Hey… Can anyone out there provide some info on setting up and starting timer 4?
I’d like to run it at 10MHz to use it as a clock for a LED driver IC
I’ve been googling for a while and haven’t been able to find much.
I don't know what driver IC you're using, but I used PRU as the clock
signal generator for TLC5946. Here you will find my implementation of
the driver for the chip: https://github.com/piranha32/IOoo/
You should be able to easily adapt the code for other chips from the family.
Jacek.
