Folks,
On my journey to pull apart the BeagleY-AI features, I’ve embarked on building a multi-stage lead-acid battery charger.
With @RobertCNelson’s kind help, I was able to come to the bottom of an I2C problem and get I2C0 running, which is great.
This time, I’m trying to generate a variable duty cycle PWM signal out of PWM0 at GPIO12, having loaded the appropriate overlay (/overlays/k3-am67a-beagley-ai-pwm-ecap0-gpio12.dtbo) and rebooted.
Now; my issue is two fold:
- The RPi module: knocked together the following test code:
#!/usr/bin/env python
import RPi.GPIO as GPIO
from time import sleep
ledpin = 12 # PWM pin connected to LED
GPIO.setwarnings(False) #disable warnings
GPIO.setmode(GPIO.BOARD) #set pin numbering system
GPIO.setup(ledpin,GPIO.OUT)
pi_pwm = GPIO.PWM(ledpin,1000) #create PWM instance with frequency
pi_pwm.start(0) #start PWM of required Duty Cycle
while True:
for duty in range(0,101,1):
pi_pwm.ChangeDutyCycle(duty) #provide duty cycle in the range 0-100
sleep(0.01)
sleep(0.5)
for duty in range(100,-1,-1):
sleep(0.01)
sleep(0.5)
Running it returns:
ahmed@beagley:~$ ./testpwm.py
Traceback (most recent call last):
File "/home/ahmed/./testpwm.py", line 2, in <module>
File "/usr/lib/python3/dist-packages/RPi/GPIO/__init__.py", line 23, in <module>
from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
Which I guess is to be expected, but what’s the way round this, to get some PWM out of GPIO12 ?
- What other possibilities are there to generate PWM output in C code? what are the relevant device files and config structures to use?
Thanks in advance,
Ahmed.
So here’s the working theory…
voodoo@BeagleBone:~$ sudo beagle-version | grep UBOOT
UBOOT: Booted Device-Tree:[k3-am67a-beagley-ai.dts]
UBOOT: Loaded Overlay:[k3-am67a-beagley-ai-pwm-ecap0-gpio12.kernel]
On bootup, we need to export pwm-ecap0-gpio12
so a usable symlink:
voodoo@BeagleBone:~$ sudo beagle-pwm-export --pin hat-32
How does someone know to run --pin hat-32
i need to modify it just figure out which overlay was loaded…
This creates this directory:
voodoo@BeagleBone:~$ tree /dev/hat/pwm/
/dev/hat/pwm/
└── GPIO12 -> /sys/devices/platform/bus@f0000/23100000.pwm/pwm/pwmchip0/pwm0/
2 directories, 0 files
Inside GPIO12 we get:
voodoo@BeagleBone:~$ tree /dev/hat/pwm/GPIO12
/dev/hat/pwm/GPIO12
├── capture
├── duty_cycle
├── enable
├── period
├── polarity
├── power
│ ├── async
│ ├── autosuspend_delay_ms
│ ├── control
│ ├── runtime_active_kids
│ ├── runtime_active_time
│ ├── runtime_enabled
│ ├── runtime_status
│ ├── runtime_suspended_time
│ └── runtime_usage
└── uevent
2 directories, 15 files
So:
Becomes: sudo beagle-pwm-export --pin hat-32
echo 1000 > /dev/hat/pwm/GPIO12/period
echo 1 > /dev/hat/pwm/GPIO12/enable
Then finally:
echo 500 > /dev/hat/pwm/GPIO12/duty_cycle
Much obliged - extensive and authoritative as usual.
I’ve tested it with some C, and it works a treat. Next task: feed this into the Node.Red interface I’m using to control the charging process, and voila: that’s my PWM controller done
Thanks again,
Ahmed.
Okay, i have the rpi number working:
sudo beagle-pwm-export --pin gpio14
This needs a few changes, so it’ll be apt update/upgrade away… in a few days…
