Which firmware for Beagleboard Blue?
I bought beagleboard blue board some time ago, but never used. Now I have some time.
The firmware seems to be outdated, I have a couple of “not found” errors, on sudo apt update
I want to flash newest firmware, but I do not know which one I have to use. I do not find firmware version, specially named for Blue board.
About my board:
debian@beaglebone:~$ uname -a
Linux beaglebone 4.4.59-ti-r96 #1 SMP Tue Apr 4 17:39:20 UTC 2017 armv7l GNU/Linux
debian@beaglebone:~$ cat /etc/dogtag
BeagleBoard.org Debian Image 2017-04-09
Board’s Internet access I have (Wifi activated)
Many thanks in advance
Richard
latest-images search on this forum will get the latest. But, I think there is an issue w/ the current images and the BBBlue working w/ the librobotcontrol lib if this is what you want.
  1. Debian 11.x (Bullseye) - Monthly Snapshot - 2023-10-07
  2. Debian 12.x (Bookworm) - Monthly Snapshot - 2023-10-07
Thank you! I will try this week, when I have time.
I’m looking for the latest image for a BBBlue with which I intend to work with the librobotcontrol library. As silver2row pointed out (and as I recall reading somewhere), there seems to be an issue with some recent images and the BBBlue working with the librobotcontrol library.
Does anyone have any advice on this?
Many thanks.
ya might need buster or stretch image
linux version 4.14.61-ti-r68 or older based on some of the documentation
take a look at, they indicated a fix for 5.x. version
Thank you, amf99, for your suggestions.
Unfortunately, it seems that the buster image is no longer supported. Today, when I tried to update buster, the output was:
debian@beaglebone:~$ date ; uname -a ; sudo apt-get update
Thu 17 Jul 2025 06:24:36 PM WEST
Linux beaglebone 4.19.94-ti-r43 #1buster SMP PREEMPT Wed Apr 22 06:11:16 UTC 2020 armv7l GNU/Linux
Ign:1 Index of /debian buster InRelease
Ign:2 Index of /debian buster-updates InRelease
Ign:3 Index of /debian-security buster/updates InRelease
Err:4 Index of /debian buster Release
404 Not Found [IP: 146.75.90.132 80]
Err:5 Index of /debian buster-updates Release
Err:6 Index of /debian-security buster/updates Release
Hit:7 Index of /debian buster InRelease
Reading package lists… Done
E: The repository ‘Index of /debian buster Release’ no longer has a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository ‘Index of /debian buster-updates Release’ no longer has a Release file.
E: The repository ‘Index of /debian-security buster/updates Release’ no longer has a Release file.
However, the real problem is that librobotcontrol has likely reached its EOL. In other words, support for librobotcontrol in newer Linux images has probably ended. If so, I wish it were clearly stated somewhere in the BeagleBone documentation or forums.
