I have successfully created a read-only FS with the latest debian (2015-03-01) image and figured out how to get a USB drive mounted as well as the network running, however I can’t figure out how to use the UARTS, specifically /dev/ttyS0. I assume that the fact that the system is read only is the problem but I am not sure how I can “mount” the tty as read-write. Does anyone have any suggestions?
For reference my fstab looks like this:
/etc/fstab: static file system information.
You might want to mount your /dev as a tmpfs? A quick google gave me this:
https://sites.google.com/site/linuxpendrive/rorootfs
cheers,
Nuno
I tried that, thanks, but it didn’t work. Maybe I didn’t have the syntax correct. Can anyone suggest the correct syntax?
After reading many articles I have made the USB drive and networking function but I really can’t find any information specific to this problem.
Correction. I should have said /dev/ttyS1 above not S0.
