Hello. I have an BeagleBoard-Xm, in the board I get REV B 00. but when
I run demo xMTest 20100820 I get Rev A.
Texas Instruments X-Loader 1.4.4ss (Aug 19 2010 - 02:49:27)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Aug 20 2010 - 20:50:46)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C er
ror.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #2fae00011ff00000015739eb0a02300d
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
** Unable to read "boot.scr" from mmc 1:1 **
reading user.scr
755 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
mmc1 is available
reading ramdisk.gz
19960110 bytes read
reading uImage
3190568 bytes read
Booting from ramdisk ...
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3190504 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
done, bootin
g the kernel.
SO load hangs here..
Do I have to update the firmware? Can this be the cause of
malfunction?
I would appreciate any help..
Greetings
