Using P8_11 as digital input with internal pull up enabled
I have been trying to configure p8_11 as digital input with internal pull up. I am using BBB rev C and followed different examples; even I used the dts generating tools, then compile it to create dto and then put it into uenv.txt but it seems after boot up it does not enable the pullup. If I use a 10k external pullup, it works fine though.
I looked at the schematic and did not notice any other circuit pulling that pin low.
I appreciate your help in resolving this issue.
Thank you in advance!
Try
/boot/uEnv.txt
LINUX file names are case-sensitive.
Regards
Thank you!
You are correct, and I used uEnv.txt. I wrote it wrong in my text. This is what I did in a bit more details:
Following instructions in BeagleBone Black Device-Tree Overlay Generator
I generated the .dts file for P8_11 defined as GPIO1_13, input, with pull-up.
bspm_P8_11_37-00A0.dts file content is:
  • This is a template-generated file from BoneScript
/dts-v1/;
/plugin/;
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
part_number = “BS_PINMODE_P8_11_0x37”;
exclusive-use =
    "P8.11",
    "gpio1_13";
fragment@0 {
    target = <&am33xx_pinmux>;
    __overlay__ {
        bs_pinmode_P8_11_0x37: pinmux_bs_pinmode_P8_11_0x37 {
            pinctrl-single,pins = <0x034 0x37>;
fragment@1 {
    target = <&ocp>;
    __overlay__ {
        bs_pinmode_P8_11_0x37_pinmux {
            compatible = "bone-pinmux-helper";
            status = "okay";
            pinctrl-names = "default";
            pinctrl-0 = <&bs_pinmode_P8_11_0x37>;
Then I used the following command to compile it and generate .dtbo file
dtc -O dtb -o /lib/firmware/bspm_P8_11_37-00A0.dtbo -b 0 -@ /lib/firmware/bspm_P8_11_37-00A0.dts
I could not follow the rest of the instruction stated in that page since my BBB does not have bone_capemgr folder. If I am not wrong, I read that after a certain Debian kernel version on, they do not offer that folder structure.
So, instead I added the path to generated .dtbo in /boot/uEnv.txt, as shown below:
I made sure the following lines are in the uEnv.txt
###Master Enable
enable_uboot_overlays=1
###Additional custom capes
uboot_overlay_addr4=/lib/firmware/bspm_P8_11_37-00A0.dtbo
The result is that P8_11 does not seem to have internal pull-up enabled. When I read the pin value in /sys/class/gpio/gpio45 it reads ‘0’ (low) and if I pull it up externally it reads ‘1’.
Have you tried 0x17 instead of 0x37 ?
No idea what the receiver enable bit does, but it might be overriding the pullup in some way.
This bit determines input or output state.
@Sia
Do you load cape-universal blob? (This may override your setting, or block it since the pin is claimed.)
I don’t deal with such stuff. Instead I use the in-source pinmuxing feature of libpruio.
Regards
Thank you DTJF and Benedict!
Your comments helped me and I think I have fixed it now. I explain it here, although it might not be precise enough.
Using that DTS generator website, as long as I create only one dts and test them one at a time, it works fine. (Note that as DTJF said, we should not enable cape_universal).
The problem arises when I create two .dts, and consequently its .dtbo file, for two different GPIOs, e.g., P8_11 and P8_13. What I was doing wrong was that I put them in uEnv.txt one after another, like shown below:
dtb_overlay=/lib/firmware/bspm_P8_11_37-00A0.dtbo
dtb_overlay=/lib/firmware/bspm_P8_13_37-00A0.dtbo
This made none of them work! I do not know the reason though.
Then I tried to combine them all in one .dts. I did miss one part and it was in this part:
exclusive-use =
“P8.09”,
“P8.11”;
It does not work this way, I had to add a couple of more lines under this related to the gpio numbers. This is what I did and worked for me:
exclusive-use =
“P8.09”,
“P8.11”,
“P8.13”,
	/* the hardware IP uses */
	"gpio1_13",
	"gpio0_23";
I got the idea from the following link:
I hope it works as I add the rest of the GPIOs to it.
Cheers,
Not seen that website to generate overlay files. Shame there is no date on it to show when it was last updated.
I have never used ‘fragment’ or ‘__overlay__’ when writing overlay files, and none of the official BBB overlays use them it seems either.
Also it seems a pretty good idea to add something like this, which is done by the official overlays.
&{/chosen} {
        overlays {
                YOUR_CUSTOM_NAME_HERE.kernel = __TIMESTAMP__;
You can then check easily to see if the overly gets loaded by doing
 ls /sys/firmware/devicetree/base/chosen/overlays/
There’s a dts source generator creating pinmuxing files and compiling them to /lib/firmware. After setting some meta data, specify the desired modes like
M(P8_11) = CHR(7 + PU)  ' example: pin 11 at header P8 in mode 7 (Gpio) as input (pull-up resistor)
M(P8_13) = CHR(7 + PU)  ' example: pin 13 at header P8 in mode 7 (Gpio) as input (pull-up resistor)
and finaly compile the code and execute it as admin (for write access in /lib folder).
Find a description at libpruio: src/config/dts_custom.bas File Reference
Regards
