which touch screen + whatever is needed to get it running would you suggest I
should buy? ( It should to be available in europe, if that is possible)
I am thinking of something below 8". Please also explain why your suggestion
is a good choice.
criteria:
- ease of use / installation
- ease of programming for it
- price
is a good choice.
criteria:
- price
I have a Xenarc touch screen with VGA, composite video, and audio
inputs. This specific model obviously wouldn't work for Beagleboard,
but I'm very pleased with it for other uses. It auto-detects the
display input and mode every time so far, and the integrated USB touch
screen seems to work well with Linux. 800x480 native resolution, with
LED backlight.
Xenarc makes a similar device with HDMI that I'm considering, it's
mentioned on the Beagleboard site as being supported:
If its quality is in any way similar to the unit I have, then I highly
recommend it. It's US$470, but the out-of-the-box experience,
workmanship, and high functional integration makes it worth the price IMHO.
can you please precise if you want only the touch screen panel or the
full LCD display + touch screen.
I live in China and I develop also a product based on beagle board and
LCD + touch screen.
Usually for a 8" or below screen dimension, the technology for touch
screen is 4 wire resistant.
If you need only the touch screen panel :
- I have a good manufacturer here in shenzhen who can do them for
cheap price. I can help you to send to Europ (I am french), no
problem.
If you need the LCD module (display + touchscreen) :
- I recommend you the Innolux AT070TN83, it is 7" in 16/9 with 800x480
resolution. It has 4-wire resistive TS integrated and an easy LED
backlight driving. I can also help to you purchase some from here.
In both case, you will need a chip to drive the TS signal. I recommend
you the TSC2046 of burr brown as it is 1,8V compatible IO and run un
3,3V (no need to adapt level from OMAP).
sorry for the very late answer. I somehow missed the mails on the
list.
At first thanks for your help!
Dear Ronny,
LCD + touch screen.
problem.
Can you please specifify what the panel can do?
How do you connect it to a computer (USB?) ?
Does it support multitouch?
Is it only usable with a pen, or can I use my fingers too?
How large is it.
What would the cost be? and and and
