I have shored out my data pins on P9 and I keep seeing tutorials and code running SpiDev test program? I’ve tried to run and it says no files exists. Where are people getting this file?
running SpiDev test program? I've tried to run and it says no files exists.
spidev_test.c is available from kernel.org
https://www.kernel.org/doc/Documentation/spi/spidev_test.c
There's also a version for the BBB that can be found in Derek Molloy's
repository for his book:
git clone GitHub - derekmolloy/exploringBB: Source code for the book Exploring BeagleBone, by Derek Molloy (see www.exploringbeaglebone.com)
then look for ../exploringBB/chp08/spi/spidev_test.c
Thanks Bill! What about the header files below? I’m getting errors on some of the global variables and I think its because I don’t have these header files.
#include <linux/types.h>
#include <linux/spi/spidev.h>
Thanks Bill! What about the header files below? I'm getting errors on some
of the global variables and I think its because I don't have these header
files.#include <linux/types.h>
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Installing_kernel_headers
I’m running the command to install the header files, but I’m coming up with errors.
sudo apt-get install linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree
Reading stat information... Done
E: Unable to locate package linux-headers-3.8.13-bone72
E: Couldn't find any package by regex 'linux-headers-3.8.13-bone72'
I ran the kernel upgrade before this too. Any ideas?
What's your base rootfs?
cat /etc/dogtag
debian@beaglebone:~$ sudo apt-cache search linux-headers-3.8.13-bone72
linux-headers-3.8.13-bone72 - Linux kernel headers for 3.8.13-bone72 on armhf
BeagleBoard.org BeagleBone Debian Image 2014-04-23
I ran the search and nothing happened.
Sorry, that apt repo was initially setup July of 2014, so it's not
enabled in the original May 2014 image.
wget http://repos.rcn-ee.com/debian/pool/main/l/linux-upstream/linux-headers-3.8.13-bone72_1wheezy_armhf.deb
sudo dpkg -i linux-headers-3.8.13-bone72_1wheezy_armhf.deb
or update the rootfs:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#2015-03-01
Thank you! That worked perfectly. I’m still having trouble compiling my spidev_test.c program though. There is a lot of undeclared variables like SPI_TX_DUAL and SPI_RX_DUAL. I thought these would be included when I downloaded the header file, but I’m not seeing the directory for this in my beaglebone. According to the code it should be </linux/types.h> and </linux/spi/spidev.h>.
