I want to use my Beaglebone Black as a standalone (not connected to internet) wireless server, to which multiple clients can connect and request a service.
I googled it out, and found that for this a usb wifi adapter, having the capability to run in a Master mode is required.
I googled for such usb devices but could not get a concrete answer.
Pls anyone help me on the same and suggest which usb wifi device can serve my purpose !
Thanks John for the reply,
as per your advice I searched about Wif Direct and came to know that it is actually
somewhat Ad-hoc wireless operation. I want to use Linux based laptops as client to the Beaglebone black (acting as a wifi server running latest Ubuntu image).
With respect to above scenario I have two questions:
1> Does wifi radio that is available in Laptop by default (running on Linux) can be configured to Ad-Hoc mode
2> Does the wifi-adapters listed here can be configured as Ad-hoc on Beaglebone black.
I am a beginner so pls excuse if any unrelated question appears!
Wi-Fi Direct is a software layer over Ad-hoc by adding a Software Access Point.
I am also interested in this. I just ordered a Beagleboard Black, also a TPE-N150USB adapter from thinkpenguin.com which is listed as supporting Master Mode with hostapd. But I don’t know if that will work with the Beagleboard.
It’s not clear if any of the adapters listed on the Beagleboard page support master mode; I suspect not.
if this thing can be useful to you, I have just set up an ad-hoc wifi network between BBB and macbook.
I use a tp-link tl-WN722N (that mounts the AR9271 atheros chip).
With this wifi-interface is only necessary to install atheros driver and configure the wifi net. nothing more.
Here my configuration lines to /etc/network/interfaces
