Hi, which one do you advise ?
https://github.com/RobertCNelson/ti-linux-kernel-dev
https://github.com/RobertCNelson/bb-kernel
https://github.com/beagleboard/linux
what is the difference ?
Micka,
Micka,
On Wed, 11 Sep 2019 09:04:15 +0200, Micka
<mickamusset@gmail.com> declaimed the
following:
Did you examine what each of those contains?
Per the readme, that is just a bunch of scripts for building the
kernel, but the source is elsewhere...
Last updated in 2014 -- I'd consider that quite dead
Readme implies four kernel versions in both normal and RT variants, and
updated last week...
Recheck https://github.com/RobertCNelson/bb-kernel. If you change the branch you’ll find it was updated a couple of days ago.
In fact, that’s the one I point my students to (https://elinux.org/EBC_Exercise_08_Installing_Development_Tools_4.4) Once the desired branch is selected, it has scripts to load the correct cross compiler and the kernel and compile everything.
–Mark
I prefer also https://github.com/RobertCNelson/bb-kernel
there is everything to compile easily and deploy the kernel.
But I would like to know the difference with
https://github.com/beagleboard/linux ?
which one is more up to date ?
which one is the best ?
On Wed, 11 Sep 2019 14:06:07 -0700 (PDT), "Mark A. Yoder"
<mark.a.yoder@gmail.com> declaimed the
following:
Recheck GitHub - RobertCNelson/bb-kernel
<Redirect Notice.
If you change the branch you'll find it was updated a couple of days ago.
Okay -- so I normally don't use GIT, and never used branches in it...
Maybe the readme for master could add some clause about "current
development is found under branches" <G>
Good idea. I’ve just put in a pull request with a more helpful README.md
–Mark
I would like that someone tell us which source is more reliable, more
up to date for the beagleboneblack :
