So I am trying to use Playstation Eye’s microphone array to perform some sound source localization tasks on my beaglebone blue.
I am using an ubuntu image from: https://jh.app.box.com/v/530-707-Dropbox
And I am using a software called HARK: https://www.hark.jp/
I suspect Playstation Eye is not working because when I try to use arecord command like:
arecord -D plughw:CARD=CameraB409241,DEV=0 -d 10 /tmp/test-mic.wav
to record a .wav file with playstation eye plugged in, it creates a .wav file (whose size is fixed, I remember it’s 44 bytes)and never ends.
When I run the command with a regular webcam plugged in, it exits normally with the audio file saved.
I am wondering if anyone else has worked on similar topic before.
Thank you!
Best,
Danbing
