I’m about to order a bunch of Wifi/Bluetooth dongles for my class and would like to know which ones work (or don’t work).
–Mark
–Mark
You could check the following links for reference to Wi-Fi Modules:
https://www.balena.io/docs/reference/hardware/wifi-dongles/
https://elinux.org/Beagleboard:BeagleBoneBlack#WIFI_Adapters
For Bluetooth support on a BeagleBone Black, I have had good luck with the ASUS USB-BT400 Bluetooth 4.0 Dongle:
Ex:
From dmesg:
[ 85.785671] Bluetooth: hci0: BCM20702A
[ 85.790648] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
$ lsusb
Bus 001 Device 002: ID 0b05:17cb ASUSTek Computer, Inc. Broadcom BCM20702A0 Bluetooth
$ sudo hcitool dev
Devices:
hci0 5C:F3:70:6E:13:4
NOTE: If you plan to use both a Wi-Fi module and a Bluetooth Dongle on a BB Black, you should use a powered USB HUB to connect these devices to the BB Black.
Cheers,
Jon
Do we need to install drivers for wifi in beaglebone black , if so does it has to be done when building an image for beaglebone itself or can it be done on the board?
P.S : I have a beaglebone black board running on debian os
