H all,
was is the max video resolution of beagleboard???
Is possible have an resolution video of 1080p??
regards
geardo di iorio
H all,
regards
geardo di iorio
2048x2048
regards,
Koen
Hi Gerardo,
In answer to your second question, the maximum video clock will rule
out a number of the standard 1080p modes. You should be able to get
1080p at 24 and 25Hz working. If you play around with blanking you
might get lucky and get 30p working with some output devices.
According to the DSS2 documentation the maximum video clock is 86.5MHz
with the OMAP2_DSS_USE_DSI_PLL option enabled.
Christopher.
