Hi All,
Please find my weekly report below.
Pramod
Status and Accomplishment
Completed porting all of my algorithms to C6accel. Added new algorithm cvCvtColor() to support CV_RGB2GRY operation. Added VLIB support to C6accel library. Used VLIB_integralImage8() for cvIntegral() implementation. Added flag to control its use. User need to get VLIB access after requesting on www.ti.com/vlibrequest. Implemented chaining of OpeCV APIs cvCvtColor() and cvSobel(). DSP_cvCvtColor_cvSobel() demonstrates this implementation. This scheme reduces codec-engine overhead between API calls.
Worked on the documentation of API and procedure to add new API to the existing library. Following is the links to documentation http://code.google.com/p/opencv-dsp-acceleration/wiki/API_DOCUMENTATION and http://code.google.com/p/opencv-dsp-acceleration/wiki/Procedure_To_add_other_OpenCV_Algorithms
Worked on the application to demonstrate the use of these APIs.
All the API call now has almost constant execution time of ~380 usec for establishing asynchronous DSP function call. The ARM and DSP should be synchronized using DSP_cvSyncDSP() before output is accessed. This can give performance boost up of greater than 10x in any algorithm for image size of 640x480 if data dependency is tackeled in application wisely.
Waiting for C6accel tag to be created before releasing code for evaluation.
Plans -
Refine document.
Review of code.
Look into DFT algorithm to avoid race condition as I am able to see result only when CE_DEBUG=3.
Blockers
Some suggestion on my issue with DFT algorithm, as mentioned in Plans section, would be helpful.
