if anyone want to know how to use
your own HDTV on the Beagleboard here
is an tutorial how to do it.
I'am not an linux-expert and i had found out it
with a little bit experimenting with beagle and tv
so it worked for me.
If anyone had a better solution or see a mistake, he
can say it!
So setup a LCD TV with Beagle you must:
1.Read out your EDID from your LCD TV.
2.Convert the xFree timings to framebuffer timings
3. Add the new framebuffer modeline to
/kernelrootfolder/drivers/video/modedb.c
4. compile the kernel and use your resolution
Details:
1. You can readout your EDID with Monitor Asset Manager or Powerstrip
both available on http://www.entechtaiwan.com/util/ (for Windows) or
with xvidtune (Linux)
I have done it with xvidtune
Then you get all supported Resolutions with its
modelines.
One XFree Modeline looks like:
"1280x720" 74,250 1280 1344 1472 1664 720 723 728 748
DCF HR SH1 SH2 HFL VR SV1 SV2
VFL
2. Then you must convert XFree86 timing values info to frame buffer
device timings
1) Pixelclock:
pixclock = 1000000 / DCF
2) horizontal timings:
left_margin = HFL - SH2
right_margin = SH1 - HR
hsync_len = SH2 - SH1
3) vertical timings:
upper_margin = VFL - SV2
lower_margin = SV1 - VR
vsync_len = SV2 - SV1
3. Then you insert the modeline to the modedb.c which is in the
kernel
directory in /drivers/video/
The whole Block looks like:
/* 1280x720 @ 60 Hz, 45 kHz hsync, CEA 681-E Format 4 */
"hd720", 60, 1280, 720, 13468, 220, 110, 20, 5, 40, 5, <--
this
is the modeline which from the script hd720 is the an example for a
"name"
0, FB_VMODE_NONINTERLACED
You must insert in in the "static const struct fb_videomode modedb[]"
block
This is an example from the Koen Kooi HD patch on:
http://cgit.openembedded.net/cgit.cgi?url=openembedded/commit/&id=687…
5. Compile your kernel as always.
6. Here are the bootargs for the nand boot:
setenv optargs 'init=/init omapdss.def_disp=dvi
omapfb.mode=dvi:hd720-24@60'
I found out that not all EDID-information you get from the LCDs are
correct.
But when a resolution is working with your pc oder notebook it should
work on the beagleboard too!
I know that it not the best method. But it works!!
A better method would be to read the EDID values direct from the
driver
of the kernel and choose the best Resolution. There is a experimental
patch on:
http://groups.google.com/group/beagleboard/browse_thread/thread/5274e…
I hope it helps!!
Regards
Michael
Here are my resources:
[1] http://store.smpte.org/product-p/smpte%200296m-2001.htm
[2] http://www.ce.org/Standards/browseByCommittee_2641.asp
[3] http://en.wikipedia.org/wiki/Extended_display_identification_data
[4]
<http://groups.google.com/group/beagleboard/browse_thread/thread/
5274e…>
[5] http://www.entechtaiwan.com/util/moninfo.shtm
[6]
<http://cgit.openembedded.net/cgit.cgi?url=openembedded/commit/
&id=687…>
[7]
http://git.kernel.org/?p=linux/kernel/git/tmlind/linux-omap-2.6.git;a…
<http://git.kernel.org/?p=linux/kernel/git/tmlind/linux-
omap-2.6.git;a…>
[8] http://www.bat.org/~tomba/linux-omap.html
<http://www.bat.org/~tomba/linux-omap.html>
