Normally using vcan (a virtual CAN bus without physical CAN interface) is not a big deal. It’s contained in SocketCAN and I am used to work with both types of CAN on my BeagleBones.
Very strange, I can not manage to get vcan to work on BeaglePlay. Unfortunately the vcan driver is not contained on available BeaglePlay Images.
(beagleplay-emmc-flasher-debian-11.8-xfce-arm64-2023-10-07-10gb.img)
modprobe -v vcan
modprobe: FATAL: Module vcan not found in directory /lib/modules/5.10.168-ti-arm64-r111
Ok, I thought: Solution for this is clear → Get the corresp. Linux headers & kernel source, then compile the missing driver vcan.ko and install it at /lib/modules/5.10.168-ti-arm64-r111/kernel/drivers/net/can/
Result OK: (driver loaded)
modprobe -v vcan
insmod /lib/modules/5.10.168-ti-arm64-r113/kernel/drivers/net/can/vcan.ko
lsmod | grep can
vcan 20480 0
can_raw 28672 0
can 28672 1 can_raw
Very surprising, after creating a virtual CAN interface with:
ip link add name vcan0 type vcan
ip link set dev vcan0 up
I get a weird interface back with ??AMPR NET/ROM??
ifconfig vcan0
vcan0: flags=65<UP,RUNNING> mtu 0
netrom txqueuelen 1000 (AMPR NET/ROM)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
And of course, CAN utils do fail:
candump vcan0
bind: No such device
I have no idea what’s wrong in here. Tried with different debian kernel versions, but no change.
