The latest official release is found at http://circuitco.com/support/index.php?title=Updating_The_Software which is the 9_4 image. Make sure you use th eFlasher version. That flashes the eMMC. But it has no GUI until after it flashes the eMMC and you power cycle the board. As the instructions say, it take about 45 minutes for the flashing process.
The webpage is out of date as usual. Stick to the Wiki.
That’s the one I have installed, I flashed the eMMC and know it was successful at it had 4 solid LEDs at the end of the process and when I rebooted it was different install. And yep, I have rebooted a number of times and still no UI…is there something else I need to do?
I have done the opkg upgrade install stuff…do I need to install a specific module or something?
