Where can i get beagle board peripherals in bangalore??
I am looking for the following peripherals,
USB-Std-A Male to 5.5x2.1mm Barrel Connector
3-port USB Hub with 10/100 Ethernet
Null Modem RS-232 DB9F-DB9F Cable
DB9M to IDC10F AT/Everex Serial Adapter
USB Std-A-Female to Mini-A-Male Adapter
Monitor Cable (HDMI-A-male to DVI-D male)
Acrylic Case for Beagle
From where can i get the above in Bangalore, India?
Check beaglesales.india@cranessoftware.com or go around SP road
Also check with IDA http://www.idasystems.net/beagle_board
Khasim
I've also found DealExtreme - http://dealextreme.com to have some good items. Their prices are cheap and they all include the cost of international shipping from Hong Kong.
Sometimes they're quick to deliver, sometimes it takes a few weeks. My recommendation is even if you need, say, 5 parts, order them one at a time so that way they will ship as each item comes into stock...
Cheers,
Kai
Thanks all.. Now, I should be up and running soon. :slight_smile:
tu bangalore mein reheke waste hai.
-super
