This usr led stays up after a while of start flashing, help please!
-Pablo Oyarzo.
-Pablo Oyarzo.
I’m following the Adafruit tutorial that worked with me last time i flashed! Don’t know why doesn’t work now…
-Pablo Oyarzo.
OK. Not sure what you are doing different then. Your description is a little thin. It sounds to me like it does not like the flasher image you put on the card.
It could make any error that this is not my first time i save an image in the SD card and i’m working with windows?
-Pablo Oyarzo
It needs to eb a flasher image. One that flashes the eMMC.
Make sure you have unzipped it.
The procedure found at the link I sent works. The 9_4 image is the current production image. Try that image using your procedure.
If that does not work, try the 9_4 image using the procedure at the link.
Like this one http://prntscr.com/2aql03 right?
-Pablo Oyarzo
The image is what you use to create the SD card using the Diskimager tool that programs the eMMC.
The image is found at https://s3.amazonaws.com/angstrom/demo/beaglebone/BBB-eMMC-flasher-2013.09.04.img.xz
Just follow the instructions on the link I sent.
