I am a newbie to beagle board, I am trying to bring DSP up on beagle board.
Can someone tell me where to get latest patches for bridgedriver kernel module?
Using kernel version - linux-2.6.34
Initially tried with the patches got from the following link
Index of /~felipec/dspbridge , it gave the following errors while compiling the modules
drivers/dsp/bridge/core/tiomap3430.c: In function ‘bridge_brd_monitor’:
drivers/dsp/bridge/core/tiomap3430.c:284: error: ‘PM_PWSTST’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:284: error: (Each undeclared identifier is reported only once
drivers/dsp/bridge/core/tiomap3430.c:284: error: for each function it appears in.)
drivers/dsp/bridge/core/tiomap3430.c:290: error: ‘PM_PWSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:293: error: ‘CM_CLKSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:304: error: ‘RM_RSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c: In function ‘bridge_brd_start’:
drivers/dsp/bridge/core/tiomap3430.c:431: error: ‘RM_RSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:592: error: ‘CM_CLKSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c: In function ‘bridge_brd_stop’:
drivers/dsp/bridge/core/tiomap3430.c:660: error: ‘PM_PWSTST’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:671: error: ‘PM_PWSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:674: error: ‘CM_CLKSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c:704: error: ‘RM_RSTCTRL’ undeclared (first use in this function)
drivers/dsp/bridge/core/tiomap3430.c: In function ‘bridge_brd_delete’:
drivers/dsp/bridge/core/tiomap3430.c:759: error: ‘RM_RSTCTRL’ undeclared (first use in this function)
make[2]: *** [drivers/dsp/bridge/core/tiomap3430.o] Error 1
Should I add something else before applying the above patch?
