use mass storage to send files from host to device
I’m stuck on this and while I don’t expect anyone to answer, I would greatly appreciate it.
I understand that the g_multi gadget has backing storage for the mass storage device in /var/cache/doc-beaglebone-getting-started.
I know that if I want to read from this storage, I have to do it while the storage is not in use.
I think I should be able to mount and read the backing storage before am335x_evm.sh is run (this is the code which configures the g_multi gadget and enables it). However, when I do this the contents of
the backing storage disappear. What could be going wrong?
For reference, this is how i’m attempting to read the storage:
I edited am335x_evm.sh to make the device read/write
I pointed /var/local/bb_usb_mass_storage.img to another file: /root/data/backing_storage - a fat32 partition with 512 byte sectors starting at sector 2048
I created the following directory: /mnt/loop
losetup -o 1048576 /dev/loop0 /root/data/backing_file
mkdosfs -F 32 /dev/loop0
mount -t vfat /dev/loop0 /mnt/loop
ls /mnt/loop >> /var/log/messages
umount /dev/loop0
losetup -d /dev/loop0
I’m not sure what’s going on with g_multi for you there. But I will say this. There are other, probably better suited options for moving files over to the device.
I’ve used g_multi in the past and have always found it problematic for this platform. So personally, I dedicated a cheap netbook to operate as a server for the beaglebone(black), and just used NFS shares, and Samba for my dev workstation.
Another option would be to use ssh file transfers, after running a ssh server on the beaglebone.
It really depends on what you’re trying to do, and your dev system.
  Unless the OP is running a highly customized OS on the Beagle, SSH (and
SFTP) should be available natively.
{Disconnecting CAT-5 cable from BBB, using just the USB to my Win10
computer}
FileZilla in SFTP mode connects with no problem...
WinSCP connects with no problem...
PsFTP connects with no problem...
C:\Users\Wulfraed>psftp debian@beaglebone
Using username "debian".
Pre-authentication banner message from server:
Debian GNU/Linux 10
BeagleBoard.org Debian Buster IoT Image 2020-04-06
Support: Beagleboard:BeagleBoneBlack Debian - eLinux.org
default username:password is [debian:temppwd]
End of banner message from server
debian@beaglebone's password:
Remote working directory is /home/debian
debian@beaglebone:~$ uname -a
Linux beaglebone 4.19.94-ti-r42 #1buster SMP PREEMPT Tue Mar 31 19:38:29
UTC 2020 armv7l GNU/Linux
Thank you William and Dennis for the feedback.
It turns out that executing the command ‘mkdosfs -F 32 /dev/loop0’ prior to attempting to read the backing storage was incorrect. This creates a new file system and overwrites the old one. I should only have used that command once when the backing storage was created.
Hi KaneLee,
How do you enable write mode for mass storage by modifying am335x_evm.sh? Thank you.
I found how to enable write mode, it’s to change the value 1 to 0 for usb_ms_ro.
