2412 oscillator
in a clone beaglebone the USB2412 oscillator doesn’t work.
the components and layout are the same of the original.
Someone know this problem and can give me some suggestion?
At the moment the beaglebone isn’t initialized, is just powered
and the other oscillators work correctly.
Regards
Mariano
Need to make sure you have the correct crystal and capacitors. The layout could be an issue as well. Make sure the USB2412 is not in reset.
I have never had an issue with the oscillator…
