I’ve been pulling my hair out over a really weird problem and after trying everything I know to try, I’m posting it here in hopes of someone seeing the problem.
I am running a Beaglebone Black. The output of version.sh is at the end of this post.
Linux beaglebone 4.19.94-ti-r61 #1buster SMP PREEMPT Wed Mar 31 15:23:20 UTC 2021 armv7l GNU/Linux
I boot from an SD card.
I’m using remoteproc to communicate between a host program and the PRU code.
The program is long and includes stuff that I don’t think is important here like configured the ADC and IEP counter.
The host program lets the user choose from a menu what they want the PRU to do. Then using RPMSG, the command is sent to the PRU. It receives the message, determines what it is and executes the appropriate action in the PRU code. This is done by reading the message and using an “if-else if-else”. One of the actions is to read three analog inputs and return the values read through RPMSG. Each analog value is stored in a ring buffer-type array, type unsigned int, that is allocated in the PRU Shared memory space.
So once the host sends the message to do the analog input read, it starts to listen for responses from the PRU.
This all works great. I get data from the PRU and the host program puts it in a CSV file that I can analyze with other tools.
Now, though we need to do some basic math on the data in the PRU. I only need to do this on a subset of the data in the arrays and the start and end points in the array can vary. So I have two integer variables that I use to store the start and end points. So, the routine that reads the analog data sets the values of these two variables as voltage thresholds are met. The code compiles just fine.
However, if these two variables are not set to a constant within the loop, the host never gets a message from the PRU code. They are set to initial values before the loop (that code is not included below.)
It’s the craziest thing I’ve ever run into I think. I have declared these variables as local and global and nothing seems to matter. If they are set to a constant in the loop, the host doesn’t get a message from the PRU program.
Here’s the code snippet with the two variables in bold. If those lines of code do not exist, the host doesn’t hear from the PRU.
count = HWREG(SOC_ADC_TSC_0_REGS + TSC_ADC_SS_FIFOCOUNT(0));
for (i = 0; i < count; i++)
Data = HWREG(SOC_ADC_TSC_0_REGS + TSC_ADC_SS_FIFODATA(0));
StepRead = (Data >> 16) & 0xF;
RawAnalog = Data & 0xFFF;
switch (StepRead)
case 0:
DetTSampleSet[pnr]=RawAnalog;
break;
case 1:
start_of_pulse = 0;
end_of_pulse = 0;
DetBSampleSet[pnr]=RawAnalog;
if ((pnr == end_of_pulse) && (in_pulse == E_YES)) // seen a pulse and at end of it analyze signal
DetBSignalAverage= AnalyzeSignal(start_of_pulse, pnr);
start_of_pulse = -1;
end_of_pulse = -1;
samples_in_pulse = 0;
in_pulse = E_NO;
else
DetBSignalAverage = 0;
if (RawAnalog > 0xB54)
__R30 |= PanelYellowLED; // turn yellow LED on; at the sampling rate we’re using this may result in just a flicker
in_pulse = E_YES; // once the leading edge of the pulse passes set this
samples_in_pulse++; // count the number of samples in the pulse
DetBSignalAverage = 999; // samples_in_pulse;//just using for debugging
// here we will check for a max # of samples in pulse while in a pulse to throw out start of fluid or end of fluid or pulses larger than a seed
if (start_of_pulse < 0) start_of_pulse = pnr; // set start pointer in ring buffer if it hasn’t already been set for this pulse
else if ((RawAnalog <= 0xAC8) && (in_pulse == E_YES))
__R30 &= ~CAValve; // turn compressed air off; stop fluid flow because the pulse has cleared the bottom detector
in_pulse = E_NO; // pulse is over
DetBSignalAverage = 1999; //samples_in_pulse;//just using for debugging
// this is an alternative place to check the number of samples in the pulse to throw out start / end of fluid but we would never stop because Rawanalog
// will never drop while there is no fluid in the tube
if (end_of_pulse < 0) end_of_pulse = pnr; // capture where we are in the ring buffer at the end of the pulse
__R30 |= VacValve; // turn vacuum on to hold fluid in place; ultimately this would read the pressure and attempt to hold it there
__delay_cycles(40000000); // put this delay cycle here for now. will be replaced with a routine to analyze pulse & maintain slight vacuum later
__R30 &= ~VacValve;
__delay_cycles(40000000); // put this delay cycle here for now. will be replaced with a routine to analyze pulse later
__R30 |= CAValve;
else __R30 &= ~PanelYellowLED; // turn yellow LED off
StepRead = RawAnalog;
RawAnalog = DetBSignalAverage;
break;
case 2:
Pressure = RawAnalog;
if (pnr == E_RING_BUFFER_SIZE-1)
pnr = 0;
else
pnr++;
RawAnalog=pnr;
break;
default: // flash both LEDS indicating a problem
for (i=0;i<20;i++)
__R30 |= PanelGreenLED; // turn green LED on
__delay_cycles(10000000);
__R30 |= PanelYellowLED; // turn green LED on
__delay_cycles(20000000);
__R30 &= ~PanelGreenLED; // turn green LED off
__delay_cycles(30000000);
break;
git:/opt/scripts/:[b39ec679648a6be8f25f48bd1c9784c1fc5a0c46]
eeprom:[A335BNLT00C04417BBBK1847]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-04-06]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g07d5700e21]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0]
UBOOT: Loaded Overlay:[BB-I2C2-RTC-DS3231]
UBOOT: Loaded Overlay:[BB-W1-P9.12-00A2]
kernel:[4.19.94-ti-r61]
nodejs:[v10.15.2]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_addr4=/lib/firmware/BB-W1-P9.12-00A0.dtbo]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
uboot_overlay_options:[dtb_overlay=/lib/firmware/BB-I2C2-RTC-DS3231.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20210401.0-0~buster+20210401]
pkg:[bb-wl18xx-firmware]:[1.20200322.0-0rcnee0~buster+20200322]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~buster+20190327]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 70.424168] remoteproc remoteproc0: wkup_m3 is available
[ 70.537289] remoteproc remoteproc0: powering up wkup_m3
[ 70.537322] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 70.537592] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 72.807404] remoteproc remoteproc1: 4a334000.pru is available
[ 72.825531] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[ 72.811832] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 72.825738] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
dmesg | grep pinctrl-single
[ 0.951001] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
[ 0.964886] gpio-of-helper ocp:cape-universal: ready
lsusb
END
