I am assuming that ti branch is the correct version??
remotes/origin/v6.1.x
remotes/origin/v6.1.x-Beagle
remotes/origin/v6.1.x-ti
This is out of the box, no overlays applied and it looks like the labels are not present. Is this a new way of doing this?
~$ gpioinfo
gpiochip0 - 84 lines:
line 0: unnamed "BOOT" input active-low [used]
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed "POWER" input active-low [used]
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
line 32: unnamed unused input active-high
line 33: unnamed unused input active-high
line 34: unnamed unused input active-high
line 35: unnamed unused input active-high
line 36: unnamed unused input active-high
line 37: unnamed unused input active-high
line 38: unnamed unused input active-high
line 39: unnamed unused input active-high
line 40: unnamed unused input active-high
line 41: unnamed unused input active-high
line 42: unnamed unused input active-high
line 43: unnamed unused input active-high
line 44: unnamed unused input active-high
line 45: unnamed unused input active-high
line 46: unnamed unused input active-high
line 47: unnamed unused input active-high
line 48: unnamed unused input active-high
line 49: unnamed unused input active-high
line 50: unnamed unused input active-high
line 51: unnamed unused input active-high
line 52: unnamed unused input active-high
line 53: unnamed unused input active-high
line 54: unnamed unused input active-high
line 55: unnamed unused input active-high
line 56: unnamed unused input active-high
line 57: unnamed unused input active-high
line 58: unnamed unused input active-high
line 59: unnamed unused input active-high
line 60: unnamed unused input active-high
line 61: unnamed unused input active-high
line 62: unnamed unused input active-high
line 63: unnamed unused input active-high
line 64: unnamed unused input active-high
line 65: unnamed unused input active-high
line 66: unnamed unused input active-high
line 67: unnamed unused input active-high
line 68: unnamed unused input active-high
line 69: unnamed unused input active-high
line 70: unnamed unused input active-high
line 71: unnamed unused input active-high
line 72: unnamed unused input active-high
line 73: unnamed unused input active-high
line 74: unnamed unused input active-high
line 75: unnamed unused input active-high
line 76: unnamed unused input active-high
line 77: unnamed unused input active-high
line 78: unnamed unused input active-high
line 79: unnamed unused input active-high
line 80: unnamed unused input active-high
line 81: unnamed unused input active-high
line 82: unnamed unused input active-high
line 83: unnamed unused input active-high
gpiochip1 - 128 lines:
line 0: unnamed unused input active-high
line 4: unnamed unused input active-high
line 22: unnamed "reset" output active-high [used]
line 49: unnamed "regulator-5" output active-high [used]
line 82: unnamed "regulator-3" output active-high [used]
line 84: unnamed unused input active-high
line 85: unnamed unused input active-high
line 86: unnamed unused input active-high
line 87: unnamed unused input active-high
line 88: unnamed unused input active-high
line 89: unnamed unused input active-high
line 90: unnamed unused input active-high
line 91: unnamed unused input active-high
line 92: unnamed unused input active-high
line 93: unnamed unused input active-high
line 94: unnamed unused input active-high
line 95: unnamed "beaglebone:green:usr1" output active-high [used]
line 96: unnamed "beaglebone:green:usr0" output active-high [used]
line 97: unnamed "beaglebone:green:usr2" output active-high [used]
line 98: unnamed unused input active-high
line 99: unnamed unused input active-high
line 100: unnamed unused input active-high
line 101: unnamed unused input active-high
line 102: unnamed unused input active-high
line 103: unnamed unused input active-high
line 104: unnamed unused input active-high
line 105: unnamed unused input active-high
line 106: unnamed unused input active-high
line 107: unnamed unused input active-high
line 108: unnamed unused input active-high
line 109: unnamed "beaglebone:green:usr4" output active-high [used]
line 110: unnamed "beaglebone:green:usr3" output active-high [used]
line 111: unnamed unused input active-high
line 112: unnamed unused input active-high
line 113: unnamed unused input active-high
line 114: unnamed unused input active-high
line 115: unnamed unused input active-high
line 116: unnamed unused input active-high
line 117: unnamed "tlv71033" output active-high [used]
line 118: unnamed unused input active-high
line 119: unnamed unused input active-high
line 120: unnamed unused input active-high
line 121: unnamed unused input active-high
line 122: unnamed unused input active-high
line 123: unnamed unused input active-high
line 124: unnamed unused input active-high
line 125: unnamed unused input active-high
line 126: unnamed unused input active-high
line 127: unnamed unused input active-high
gpiochip2 - 36 lines:
line 3: unnamed "typec-dir" input active-low [used]
