Hello
I have built the Yocto gatesgarth image for Beaglebone black. Then I loaded the image in SD card and booted with beagle.
Is there any way to check whether the image is built and working with beagle correctly?
Please suggest.
Note: I don’t have UART to usb converter with me.
Thanks.
amf99
April 19, 2021, 3:43pm
2
The following applies if you have BBB w/o wireless, other wise you have to build with wpa_supplicant and firmware.
if you have this in conf/local.conf, you should be able to ssh in as root without a password (been a while, going from memory)
EXTRA_IMAGE_FEATURES = “debug-tweaks”
adding this to conf/local.conf will set root password
INHERIT += “extrausers”
EXTRA_USERS_PARAMS = "usermod -P rootpassword root; "
you will need to have openssh-server or equivalent for ssh
I tried with debug-tweaks option. I have built the image with openssh-sftp-server and booted BBB.
But still It is not working for me. I am not able to connect with BBB through ssh from my computer(Ubuntu).
Note: I am building using core-minimal-image
Any support please.
amf99
April 20, 2021, 8:10pm
4
short answer, yes yocto gatesgarth branch does work on BBB,
However I have two meta- bbb and jumpnow from jumpnowtek,
I can ssh in as root with a password (provided in local.conf)
