Hi All,
Any tutorials on how to operate the watchdog on the beagleboard?
Many thanks,
Chris
Hi All,
Many thanks,
Chris
OMAP watchdog support is built in to the kernel and is used to detect a kernel hang… AFAIR it dumps a stack trace and reboots the BeagleBoard if the kernel “hangs” for 60 seconds.
If you want to tinker with it then the code is in linux/drivers/watchdog/omap*. Its not in the mainline linux branch, so you’d need to look here for it (or use OpenEmbedded):
Hope it helps, if not then could you elaborate some more on what you are wanting to do…
I want it to watch a script and reboot if the script is not run after
a period of time.
Is this possible?
Not unless you change the driver… although that shouldn’t be too much work:
a) change initial state of watchdog to be off - otherwise you might have problems booting
b) change the driver register so that its a generic driver rather than a watchdog - then the kernel will stop poking it
c) use ioctl to “ping” the watchdog sysfs file from user space.
