Hi everyone,
I’m working on a project using PRU0 on the BeagleBone Black Industrial, and I’d like to confirm if the following pin configuration is valid:
- P8_11 set to mode 6 as
pr1_pru0_pru_r30_15(output via R30, bit 15) - P8_15 set to mode 5 as
pr1_pru0_pru_r31_15(input via R31, bit 15)
From what I understand, R30 and R31 are independent registers, so it should be possible to use these two pins simultaneously without conflict. I plan to use R30 to control an output signal on P8_11 and R31 to read an input signal on P8_15.
I’ve reviewed the pinout and it seems that these two pins do not overlap in terms of functionality or mux modes. However, I wanted to check with the community to ensure I’m not missing anything before I proceed with the configuration and code.
Has anyone worked with a similar setup, or can confirm that this approach will work correctly?
Additionally, if there are any potential issues or conflicts I should be aware of when using PRU0 in this configuration, I’d appreciate the advice!
Thanks in advance for your help.
Best regards,
Maciej
