I'm on a BBW with vanilla Angstrom distribution. Valgrind fails like this:
root@bboneumh2:~/software# ~/local/bin/valgrind --leak-check=yes ./my_program
==13719== Memcheck, a memory error detector
==13719== Copyright (C) 2002-2012, and GNU GPL'd, by Julian Seward et al.
==13719== Using Valgrind-3.8.1 and LibVEX; rerun with -h for copyright info
==13719== Command: ./heat_and_water_meter
==13719==
valgrind: Fatal error at startup: a function redirection
valgrind: which is mandatory for this platform-tool combination
valgrind: cannot be set up. Details of the redirection are:
valgrind:
valgrind: A must-be-redirected function
valgrind: whose name matches the pattern: memcpy
valgrind: in an object with soname matching: ld-linux.so.3
valgrind: was not found whilst processing
valgrind: symbols from the object with soname: ld-linux.so.3
valgrind:
valgrind: Possible fixes: (1, short term): install glibc's debuginfo
valgrind: package on this machine. (2, longer term): ask the packagers
valgrind: for your Linux distribution to please in future ship a non-
valgrind: stripped ld.so (or whatever the dynamic linker .so is called)
valgrind: that exports the above-named function using the standard
valgrind: calling conventions for this platform. The package you need
valgrind: to install for fix (1) is called
valgrind:
valgrind: On Debian, Ubuntu: libc6-dbg
valgrind: On SuSE, openSuSE, Fedora, RHEL: glibc-debuginfo
valgrind:
valgrind: Cannot continue -- exiting now. Sorry.
I've installed libc6-dbg as it says. Same problem.
While installing libc6-dbg, opkg complains like this:
bash-dbg: unsatisfied recommendation for ncurses-libtinfo-dbg
libc6-dbg: unsatisfied recommendation for libsegfault-dbg
libc6-dbg: unsatisfied recommendation for eglibc-thread-db-dbg
libc6-dbg: unsatisfied recommendation for eglibc-extra-nss-dbg
libc6-dbg: unsatisfied recommendation for libcidn-dbg
But trying 'opkg install eglibc-thread-db-dbg' says its an unknown
package.
Any clues?
Britton
