I would like to use the UARTs on beaglebone black or at least one of them. I found a big variety of information concerning this topic. Unfortunately many of it seems quite outdated.
- the hardware is supported by the Kernel via device-tree and more specific functions by overlays
- i found instructions to build own device trees
- pins must be configured by config-pin?
- Sometimes the resulting devices are called /dev/ttyOx, sometimes /dev/ttySx
- i found information that dt overlays are managed by uboot instead of the kernel itself now
- there is a library (adafruit) for using the uarts in python. But it has something to do with devicetrees too?
- could it be that the ttyOx devices are related to the adafruit library?
Im using the am335x-debian-11.7-iot-armhf-2023-09-02-4gb.img.xz image.
What is the prefered way to use the uarts today?
My conclusion was that it should be enough to append
uboot_overlay_addr4=BB-UART2-00A0.dtbo
to /boot/uEnv.txt. Indeed i found the following message while booting:
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-UART2-00A0.dtbo ...
1017 bytes read in 4 ms (248 KiB/s)
So i expected to be able to use /dev/ttyS2.
But it isn’t.
