As title says, usally to grow a partition in BB-black i run
$> sudo /opt/scripts/tools/grow_partition.sh
Unfortunately there is no more /opt/scripts in the BBAI64,
What is the proper procedure to grow a newly burned microSD in BBAI64 ?
bye
Nicola
bye
Nicola
Hi @nmingotti just reboot⌠![]()
Background (for all Bullseye imagesâŚ) the package âgeneric-sys-modsâ pre-installed on every Bullseye image does:
On first bootup, the systemd service file: grow_partition.service runs, it calls â/usr/bin/bb-growpartâ to grow the partition and set the next resize_filesystem.service file to expandâŚ
Sadly yes it requires a reboot to get everything doneâŚ
#!/bin/sh
if [ -f /etc/default/generic-sys-mods ] ; then
. /etc/default/generic-sys-mods
fi
if [ ! "x${ROOT_DRIVE}" = "x" ] ; then
if [ ! "x${ROOT_PARTITION}" = "x" ] ; then
echo "/usr/bin/growpart ${ROOT_DRIVE} ${ROOT_PARTITION}"
fi
fi
/usr/bin/bb-resizefs
#!/bin/sh
fi
unset is_btrfs
is_btrfs=$(cat /proc/cmdline | grep btrfs || true)
if [ "x${is_btrfs}" = "x" ] ; then
echo "resize2fs ${ROOT_DRIVE}p${ROOT_PARTITION}"
fi
fi
else
echo "btrfs filesystem resize max /"
fi
Yap, confirmed. I just peeked into âdfâ and the all microSD space is being used !
It did all alone.
I have other little questions like this one, but better i separate in proper titles so other user in the future may find the solution faster.
Thank you !
I also tagged this as an FAQ for the next person. ![]()
Yeah, this is one of the various cleanups i did for Bullseye, that changed 7 years of historical ways of doing things.
