Hello
I want use ti-ads8688 iio driver as a kernel module. I am using Beaglebone Black.
I wrote below Makefile for this work.
obj-m+=ti-ads8688.o
all:
make -C /lib/modules/$(shell uname -r)/build/ M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build/ M=$(PWD) clean
ti-ads8688.ko file correctly generated and i load it with insmod command. But there is not module in iio devices, as you can see in below:
debian@beaglebone:~/work/phase1$ ls /sys/bus/iio/devices/iio\:device0
buffer in_voltage1_raw in_voltage4_raw in_voltage7_raw power uevent
dev in_voltage2_raw in_voltage5_raw name scan_elements
in_voltage0_raw in_voltage3_raw in_voltage6_raw of_node subsystem
am i miss something? I also add in my devicetree below unit:
adc@0 {
compatible = "ti,ads8688";
reg = <0>;
spi-cpha;
spi-max-frequency = <100000>;
I think the problem is with my device tree, but I don't know how fix it.
