I´ve solved a problem with Bluetooth Driver although I would like to understand why. I have installed: BBB-eMMC-flasher-ubuntu-14.04.1-console-armhf-2014-10-29-2gb.img
Problem was that this device although recognized were not usable (“hcitool dev” not showing any device)
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
I´ve tried these Kernels:
3.14.26-ti-r39 → NOK
v3.18.0-rc7-bone1 → NOK
v3.8.13-bone68 → OK
With the latest one Bluetooth device is working properly (although I have not connected successfully yet to a Headset). My question is, why? Which are the differences between them?
Any ideas why I cannot pair with my bluetooth headset?
In other hand, I´ve tested also Debian BBB-eMMC-flasher-debian-7.7-console-armhf-2014-11-19-2gb.img but WiFi took over 5 minutes to be ready… I do not why… I didn´t try to update kernel but I will, this is my Dongle:
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Thanks for your support, great community!
Jaime Fdez-Caro
http://cortexlabs.blogspot.com
Problem was that this device although recognized were not usable ("hcitool
dev" not showing any device)
Dongle (HCI mode)
3.14.26-ti-r39 --> NOK
v3.18.0-rc7-bone1 --> NOK
v3.8.13-bone68 --> OK
OH... it would probally would have helped if i actually enabled
CONFIG_BT_* options in the kernel config..
DOh..
over 5 minutes to be ready... I do not why... I didn´t try to update kernel
the 8188's are picky.. Do you have a usb extension cable to get it
away from the hdmi ground plane?
Yes probably it would helped! XDDD glad to collaborate.
Regarding WiFi, I have connected through an USB HUB, the thing is that it has no problem with Arch or Ubuntu, only with Debian. I will try to change Kernel if it helps. If you need some additional info just tell me.
Thanks for your support Robert, your are great!
OH… it would probally would have helped if i actually enabled
CONFIG_BT_* options in the kernel config…
OMG ! It’s human after all ! hehehehe . . . sounds like something id do
