Which is the correct way to upgrade node-RED on Beaglebone Green Wireless?
Some received messages when I tried to stop and start manually:
root@beaglebone:~# sudo service node-red stop
Failed to stop node-red.service: Unit node-red.service not loaded.
root@beaglebone:~# sudo service node-red start
Failed to start node-red.service: Unit node-red.service not found.
root@beaglebone:~# sudo systemctl enable node-red.service
Failed to enable unit: Unit file node-red.service does not exist.
root@beaglebone:~# sudo apt upgrade nodejs bb-node-red-installer
Reading package lists… Done
Building dependency tree
nodejs is already the newest version (10.24.0~dfsg-1~deb10u1).
bb-node-red-installer is already the newest version (1.3.5-0rcnee2~buster+20210719).
Calculating upgrade… Done
The following packages have been kept back:
c9-core-installer
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
I grabed a new snapshot as you suggested and everything works fine, I already have node-red updated to version 1.3.5, thank you very much for the help.
