You will want a VNC client on your PC. A good opensource option is
UltraVNC
connect the serial port from the beagleboard to the PC using the
beagleboard serial adapter
connect USB to PC and boot Beagleboard
the beagleboard will boot causing windows to detect the device
install the NDSIS drive per
http://embedded.seattle.intel-research.net/wiki/index.php?title=Setting_up_USBnet&redirect=no
the required .inf is linked in the documentation
and setup the network connection (IP address 192.168.0.1 or your
preferred private address, and network mask 255.255.255.0 )
using a terminal program (hyperterm or realterm in ansi mode) connect
to the serial port at 115200 8n1
log into beagle username and password angstrom
(you may need to be logged in as root to execute from sbin)
configure network on beagleboard with the following command
/sbin/ifconfig usb0 192.168.0.2 netmask 255.255.255.0
now add a default route
/sbin/route add default gw 192.168.0.1
test the connection by pinging the windows box
ping 192.168.0.1
make sure your windows box is sharing the connection (advanced tab for
the network connection)
setup name services, edit /etc/resolv.conf
vi /etc/resolv.conf
you will have one line that points to the windows box
nameserver 192.168.0.1
now you should be able to ping a nearby network address by name eg:
ping google.com
update the package from the beagle terminal
opkg update
install VNC for beagle with the following
opkg install x11vnc
now create the VNC server on the beagle board
x11nvc -display :0 &
now connect to the vnc server using the windows vnc viewer
start->programs->ultraVNC->Ultra VNC Viewer
in the VNC Server window type the IP address and display, such as
192.168.0.2:0
The default setting for connection speed of LAN (>1Mbit/s) is fine,
click connect
You should see the beagleboard desktop in a window on your PC
