I have been using kernel 2.6.32 for years and decided it was time to upgrade to a more recent one so I chose the following as it can run the board safely at 1GHz:
https://github.com/RobertCNelson/armv7-multiplatform (v3.11.x branch)
I also had to upgrade u-boot as my version (U-Boot SPL 2013.01-00071-g6ad77d8 (Feb 01 2013 - 22:10:08)) does not support zImage (even if I rebuild it with CONFIG_CMD_BOOTZ set it refuses to boot a zImage). So I switched to u-boot-2014.1.
Whilst it booted first time the USB ports do not come up (and there are a bunch of errors during boot). I suspect this is a u-boot problem since if I boot my known working 2.6.32 kernel with uboot-2014.1 the usb ports are not working either. (If I go back to old uboot with 2.6.32 everything works fine so I know the board is good).
Is there a known stable version of u-boot for beaglexm that can boot a zImage for this kernel? Do I need some patches for uboot?
Mark
Serial output below:
U-Boot 2014.01 (Jan 30 2014 - 01:06:48)
OMAP3630/3730-GP ES1.1, CPU-OPP2, L3-200MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
Error: Bad compare! failed
NAND read from offset 260000 failed -74
In: serial
Out: serial
Err: serial
Beagle xM Rev A/B
No EEPROM on expansion board
Die ID #127400011ff00000015739eb0c00d00d
Net: usb_ether
mmc0 is current device
gpio: pin 173 (gpio 173) value is 0
gpio: pin 4 (gpio 4) value is 0
SD/MMC found on device 0
reading uEnv.txt
8 bytes read in 3 ms (2 KiB/s)
** File not found /boot/uImage **
Booting from nand …
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
Wrong Image Format for bootm command
ERROR: can’t get kernel image!
3810576 bytes read in 264 ms (13.8 MiB/s)
13511 bytes read in 22 ms (599.6 KiB/s)
Booting with DT from mmc0 …
Kernel image @ 0x80200000 [ 0x000000 - 0x3a2510 ]
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
Using Device Tree in place at 80f80000, end 80f864c6
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.11.10-armv7-x14.2 (xxxx@xxxxxxx) (gcc version 4.8.2 20131014 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2013.10 - Linaro GCC 2013.10) ) #1 SMP Wed Jan 29 23:51:17 GMT 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Generic OMAP3-GP (Flattened Device Tree), model: TI OMAP3 BeagleBoard xM
[ 0.000000] cma: CMA: reserved 16 MiB at 9e800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] OMAP3630 ES1.1 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c138e000 s14080 r8192 d14592 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mpurate=auto buddy=none camera=none vram=2M omapfb.mode=dvi:640x480MR-16@60 omapdss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 488964K/523264K available (7254K kernel code, 627K rwdata, 2864K rodata, 469K init, 1014K bss, 34300K reserved, 0K highmem)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc09e99f4 (10119 kB)
[ 0.000000] .init : 0xc09ea000 - 0xc0a5f700 ( 470 kB)
[ 0.000000] .data : 0xc0a60000 - 0xc0afcea0 ( 628 kB)
[ 0.000000] .bss : 0xc0afcea0 - 0xc0bfa6b8 (1015 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[ 0.000000] clock: dpll5: dpll5_clk omap3630
[ 0.000000] clock: dpll5: Applying SPRZ319E 2.1: 13000000, 443, 5, 8
[ 0.000000] OMAP clockevent source: timer12 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000305] Calibrating delay loop… 339.14 BogoMIPS (lpj=1695744)
[ 0.042633] pid_max: default: 32768 minimum: 301
[ 0.042785] Security Framework initialized
[ 0.042877] AppArmor: AppArmor initialized
[ 0.043090] Mount-cache hash table entries: 512
[ 0.048095] Initializing cgroup subsys memory
[ 0.048156] Initializing cgroup subsys devices
[ 0.048156] Initializing cgroup subsys freezer
[ 0.048187] Initializing cgroup subsys net_cls
[ 0.048187] Initializing cgroup subsys blkio
[ 0.048217] Initializing cgroup subsys perf_event
[ 0.048339] CPU: Testing write buffer coherency: ok
[ 0.048767] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.048828] Setting up static identity map for 0xc06dd928 - 0xc06dd980
[ 0.049987] Brought up 1 CPUs
[ 0.050018] SMP: Total of 1 processors activated (339.14 BogoMIPS).
[ 0.050018] CPU: All CPU(s) started in SVC mode.
[ 0.050903] devtmpfs: initialized
[ 0.072357] omap_hwmod: mcbsp2: cannot be enabled for reset (3)
[ 0.114868] xor: measuring software checksum speed
[ 0.198150] arm4regs : 647.200 MB/sec
[ 0.284698] 8regs : 477.200 MB/sec
[ 0.371246] 32regs : 558.400 MB/sec
[ 0.371246] xor: using function: arm4regs (647.200 MB/sec)
[ 0.371276] pinctrl core: initialized pinctrl subsystem
[ 0.371917] regulator-dummy: no parameters
[ 0.373382] NET: Registered protocol family 16
[ 0.377166] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.384704] Reprogramming SDRC clock to 400000000 Hz
[ 0.386688] omap_gpio 48310000.gpio: could not find pctldev for node /ocp/pinmux@48002a00/pinmux_gpio1_pins, deferring probe
[ 0.386749] platform 48310000.gpio: Driver omap_gpio requests probe deferral
[ 0.387786] OMAP GPIO hardware version 2.5
[ 0.394622] platform 49022000.mcbsp: alias fck already exists
[ 0.395019] platform 49024000.mcbsp: alias fck already exists
[ 0.398864] omap-gpmc 6e000000.gpmc: GPMC revision 5.0
[ 0.401428] No ATAGs?
[ 0.401428] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.403076] OMAP DMA hardware revision 5.0
[ 0.417785] bio: create slab at 0
[ 0.561950] raid6: int32x1 85 MB/s
[ 0.709106] raid6: int32x2 112 MB/s
[ 0.855773] raid6: int32x4 89 MB/s
[ 1.002868] raid6: int32x8 90 MB/s
[ 1.002868] raid6: using algorithm int32x2 (112 MB/s)
[ 1.002899] raid6: using intx1 recovery algorithm
[ 1.003906] edma-dma-engine edma-dma-engine.0: Can’t allocate PaRAM dummy slot
[ 1.003967] edma-dma-engine: probe of edma-dma-engine.0 failed with error -5
[ 1.019073] omap-dma-engine 48056000.dma-controller: OMAP DMA engine driver
[ 1.019683] platform hsusb2_power_reg.24: Driver reg-fixed-voltage requests probe deferral
[ 1.022918] SCSI subsystem initialized
[ 1.023651] usbcore: registered new interface driver usbfs
[ 1.023742] usbcore: registered new interface driver hub
[ 1.023925] usbcore: registered new device driver usb
[ 1.025787] omap_i2c i2c.10: did not get pins for i2c error: -19
[ 1.026367] omap_i2c i2c.10: bus 0 rev4.4 at 2600 kHz
[ 1.027313] omap_i2c i2c.11: did not get pins for i2c error: -19
[ 1.027770] omap_i2c i2c.11: bus 1 rev4.4 at 400 kHz
[ 1.027893] omap_i2c i2c.12: did not get pins for i2c error: -19
[ 1.028320] omap_i2c i2c.12: bus 2 rev4.4 at 100 kHz
[ 1.029174] media: Linux media interface: v0.10
[ 1.029266] Linux video capture interface: v2.00
[ 1.029418] pps_core: LinuxPPS API ver. 1 registered
