Virtual Ethernet and Serial Port not working for me on the latest software version
Hello, after updating the OS of my BeagleV-Fire to Debian 13 (Trixie) v6.12.x and while being on the latest gateware, bbb.io-gateware/unknown,unknown,now 1.20260721.1-0~trixie+20260722 all [installed], virtual connections no longer work. I can no longer SSH via 192.168.7.2 and my Beagle does not enumerate as a COM port. In the meantime, I have been connecting via a physical RJ45. In comparison, the virtual connections worked in the out of the box scenario. I followed the instructions here: USB-C problems after gateware change - #4 by fredrikBB , to no avail. Any ideas?
Were you using Ubuntu before?
Something tells me that your USB Gadgets got disabled in Debian 13…
no this is a current regression in 6.12.x branch, i’m looking into it..
In the OOB experience I was on Ubuntu – it came default. Interestingly, when I checked systemctl status bb-usb-gadgets.service I received output which said “No USB Device Controller available”
○ bb-usb-gadgets.service - BeagleBoard.org USB gadgets
     Loaded: loaded (/usr/lib/systemd/system/bb-usb-gadgets.service; enabled; preset: enabled)
     Active: inactive (dead) since Mon 2026-08-03 03:59:19 UTC; 23h ago
 Invocation: 60cc7dd590664176afb22664ea870d9e
    Process: 381 ExecStartPre=/sbin/modprobe libcomposite (code=exited, status=0/SUCCESS)
    Process: 399 ExecStart=/usr/bin/bb-start-usb-gadgets (code=exited, status=0/SUCCESS)
        CPU: 486ms
Aug 03 03:59:17 BeagleV systemd[1]: Starting bb-usb-gadgets.service - BeagleBoard.org USB gadgets...
Aug 03 03:59:18 BeagleV bb-start-usb-gadgets[399]: bb-usb-gadgets: bb-start-acm-ncm-rndis-old-gadget
Aug 03 03:59:18 BeagleV bb-start-usb-gadgets[417]: usb_gadget: Looking for libcomposite
Aug 03 03:59:18 BeagleV bb-start-usb-gadgets[417]: usb_gadget: Setting up g_multit through configfs
Aug 03 03:59:19 BeagleV bb-start-usb-gadgets[417]: usb_gadget: No USB Device Controller available
Aug 03 03:59:19 BeagleV systemd[1]: bb-usb-gadgets.service: Deactivated successfully.
Aug 03 03:59:19 BeagleV systemd[1]: Started bb-usb-gadgets.service - BeagleBoard.org USB gadgets.
Could you post the first 4 seconds of your dmesg for us, please?
@RobertCNelson: The MUSB driver is present in kernel 6.12
Attached are the first for seconds of dmesg. Posting again as previous post is in approval limbo
Dmesg Log
[ 0.000000] Linux version 6.12.48-linux4microchip+fpga-2025.10-20260725-gace63b6647f4 (root@runner-y65kxtsmq-project-69822087-concurrent-0) (riscv64-linux-gnu-gcc (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP Sat Jul 25 22:09:03 UTC 2026
[ 0.000000] Machine model: BeagleBoard BeagleV-Fire
[ 0.000000] SBI specification v1.0 detected
[ 0.000000] SBI implementation ID=0x8 Version=0x10002
[ 0.000000] SBI TIME extension detected
[ 0.000000] SBI IPI extension detected
[ 0.000000] SBI RFENCE extension detected
[ 0.000000] SBI SRST extension detected
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000020000000 (options ‘115200n8’)
[ 0.000000] printk: legacy bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000c4000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node non-cached-low-buffer, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000c4000000..0x00000000c7ffffff (65536 KiB) nomap non-reusable non-cached-low-buffer
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000001412000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node non-cached-high-buffer, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000001412000000..0x0000001421ffffff (262144 KiB) nomap non-reusable non-cached-high-buffer
[ 0.000000] OF: reserved mem: 0x0000000084000000..0x0000000087ffffff (65536 KiB) nomap non-reusable region@84000000
[ 0.000000] OF: reserved mem: 0x00000000d8000000..0x00000000d9ffffff (32768 KiB) nomap non-reusable buffer@d8000000
[ 0.000000] OF: reserved mem: 0x00000000c8000000..0x00000000c9ffffff (32768 KiB) nomap non-reusable buffer@c8000000
[ 0.000000] OF: reserved mem: 0x0000000088000000..0x0000000089ffffff (32768 KiB) nomap non-reusable buffer@88000000
[ 0.000000] OF: reserved mem: 0x000000000a000000..0x000000000a03ffff (256 KiB) nomap non-reusable mmode_resv0@a000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000103fc00000, size 4 MiB
[ 0.000000] OF: reserved mem: initialized node hss-buffer@103fc00000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000103fc00000..0x000000103fffffff (4096 KiB) nomap non-reusable hss-buffer@103fc00000
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x0000001421ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x000000008a000000-0x0000000091ffffff]
[ 0.000000] node 0: [mem 0x00000000c4000000-0x00000000c9ffffff]
[ 0.000000] node 0: [mem 0x0000001022000000-0x000000103fbfffff]
[ 0.000000] node 0: [mem 0x000000103fc00000-0x000000103fffffff]
[ 0.000000] node 0: [mem 0x0000001040000000-0x000000107fffffff]
[ 0.000000] node 0: [mem 0x0000001412000000-0x0000001421ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000001421ffffff]
[ 0.000000] On node 0, zone DMA32: 24576 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 40960 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 32768 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 8192 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 24576 pages in unavailable ranges
[ 0.000000] SBI HSM extension detected
[ 0.000000] CPU with hartid=0 is not available
[ 0.000000] riscv: base ISA extensions acdfim
[ 0.000000] riscv: ELF capabilities acdfim
[ 0.000000] percpu: Embedded 29 pages/cpu s78552 r8192 d32040 u118784
[ 0.000000] pcpu-alloc: s78552 r8192 d32040 u118784 alloc=29*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Kernel command line: root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait console=ttyS0,115200 earlycon uio_pdrv_genirq.of_id=generic-uio net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 524288
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x000000008e000000-0x0000000092000000] (64MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32360 entries in 127 pages
[ 0.000000] ftrace: allocated 127 pages with 7 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] riscv-intc: 64 local interrupts mapped
[ 0.000000] riscv: providing IPIs using SBI IPI extension
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
[ 0.000004] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
[ 0.009654] Console: colour dummy device 80x25
[ 0.014742] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000)
[ 0.025898] pid_max: default: 32768 minimum: 301
[ 0.031169] LSM: initializing lsm=capability
[ 0.036367] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.044707] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.055980] CPU node for /cpus/cpu@0 exist but the possible cpu range is :0-3
[ 0.068492] riscv: ELF compat mode unsupported
[ 0.068526] ASID allocator disabled (0 bits)
[ 0.078568] rcu: Hierarchical SRCU implementation.
[ 0.083874] rcu: Max phase no-delay instances is 1000.
[ 0.090605] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.100050] EFI services will not be available.
[ 0.106254] smp: Bringing up secondary CPUs …
[ 0.118197] smp: Brought up 1 node, 4 CPUs
[ 0.124722] Memory: 1579988K/2097152K available (8108K kernel code, 5035K rwdata, 4096K rodata, 2547K init, 422K bss, 512444K reserved, 0K cma-reserved)
[ 0.141149] devtmpfs: initialized
[ 0.156637] DMA: default coherent area is set
[ 0.161525] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.172314] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.181259] DMI not present or invalid.
[ 0.187355] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.196720] CCACHE: 4 banks, 16 ways, sets/bank=512, bytes/block=64
[ 0.203682] CCACHE: Index of the largest way enabled: 11
[ 0.235162] /fabric-pcie-bus@3000000000/pcie@3000000000: Fixed dependency cycle(s) with /fabric-pcie-bus@3000000000/pcie@3000000000
[ 0.248860] /fabric-pcie-bus@3000000000/pcie@3000000000: Fixed dependency cycle(s) with /fabric-pcie-bus@3000000000/pcie@3000000000
[ 0.262074] /fabric-pcie-bus@3000000000/pcie@3000000000: Fixed dependency cycle(s) with /fabric-pcie-bus@3000000000/pcie@3000000000/interrupt-controller
[ 0.285018] SCSI subsystem initialized
[ 0.289725] libata version 3.00 loaded.
[ 0.290124] usbcore: registered new interface driver usbfs
[ 0.296281] usbcore: registered new interface driver hub
[ 0.302244] usbcore: registered new device driver usb
[ 0.308270] pps_core: LinuxPPS API ver. 1 registered
[ 0.313763] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.323868] PTP clock support registered
[ 0.328672] FPGA manager framework
[ 0.334453] vgaarb: loaded
[ 0.338590] clocksource: Switched to clocksource riscv_clocksource
[ 0.369423] NET: Registered PF_INET protocol family
[ 0.376455] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.393061] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.402656] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.411254] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.421016] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.432366] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.440449] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.448137] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.456690] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.463090] PCI: CLS 0 bytes, default 64
[ 0.470090] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[ 0.478504] NET: Registered PF_ALG protocol family
[ 0.483877] Key type asymmetric registered
[ 0.488435] Asymmetric key parser ‘x509’ registered
[ 0.493895] Asymmetric key parser ‘pkcs8’ registered
[ 0.499634] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.507839] io scheduler mq-deadline registered
[ 0.512871] io scheduler kyber registered
[ 0.517424] io scheduler bfq registered
[ 0.524364] riscv-plic: interrupt-controller@c000000: mapped 186 interrupts with 4 handlers for 9 contexts.
[ 0.536439] mpfs_irq_mux 20002000.syscon:interrupt-controller@54: mux configuration 0
[ 0.548885] microchip,mpfs-gpio 20120000.gpio: Registered MPFS GPIO controller
[ 0.560751] microchip,mpfs-gpio 20121000.gpio: Registered MPFS GPIO controller
[ 0.570938] irq: IRQ53: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.579374] irq: IRQ54: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.587743] irq: IRQ55: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.596101] irq: IRQ56: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.604458] irq: IRQ57: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.612831] irq: IRQ58: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.621202] irq: IRQ59: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.629593] irq: IRQ60: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.637955] irq: IRQ61: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.646326] irq: IRQ62: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.654685] irq: IRQ63: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.663038] irq: IRQ64: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.671412] irq: IRQ65: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.679773] irq: IRQ66: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.688138] irq: IRQ67: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.696493] irq: IRQ68: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.704898] irq: IRQ69: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.713258] irq: IRQ70: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.721612] irq: IRQ71: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.729977] irq: IRQ72: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.738355] irq: IRQ73: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.746742] irq: IRQ74: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.755122] irq: IRQ75: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.763477] irq: IRQ76: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.771848] irq: IRQ77: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.780210] irq: IRQ78: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.788571] irq: IRQ79: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.796945] irq: IRQ80: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.805313] irq: IRQ81: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.813673] irq: IRQ82: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.822034] irq: IRQ83: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.830440] irq: IRQ84: trimming hierarchy from :soc:interrupt-controller@c000000
[ 0.838724] microchip,mpfs-gpio 20122000.gpio: Registered MPFS GPIO controller
[ 0.847880] microchip,mpfs-gpio 41100000.gpio: Registered MPFS GPIO controller
[ 0.856711] microchip,mpfs-gpio 41200000.gpio: Registered MPFS GPIO controller
[ 0.865516] microchip,mpfs-gpio 44000000.gpio: Registered MPFS GPIO controller
[ 0.879828] microchip-pcie 3000000000.pcie: host bridge /fabric-pcie-bus@3000000000/pcie@3000000000 ranges:
[ 0.890717] microchip-pcie 3000000000.pcie: MEM 0x3009000000..0x3017ffffff → 0x0009000000
[ 0.900415] microchip-pcie 3000000000.pcie: IO 0x3008000000..0x3008ffffff → 0x0008000000
[ 0.910086] microchip-pcie 3000000000.pcie: MEM 0x3018000000..0x3087ffffff → 0x0018000000
[ 0.919774] microchip-pcie 3000000000.pcie: IB MEM 0x0080000000..0x0083ffffff → 0x0080000000
[ 0.929456] microchip-pcie 3000000000.pcie: IB MEM 0x00c4000000..0x00c9ffffff → 0x0084000000
[ 0.939142] microchip-pcie 3000000000.pcie: IB MEM 0x008a000000..0x0091ffffff → 0x008a000000
[ 0.948836] microchip-pcie 3000000000.pcie: IB MEM 0x1412000000..0x1421ffffff → 0x0092000000
[ 0.958509] microchip-pcie 3000000000.pcie: IB MEM 0x1022000000..0x107fffffff → 0x00a2000000
[ 0.972097] microchip-pcie 3000000000.pcie: ECAM at [mem 0x3000000000-0x3007ffffff] for [bus 00-7f]
[ 0.982853] microchip-pcie 3000000000.pcie: PCI host bridge to bus 0000:00
[ 0.990487] pci_bus 0000:00: root bus resource [bus 00-7f]
[ 0.996595] pci_bus 0000:00: root bus resource [mem 0x3009000000-0x3017ffffff pref] (bus address [0x09000000-0x17ffffff])
[ 1.008739] pci_bus 0000:00: root bus resource [io 0x0000-0xffffff] (bus address [0x8000000-0x8ffffff])
[ 1.019241] pci_bus 0000:00: root bus resource [mem 0x3018000000-0x3087ffffff] (bus address [0x18000000-0x87ffffff])
[ 1.030963] pci 0000:00:00.0: [11aa:1556] type 01 class 0x060400 PCIe Root Port
[ 1.039101] pci 0000:00:00.0: BAR 0 [mem 0x00000000-0x7fffffff 64bit pref]
[ 1.046741] pci 0000:00:00.0: PCI bridge to [bus 00]
[ 1.052259] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
[ 1.059023] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 1.066542] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 1.075243] pci 0000:00:00.0: supports D1 D2
[ 1.079997] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.091120] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.150296] pci_bus 0000:01: busn_res: [bus 01-7f] end is updated to 01
[ 1.157670] pci 0000:00:00.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 1.166750] pci 0000:00:00.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 1.179462] pci 0000:00:00.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 1.191155] pci 0000:00:00.0: BAR 0 [mem size 0x80000000 64bit pref]: can’t assign; no space
[ 1.200516] pci 0000:00:00.0: BAR 0 [mem size 0x80000000 64bit pref]: failed to assign
[ 1.209310] pci 0000:00:00.0: bridge window [mem 0x3018000000-0x30181fffff]: assigned
[ 1.218005] pci 0000:00:00.0: bridge window [mem 0x3009000000-0x30091fffff 64bit pref]: assigned
[ 1.227740] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]: assigned
[ 1.235292] pci 0000:00:00.0: BAR 0 [mem size 0x80000000 64bit pref]: can’t assign; no space
[ 1.244647] pci 0000:00:00.0: BAR 0 [mem size 0x80000000 64bit pref]: failed to assign
[ 1.253441] pci 0000:00:00.0: bridge window [mem 0x3018000000-0x30181fffff]: assigned
[ 1.262135] pci 0000:00:00.0: bridge window [mem 0x3009000000-0x30091fffff 64bit pref]: assigned
[ 1.271894] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.277407] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.284169] pci 0000:00:00.0: bridge window [mem 0x3018000000-0x30181fffff]
[ 1.292076] pci 0000:00:00.0: bridge window [mem 0x3009000000-0x30091fffff 64bit pref]
[ 1.301035] pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
[ 1.311065] pci_bus 0000:00: resource 4 [mem 0x3009000000-0x3017ffffff pref]
[ 1.318896] pci_bus 0000:00: resource 5 [io 0x0000-0xffffff]
[ 1.325273] pci_bus 0000:00: resource 6 [mem 0x3018000000-0x3087ffffff]
[ 1.332600] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 1.338780] pci_bus 0000:01: resource 1 [mem 0x3018000000-0x30181fffff]
[ 1.346099] pci_bus 0000:01: resource 2 [mem 0x3009000000-0x30091fffff 64bit pref]
[ 1.511969] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.527026] printk: legacy console [ttyS0] disabled
[ 1.533251] 20000000.serial: ttyS0 at MMIO 0x20000000 (irq = 114, base_baud = 9375000) is a 16550A
[ 1.543256] printk: legacy console [ttyS0] enabled
[ 1.553437] printk: legacy bootconsole [ns16550a0] disabled
[ 1.568205] 20100000.serial: ttyS1 at MMIO 0x20100000 (irq = 115, base_baud = 9375000) is a 16550A
[ 1.579674] 20102000.serial: ttyS2 at MMIO 0x20102000 (irq = 116, base_baud = 9375000) is a 16550A
[ 1.591129] 20106000.serial: ttyS4 at MMIO 0x20106000 (irq = 117, base_baud = 9375000) is a 16550A
[ 1.619730] loop: module loaded
[ 1.627755] microchip-corespi 20108000.spi: Registered SPI controller 0
[ 1.636811] microchip-corespi 20109000.spi: Registered SPI controller 1
[ 1.651940] CAN device driver interface
[ 1.661710] macb 20110000.ethernet eth0: Cadence GEM rev 0x0107010c at 0x20110000 irq 121 (00:04:a3:6c:bb:55)
[ 1.675989] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.681976] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.691614] hub 1-0:1.0: USB hub found
[ 1.695571] hub 1-0:1.0: 1 port detected
[ 1.700805] mpfs-musb 20201000.usb: Registered MPFS MUSB driver
[ 1.708247] mpfs_rtc 20124000.rtc: prescaler set to: 999999
[ 1.715044] mpfs_rtc 20124000.rtc: registered as rtc0
[ 1.720202] mpfs_rtc 20124000.rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 1.728410] i2c_dev: i2c /dev entries driver
[ 1.733904] microchip-corei2c 2010a000.i2c: registered CoreI2C bus driver
[ 1.742460] microchip-corei2c 2010b000.i2c: registered CoreI2C bus driver
[ 1.751549] mpfs_wdt 20101000.watchdog: timeout 28 sec (nowayout=true)
[ 1.758968] sdhci: Secure Digital Host Controller Interface driver
[ 1.765220] sdhci: Copyright(c) Pierre Ossman
[ 1.795527] mmc_spi spi1.1: SD/MMC host mmc1, no WP, no poweroff
[ 1.801774] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.808372] usbcore: registered new interface driver usbhid
[ 1.814020] usbhid: USB HID core driver
[ 1.819154] mpfs-mailbox 37020800.mailbox: Registered MPFS mailbox controller driver
[ 1.829023] NET: Registered PF_INET6 protocol family
[ 1.837334] Segment Routing with IPv6
[ 1.841283] In-situ OAM (IOAM) with IPv6
[ 1.845440] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.852732] NET: Registered PF_PACKET protocol family
[ 1.857850] can: controller area network core
[ 1.862484] NET: Registered PF_CAN protocol family
[ 1.866308] mmc0: SDHCI controller on 20008000.mmc [20008000.mmc] using ADMA 64-bit
[ 1.867342] can: raw protocol
[ 1.878039] can: broadcast manager protocol
[ 1.882283] can: netlink gateway - max_hops=1
[ 1.921491] Key type encrypted registered
[ 1.934458] CCACHE: DataError @ 0x00000000.081DFFF8
[ 1.939396] CCACHE: DataFail @ 0x00000000.081DFFF0
[ 1.944392] mpfs-rng mpfs-rng: Registered MPFS hwrng
[ 1.964675] random: crng init done
[ 1.965031] mpfs-sys-controller syscontroller: Registered MPFS system controller
[ 1.977039] clk: Disabling unused clocks
[ 1.982365] Waiting for root device /dev/mmcblk0p3…
[ 2.149115] mmc0: new HS200 MMC card at address 0001
[ 2.156736] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 2.170116] mmcblk0: p1 p2 p3
[ 2.176152] mmcblk0boot0: mmc0:0001 TB2916 4.00 MiB
[ 2.187294] mmcblk0boot1: mmc0:0001 TB2916 4.00 MiB
[ 2.196989] mmcblk0rpmb: mmc0:0001 TB2916 4.00 MiB, chardev (241:0)
[ 2.224810] EXT4-fs (mmcblk0p3): INFO: recovery required on readonly filesystem
[ 2.232219] EXT4-fs (mmcblk0p3): write access will be enabled during recovery
[ 2.653770] EXT4-fs (mmcblk0p3): orphan cleanup on readonly fs
[ 2.662620] EXT4-fs (mmcblk0p3): recovery complete
[ 2.669934] EXT4-fs (mmcblk0p3): mounted filesystem fe89daf6-31a2-4618-bf5d-714a37864756 ro with ordered data mode. Quota mode: disabled.
[ 2.682531] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 2.690264] devtmpfs: mounted
[ 2.712777] Freeing unused kernel image (initmem) memory: 2544K
[ 2.719169] Run /sbin/init as init process
[ 2.723341] with arguments:
[ 2.723357] /sbin/init
[ 2.723372] with environment:
[ 2.723386] HOME=/
[ 2.723400] TERM=linux
[ 3.060678] systemd[1]: System time advanced to timestamp on /var/lib/systemd/timesync/clock: Thu 2026-08-06 02:45:15 UTC
[ 3.121435] systemd[1]: Inserted module ‘autofs4’
[ 3.222798] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[ 3.257368] systemd[1]: Detected architecture riscv64.
[ 3.283702] systemd[1]: Hostname set to </BeagleV/>.
Attached are the first for seconds of dmesg. I have also included the full output, just in case.
dmesg_firstFourSeconds.txt (22.4 KB)
dmesg.txt (29.6 KB)
Well, we’ve gotten some more to go on, although you’ve managed to loose the interesting bits.
Are you doing proper shutdowns or do you just yank the power?
The first four seconds looks exactly like they should, so I’m none the wiser…
How did you write the image to eMMC? Please don’t say Balena!
On the first few sessions, I was just yanking power. Since then, I do sudo shutdown -now.
I wrote the image using the BeagleBoard Imaging Utility.
I am currently experiencing the same issue.
I am running a fully up-to-date version of the latest Debian 13 image, flashed via the official imager in DFU mode.
I flashed the latest default gateware available via apt (2025.10-15-ga46f8b1)
Is there any way I can help with debugging this issue?
If you can log on his another method (e.g. Alternative Ethernet or a uart) then check “ip a” and “cat /etc/systemd/network/*” . I’m doing this from memory - can’t check I have the path right for the systemd networkd configuration. Those two are the main things that go wrong, but may point to other problems like the gadget part of the kernel not coming up …
Here’s the output of the requested commands, plus the status of the USB gadget service
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:04:a3:6a:0d:d8 brd ff:ff:ff:ff:ff:ff
    altname enx0004a36a0dd8
    inet 192.168.178.238/24 metric 1024 brd 192.168.178.255 scope global dynamic eth0
       valid_lft 86322sec preferred_lft 86322sec
    inet6 2a02:a461:a200:0:204:a3ff:fe6a:dd8/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 86324sec preferred_lft 86324sec
    inet6 fe80::204:a3ff:fe6a:dd8/64 scope link proto kernel_ll
3: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
$ cat /etc/systemd/network/*
[Match]
Name=SoftAp0
[Link]
RequiredForOnline=no
[Network]
DHCP=no
Address=192.168.8.1/24
DHCPServer=on
[Match]
Name=eth0
Type=ether
[Link]
RequiredForOnline=yes
[Network]
DHCP=ipv4
[Match]
Name=eth1
Type=ether
[Link]
[Network]
DHCP=ipv4
[Match]
Name=mlan0
Type=wlan
[Link]
[Network]
DHCP=ipv4
[Match]
Name=usb0
[Link]
[Network]
DHCP=ipv4
[Match]
Name=wlan0
Type=wlan
[Link]
[Network]
DHCP=ipv4
$ systemctl status bb-usb-gadgets.service
     Active: inactive (dead) since Thu 2026-10-01 13:10:35 CEST; 1h 21min ago
 Invocation: b86e7f0ac4074183bde55e83490f3352
    Process: 383 ExecStartPre=/sbin/modprobe libcomposite (code=exited, status=0/SUCCESS)
    Process: 400 ExecStart=/usr/bin/bb-start-usb-gadgets (code=exited, status=0/SUCCESS)
        CPU: 486ms
Oct 01 13:10:32 beagle-v systemd[1]: Starting bb-usb-gadgets.service - BeagleBoard.org USB gadgets...
Oct 01 13:10:33 beagle-v bb-start-usb-gadgets[400]: bb-usb-gadgets: bb-start-acm-ncm-rndis-old-gadget
Oct 01 13:10:33 beagle-v bb-start-usb-gadgets[416]: usb_gadget: Looking for libcomposite
Oct 01 13:10:33 beagle-v bb-start-usb-gadgets[416]: usb_gadget: Setting up g_multit through configfs
Oct 01 13:10:34 beagle-v bb-start-usb-gadgets[416]: usb_gadget: No USB Device Controller available
Oct 01 13:10:35 beagle-v systemd[1]: bb-usb-gadgets.service: Deactivated successfully.
Oct 01 13:10:35 beagle-v systemd[1]: Started bb-usb-gadgets.service - BeagleBoard.org USB gadgets.
I would split it into separate code pieces, but the text editor of this reply won’t let me :frowning:
Hope this helps!
Let me know if there is any more information you need.
As @RobertCNelson has already pointed out, the missing piece usb_gadget needs to hook onto
isn’t being produced by the kernel, so rummaging through the OS won’t get you anywhere.
You’ll need to wait and see what he comes up with.
Yes agree with @lranders - your networkd files expect the kernel GPS gadgets to come up as usb0. As you can’t see that “ethernet” interface, that part of the kernel isn’t coming up. Trying to remember what I did there.. Ah yes I remember the gadgets used configfs to set up devices, you have to populate a “filesystem” in a virtual “filespace” - I have always used a script to set up the file structure, then have systemd execute the script as a one off. This is a very ugly solution, I never liked it. Alas I never came up with anything better, so I think configfs is a mess that shouldn’t be in the kernel as it leads to horrible solutions to create the required file structure. I don’t expect to get any traction there - so suspect one has to live with an ugly solution. When I manage to get back on my beagles I’ll look at what the official beagle distribution does in more detail. I’d not be surprised if they have a ugly solution as well. Oh yes you’ll have to think how the network is brought up on usb0, other computers you plug in often don’t expect a new Ethernet connection to suddenly appear on a usb port … You could check Arch Linux ARM • View topic - PocketBeagle on Arch for half my story, it doesn’t give the other half, as you can’t update treads on arm arch … And the clue from that tread is look in “/sys/kernel/config/usb_gadget/” that should have a directory created that brings up the usb gadget using libcomposite.
